Guest jaimesix Posted September 16, 2008 Report Share Posted September 16, 2008 Finally got something done!! Installed Addco front sway bars. It's nice, unfortunately it's not powdered coated. Painted high gloss black, easily scratched while installing. Front Disc conversion and 620 spindle assembly. Almost there. Installed Billstein rear shocks. Their are one stiff shocks. It's a pain to compress them while installing it. :mad::mad::mad: And I have the matching front Billstein as well. Got lucky to even find them. How do you feel the truck now with all those goodies.. Sway bar, suspension.....must feel nice.:cool: Performance report would be appreciated. Jaime._____________________________________________________ Quote Link to comment
pl521sss Posted September 16, 2008 Author Report Share Posted September 16, 2008 How do you feel the truck now with all those goodies.. Sway bar, suspension.....must feel nice.:cool: Performance report would be appreciated. Jaime._____________________________________________________ Haven't installed the rear sway bar and front Bilstein shocks yet. Cause of suspension travel is limited and will just blow out those shocks from bottoming out. Rear Bilstein shocks are awesome Handles pretty well for a torsion bar, hardly any body roll. But it's harsh on my internal organs, very little suspension travel upfront. It will continue this way till I do something about it. It's a fun truck, different and not many around that it's daily driven. Quote Link to comment
Guest jaimesix Posted September 16, 2008 Report Share Posted September 16, 2008 If you are worried about suspension travel, best way to deal with it is by cutting the strut assemblies shorter. Then use a shorter strut insert. I am doing that with my 610. Had I gotten the springs cut, or simply getting shorter performance springs, when lowering the car, the strut would had kept very limited travel range. By using shortened struts and strut assemblies you regain your suspension travel range. Cutting the strut assembly , taking a section of the tube, and re welding, plus a threaded spring seat for adjustability will do. Bilstein is an excellent brand, German made shocks /struts . I do not know which strut assemblies would fit your Datsun, you could upgrade to another model Datsun front strut assemblies. Perhaps Datsun 210/B210. If 210/B210s work, then you could go all the way to 280ZX, because B210s/710s/610s/280ZX all have same disposition. The only difference between these Datsun front struts asse,mblies is the double walled vented 280ZX discs. But if you could not use any of the aforementioned Datsun struts, no problem, youe existing struts would be excellent with shorter strut inserts and shortened assemblies. About your sway bars, I love sway bars, make any car feel like a million bucks! About harsh suspension feeling, something that helps is getting a good seat. It does not have to be a fancy expensive one, you can reupholster your existing seat, and in the process, a good upholsterer will re-do the spring system, even improve it with todays better options. Keep us posted. Jaime.___________________________________________________ Quote Link to comment
slodat Posted September 16, 2008 Report Share Posted September 16, 2008 Jaime, that is great advice! For a car :D This thread is for a 521 truck. They have no struts. pl521sss: the way I am handling the suspension travel/lowering equation on my 521 is with custom upper control arms to convert to ball joints, drop spindles and coil overs. Quote Link to comment
pl521sss Posted September 16, 2008 Author Report Share Posted September 16, 2008 Jaime, that is great advice! For a car :D This thread is for a 521 truck. They have no struts. pl521sss: the way I am handling the suspension travel/lowering equation on my 510 is with custom upper control arms to convert to ball joints, drop spindles and coil overs. I think you meant 521 I saw your project thread and it's a good option. There's several approach to correct this issue. One that I wanted to do is Mike's Z'd lower control arm. This way, can still use my Bilstein front shocks. Or Fineline's QA1 coilover setup and eliminate the Torsion bar all together. Quote Link to comment
slodat Posted September 16, 2008 Report Share Posted September 16, 2008 Mike's Z'd LCA is a slick setup. For me, it was much simpler to buy the upper control arms. I really need the disc brake upgrade as well. I'm running the coil over setup ala Fineline as well. Quote Link to comment
Guest jaimesix Posted September 17, 2008 Report Share Posted September 17, 2008 Yes, sorry guys about my ignorance about this pick up truck's suspension. Is it leaf sprung all around?:confused: Does it have a J15 engine? I love J series engines, I bought a Nissan Negine factory manual for the J series a while ago. I hope the issues with lost dampening travel can be addressed efficiently. Those trucks are cool. Jaime._____________________________________________________- Quote Link to comment
Guest jaimesix Posted September 17, 2008 Report Share Posted September 17, 2008 My early X-mas shoppingI think this should do for now. This will keep me busy for the next month or 2 at least. Ignore the Strut bar on the picture, it's for the 510. OK, I see a L16 valve cover over there, that answers my J series question.:rolleyes: It is a great looking truck, those wheels look awesome, perfect. I do not ike chrome ( I am the self proclaimed "Enemy Number One of Chrome!:cool: ENOC!!!!:eek: )...so these wheels are 100% awesome in my view. What are these??? My 710 would look very cool on these , albeit being 6 lug nuts instead of four....would have to contrive something up. Jaime.______________________________________________________- Quote Link to comment
pl521sss Posted September 27, 2008 Author Report Share Posted September 27, 2008 Test engine smokey (burns oil) for turbo setup. Turbo mounted So far so good Still have the starter, Ignition, oil pan, carb and oil fittings to hook up. I say another 2 more weekends before I can start it up. Was able to track down gaskets for the housing in case I need to tear it down. Also able to contact a former Roto-Master employee that has CHRA (Center Housing and Rotating Assembly) for sale. Not sure what gasket to use for the exhaust outlet and hopefully the wastegate is still good. Quote Link to comment
