burrito213 Posted June 6, 2010 Author Report Share Posted June 6, 2010 update: (will post pics soon) tried to put the slave cylinder on and ....well....it wouldn't go on.... The shark fin (spring hole) on cylinder was hitting against the (torsion bar)...it definitely is another transmission because looking at the arm is just chewed up.... I may have to cut the shark fin and or find an alternative..... if I cut it, I won't screw up the innards would I? Quote Link to comment
burrito213 Posted June 6, 2010 Author Report Share Posted June 6, 2010 but also...the slave cylinder was $32+ so I figure return it and get another w.out it. Quote Link to comment
Charlie69 Posted June 6, 2010 Report Share Posted June 6, 2010 Buritto cutting that off will not harm the cylinder. Just cut enough off to clear the torsion brt and then redrill the return spring hole. Quote Link to comment
burrito213 Posted June 6, 2010 Author Report Share Posted June 6, 2010 here are the pics.... started cleaning all the transmission fluid that leaked out: (thanks walmart. kitty litter $2.98) got the parts!...note: for this clutch slave, it did not come with the bolt or nuts. side by side: ANNNdddd,,,, it didnt fit: until i can get to my jobs work shop.... time to throw the ball around: Quote Link to comment
mklotz70 Posted June 7, 2010 Report Share Posted June 7, 2010 You can drill another hole, half way between the hole in the tab and the edge of the body...effectively moving the hole inboard. Then cut off the tab at the original hole. You won't hurt the slave cyl, but you will not be able to return it if it doesn't work for any other reason. Quote Link to comment
burrito213 Posted June 7, 2010 Author Report Share Posted June 7, 2010 cut and grinded about 1/4" . doesnt look too bad . didnt punch before i drilled so i got the hole a little back but it looks like it would work. Quote Link to comment
Charlie69 Posted June 7, 2010 Report Share Posted June 7, 2010 Looks great Burrito. Now let see some video of you driving it. :D Quote Link to comment
mklotz70 Posted June 8, 2010 Report Share Posted June 8, 2010 should work just fine. :) Quote Link to comment
burrito213 Posted July 2, 2010 Author Report Share Posted July 2, 2010 update for the concerned: i have been off and on with the 320 for some time. not that im neglecting it but since the tranny seal or ??? went bad i decided just to pull the engine and clean it up a little while i rebuild the tranny in hopes to make it to JCCS. if not, there are plans, though it'll be a slow build, there will be plans for the 320. whats slowing me down is i have to sell my other truck -but- i have to repair it before i move ahead. its not a datto, its a chevy :o..and also my honda which im planning on ratrodding it out a little ideas right now are the obvious of getting it running again, rhino line or line-x the bed, paint the truck and wheels, add a stereo, new upholstery, re-chrome all trim and stuff that has chrome, clean the suspension and engine, and make some plaque as homage to "Ratsun" and all the insight all you have left behind and gave me. as of now, i bought some bullet lugs and caps but the caps are running a little small. i read you can flare them out...sooooo... does anyone have an idea how i can flare them out?... i can mail them to you or just give me a play by play and i can attempt to do it at work. i think i just need 1/4" all around and it'll shorten the cap and look better on the wheel. once that is done, i am going to repair the few busted wheel studs... here are some pics: this is the gap i'd need to work with: ______________________________________________________________________________________________________________ with this i ask MKLOTZ 70: are you still selling the dics conversion set? if so - do i need to do anything besides buy the caplipers, rotors, and conversion kit, and some of the fabrication/buy new of the brake lines? ---would i need to really replace the master brake cylinder? ---i read the thread and it said i may have to machine down, is this true? (just trying to get everything prepped before i commit to this) if there is alot of information, i can pm you for info. and thanks for the help so far _______________________________________________________________________________________________________________ and i also requested 6 lug 14" stock wheels on the "items wanted" so if any of those reading this and know someone who can part out with a set please let me know -or- is it difficult to convert the 6 lug to 5 lug set up for the 320?... seems like there are more 5 lug options out there but this is just an idea for now unless it is easily do-able. Quote Link to comment
mklotz70 Posted July 3, 2010 Report Share Posted July 3, 2010 That sounds like about it, I haven't looked in awhile. I personally wouldn't use the stock m/c, but I've heard of other guys doing it. If you're already making brake lines, it's the best time to do it. If you use '83ish 720 hubs, you don't need to machine the hubs. The machining is for the late 720 and hardbody hubs....to use with stock wheels. One of these days, I should check into using Toyota hubs with my kit.....since the bearings are the same in the Toy hub and the 720 hub, it probably wouldn't take much to make it work. As of right now, I don't know of any 5 lug options for kingpins. Quote Link to comment
Charlie69 Posted July 3, 2010 Report Share Posted July 3, 2010 Burrito, I used 1980 720 hubs on my Mike klotz brackets & the stock 320 wheels fit the hubs fine, no machining required. Mike does this mean there will be another run of the famous Klots disk brake kits? Quote Link to comment
