Project: Skunk Works III
pl521sss
Here's that modified oil spray bar from a Z motor.
Cam towers form that motor has the oil feed that goes to the bar itself.
Alternative to the Nissan Comp spray bar that requires drilling through the valve cover and running oil feed from the oil sending unit.
Cut in the middle then slightly larger tube insert over it.
  • Replies 96
I agree... 521 wheels are hard to find
Dude
now you tell me
Or is hard to find cause your missing 521 wheel? :D
I should have asked the forum first if someone wants a "perfect 521 wheel" for a not so good 521 wheel. I just need the the center hub.
My 521 wheel was cracked but I had a sweet Petri Wheel for a VW, I took and turned the 521 hub down to about an 1 1/2" and bored the center out of the Petri wheel to fit pressed it in and welded it, as long as you dont think about it, it works well. it also helps to have a lathe and TIG welder.
Can you post pics?
I don't have a lathe or welder.
That's going to be a problem.
Will ask my neighbor fineline if he could help :D
  • 1 month later...
Bearing Carrier Spacers
Used an aluminum block @ 34 inch each.
My brothers friend did it the machining.
Slotted like the bracket.
BTW, the bolts are SAE not metric
Installed
Went with 34 inch for now and check for vibration.
I think most folks went with 1.5 right away
  • 1 month later...
  • 3 weeks later...
  • 1 year later...
The red 521 belongs to a different member, but yes it is notched and body dropped. Im hazy on whether its still even on the road. Havent heard much from him personally since the brakes failed and it rear ended a semi.
On a side note...yea, im back. More to come...
very cool. like the wheels. what size are they? did you have to notch the frame in the rear?
My truck is not notch
Lowering blocks
Wheels are 15 x 7 (If memory is correct)
J-dropped521 on other hand is notched (Red truck)
He has a thread here somewhere
Where you been man?
Who's your VG coming along?
J-dropped521 still around
He hasn't posted anything that I know in a while.
Spoke to him couple of days ago and he's going for different motor.
I'll let him tell rest of the story, let's just say it's not a Nissan\Datsun motor.
  • 1 year later...
My memory is so bad.
It was sort of a group buy
Sway bar is Addco and it was for 620 front and rear bars.
I will double check and maybe someone here can chime in also.
What sway bars are you using? I am on the addco site and can't find any for the pickups