fisch Posted September 27, 2008 Report Share Posted September 27, 2008 So the turbo is for the 521! Awesome! Quote Link to comment
pl521sss Posted September 27, 2008 Author Report Share Posted September 27, 2008 So the turbo is for the 521! Awesome! Turbo setup is for any L4 powered Datsun I change my plan on putting it on my truck instead. Quote Link to comment
fisch Posted September 27, 2008 Report Share Posted September 27, 2008 Turbo setup is for any L4 powered DatsunI change my plan on putting it on my truck instead. Oh I know you can put it on any L4.:) I am just celebrating it going on the 521 rather than the dime! Doin' a dance, doin' a dance!:D Though I'd be dancing to see it on any datto really. BTW, way to do your homework and find a guy who used to work for rotomaster! Quote Link to comment
impala_631 Posted October 16, 2008 Report Share Posted October 16, 2008 lookin good Quote Link to comment
pl521sss Posted February 9, 2009 Author Report Share Posted February 9, 2009 Is this off 521 truck? Got it for free Quote Link to comment
WAGON JON Posted February 16, 2009 Report Share Posted February 16, 2009 Was curious where you picked up the turbo header? I need one for my L series. Wagon Jon Quote Link to comment
pl521sss Posted February 23, 2009 Author Report Share Posted February 23, 2009 Improved lighting LED lights on 521 Dash Idea from VGwagon It uses high intensity 1W LED. Compared with filament bulbs, it has no heat output and extremely low power consumption. It works at 12V. Compared with traditional LED bulbs, it has a 180degree of intense illumination. Removed this colored bulb cover right behind the speedo gauge. LED bulb Here's something interesting Hidden when installed It says 60MPH=1024RPM I guess it's formula for speedo calibration Quote Link to comment
pl521sss Posted February 23, 2009 Author Report Share Posted February 23, 2009 Here's the wire to tap into for you car alarm. Red with blue stripe wire behind the dash cluster gauge wiring. For those who install their own alarm. sends output for the running lights and dash light to flash when armdisarm. Thought would be helpful Quote Link to comment
denveratsun Posted February 23, 2009 Report Share Posted February 23, 2009 Great looking thread! Keep it up man!:cool: Quote Link to comment
dat521kid Posted February 23, 2009 Report Share Posted February 23, 2009 Improved lightingLED lights on 521 Dash Idea from VGwagon It uses high intensity 1W LED. Compared with filament bulbs, it has no heat output and extremely low power consumption. It works at 12V. Compared with traditional LED bulbs, it has a 180degree of intense illumination. Removed this colored bulb cover right behind the speedo gauge. LED bulb Here's something interesting Hidden when installed It says 60MPH=1024RPM I guess it's formula for speedo calibration WOW this is so great i love it!!! looks real good man Quote Link to comment
Duke Posted February 24, 2009 Report Share Posted February 24, 2009 Just wanted to say that I dig the project. Very clean, with some cool, well thought out mods. Looking forward to seeing the turbo on there. Quote Link to comment
pl521sss Posted February 24, 2009 Author Report Share Posted February 24, 2009 WOW this is so great i love it!!! looks real good man just wondering.. how much and where did you get those led's for your dash? thanks, robert __________________ think different, question everything!!!:fu: I got it from this guy in ebay http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__2pcs-168-194-1W-High-Power-LED-Spark-Blue-Wedge-Bulb_W0QQitemZ190287920433QQadiZ2865QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item190287920433&_trksid=p4506.c0.m245&_trkparms=72%3A543|65%3A12|39%3A1|240%3A1318 Quote Link to comment
izzo Posted February 24, 2009 Report Share Posted February 24, 2009 check out a site called http://www.Superbrightleds.com probably the same bulbs, might even get them cheaper? they make all kinds of LEDs for your car, tail lights, turn signals etc. and even have a power adapter for it to keep your turn signals from flashing fast due to the lower power consumed by the led's Quote Link to comment
dat521kid Posted February 24, 2009 Report Share Posted February 24, 2009 (edited) I got it from this guy in ebay http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__2pcs-168-194-1W-High-Power-LED-Spark-Blue-Wedge-Bulb_W0QQitemZ190287920433QQadiZ2865QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item190287920433&_trksid=p4506.c0.m245&_trkparms=72%3A543|65%3A12|39%3A1|240%3A1318 cool thanks for the link... i noticed you took a pic of 2 of them, is that all i need? h2theizzo thanks for that link too Edited February 24, 2009 by dat521kid Quote Link to comment
pl521sss Posted February 24, 2009 Author Report Share Posted February 24, 2009 Was curious where you picked up the turbo header? I need one for my L series. Wagon Jon It's part of the RayJay Turbo Kit sold back in the 80's Just wanted to say that I dig the project. Very clean, with some cool, well thought out mods. Looking forward to seeing the turbo on there. Thanks man, hope you get your engine sorted out Was just reading your project thread cool thanks for the link... i noticed you took a pic of 2 of them, is that all i need? h2theizzo thanks for that link too There's 4 bulbs for illumination on the dash I only use 2 cause it's more than enough You could use 4 if you want 2 right behind the speedo and 1 each top corner I replaced just the 2 behind the speedo Careful though, when you have it out of the case, the gauge needles are easily bent if your not careful while working on it. Quote Link to comment
dat521kid Posted February 24, 2009 Report Share Posted February 24, 2009 sweet man, thanks im going to order them right now!!! Quote Link to comment