mklotz70 Posted July 3, 2010 Report Share Posted July 3, 2010 There will be...hopefully in the next month or so. I was going to use some of the money from the wgn to order up parts, but oh well. :) Just FYI on the clutch slave....I just put a 620 slave into Paula's 521....it looked the same as the one Burrito put in, but it didn't have the tab sticking out that he had to modify. I'll have to put up some pics of what I did and put a link here. The 521's frame is at least 3" wider, so the tab would work. I didn't notice the missing tab on the 620 slave until I was about to mount it...so I had to come up with a way to hold the spring. It ought to work really nice on a 320. :) Quote Link to comment
burrito213 Posted July 6, 2010 Author Report Share Posted July 6, 2010 picked up a new toy...gotta see what this can do.. will post pics of results soon. ______________________________________________________________________________________________ and mike (if you read this), charlie69 gave me the motivation to convert to disc so if you do make your famous convesion kits again please put me down for one set. i will slowly buy the needed parts till that time. Quote Link to comment
Charlie69 Posted July 8, 2010 Report Share Posted July 8, 2010 With the blasting cabinet & the pressurized sand blasting pot moisture is your worst enemy. Here is a link that shows a great way to set up compressor air lines to minimize water in the lines. http://www.tptools.com/pl/Images,metal_pipe_kits_L,74,2035_Modular-Metal-Piping-Kits.html be careful with the sanblaster it creates lots of dust. Quote Link to comment
burrito213 Posted July 8, 2010 Author Report Share Posted July 8, 2010 With the blasting cabinet & the pressurized sand blasting pot moisture is your worst enemy. Here is a link that shows a great way to set up compressor air lines to minimize water in the lines. be careful with the sanblaster it creates lots of dust. thanks for the info charlie69. i noticed there was residue on the rim of the tank so i knew there might be some cleaning before i use it. i paid $100 for it so hopefully i can put good use to it Quote Link to comment
hang_510 Posted July 8, 2010 Report Share Posted July 8, 2010 Here is a link that shows a great way to set up compressor air lines to minimize water in the lines. :hmm: dont see it, can you post it again? Quote Link to comment
burrito213 Posted July 11, 2010 Author Report Share Posted July 11, 2010 hey everyone... met up with AZhitman on a run to sandiego thursday and picked up some needed parts and met some great guys over at classic datsun motorsports... thanks to AZhitman and charlie69 for the help,,,great people with loads of good information. but two questions rose when i was talking about my truck... apparently i am suppose to have a column shifter and not a floor shifter but i have a floor shifter -&- there was 3 sets of trim made for the 320 which one was mine.... also, if you read this AZhitman, here are my pics of my trim and the steering column. (and yes, i think my floor did get cut) if anyone else has input please post and if "i can afford it, i'll restore it!"...lol trim___________________________________________ Quote Link to comment
mklotz70 Posted July 11, 2010 Report Share Posted July 11, 2010 here's a link to my NL on photobucket....you might find the pics you want....might be faster than waiting for me to take more :) http://s88.photobucket.com/albums/k162/mklotz70/NL320/ Quote Link to comment
Charlie69 Posted July 11, 2010 Report Share Posted July 11, 2010 Hey Mike, we need you to do a photo shoot with your NL any way. We need more pictures of you with your NL! Also if Fisch is watching we need another Fisch picture of Mike's NL with Mike in it. How about a group picture of Mike & Burrito with there NL's. :D Burrito good things come to good people! Quote Link to comment
mklotz70 Posted July 12, 2010 Report Share Posted July 12, 2010 If not tonight, in the morning...got some pics of the NL in different locations today :) It might take a bit for burrito and I to get them side by side! Quote Link to comment
Charlie69 Posted July 12, 2010 Report Share Posted July 12, 2010 Burrito & Mike it would be well worth any wait to see pictures off both your NL together. Also be even beter If AZhitman's NL could be included. Just imagine 3 Running and great looking NL's In the same picture in the 21st Century. :cool: Quote Link to comment
burrito213 Posted July 12, 2010 Author Report Share Posted July 12, 2010 that is so true charlie69...azhitman was saying when I spoke to him that there are no more than 6 or so nl320's that are running... I plan on hitting canby next year if possible and jccs this year even if I have to trailer it....i hope I can get the truck back at 100% soon ... Quote Link to comment
mklotz70 Posted July 12, 2010 Report Share Posted July 12, 2010 Burrito.....I took the time to take these pics and vids while I was replacing the clutch slave on my wife's 521 a few weeks ago. I finally got around to doing a thread on it. I know you're already done, but maybe either you or someone watching your thread will have a use for this info later. :) http://community.ratsun.net/topic/22972-clutch-slave-adjustment/ Quote Link to comment
burrito213 Posted July 12, 2010 Author Report Share Posted July 12, 2010 thanks mike... I haven't pushed forward with finishing my clutch slave yet because I planned to pull the engine so I am sure I am going to benefit from the thread you made Quote Link to comment
