DatDoug Posted November 6, 2009 Report Share Posted November 6, 2009 So outta all you Dimers which one of these is the preferred tranny in a 510? It will be going in a 69 Goon with a semi-built L20b. I already av both trannys. I av never driven a DogLeg B4:blink: Quote Link to comment
JDM510 Posted November 6, 2009 Report Share Posted November 6, 2009 Hi im new here lol j/k whats the diff between the 2??? What makes a dog leg a dog leg??? What dose it come in? Quote Link to comment
Cuts metal like mad Posted November 6, 2009 Report Share Posted November 6, 2009 dogleg is weaker, I don't like it... its just weird. The Z tranny is gonna require shortening of the driveline though, but its a better tranny. Quote Link to comment
izzo Posted November 6, 2009 Report Share Posted November 6, 2009 the dogleg has a different shift pattern than a normal car, came in the 200sx for a short amount of time Doug, i don't own a 510. I have two trucks tho, the 80 has the dogleg in it, and my 85 has the 5sp in it. I like em both. Quote Link to comment
benzo Posted November 6, 2009 Report Share Posted November 6, 2009 I prefer the zx trans. I heard one time that the doglegs are a pain to rebuild but I may be wrong. Quote Link to comment
Yakuza Posted November 6, 2009 Report Share Posted November 6, 2009 Z trans all day....the dogleg is weak...:D Quote Link to comment
datzenmike Posted November 6, 2009 Report Share Posted November 6, 2009 The dogleg (FS5W63) drops in to the 510, no drive line shortening needed as it's the same length as the stock 4 spd. You may need to mod the rear mount. The FS5W63 shift pattern is: R 2 4 1 3 5 The FS5W71B 280z 5spd ('77-'78) is almost 6" longer and besides shortening the driveshaft you will need to make/mod a mount for it and get a longer speedo cable. The 280zx 5spd. ('79-'83) same as above but a much higher 5th overdrive ratio. The FS5W71B shift pattern is: 1 3 5 2 4 R Of the two the FS5W71B is stronger than the FS5W63 but either will be fine behind an unmodified L20B. Quote Link to comment
slodat Posted November 6, 2009 Report Share Posted November 6, 2009 I have a few doglegs. I do not like it. At all. My vote is the Z/ZX 5 speed, even if it is a little more work, you won't regret it. Quote Link to comment
datzenmike Posted November 6, 2009 Report Share Posted November 6, 2009 Funny about doglegs, you either love 'em or hate 'em. Quote Link to comment
JDM510 Posted November 6, 2009 Report Share Posted November 6, 2009 (edited) ****WARNING POSIBLE THREAD JACK (sorry)**** Thanks datzenmike i see why your called "king rat" MY CAR IS A 71 W/AUTO, WITH THE DOG LEG WILL I HAVE TO MOD MY DRIVE SHAFT???? SPLINES, LENGHT?? IM ON THE FENCE IF IM JUST GOING TO THROW A 5SPD AND DRIVE IT TILL THE MOTOR POPS (47K AND YOU CAN EAT OFF THE INSIDE OF THE ENG.) SO IT MAY LAST FOR A WHILE OR IF LIKE MY DAD SAYS MY LIFE TIME LOL. OPTION 2 IS TO PUT A KADE WITH SOME CARBS OF SOME SORT (im thinking r1) or just some mikunis but i kind of want to be diff OR OPTION 3 IM NOW THINKING OF GOING CARB'D VG AFTER SEEING A FEW NICE SWAPS I THINK IT LOOKS GOOD IN THIER WITH THAT MOTOR BUT I DONT LIEK THE IDEA OF DUAL PIPES UNDER THE CAR IDK I HAVE NOT SEEN MANY PEOPLES EXAUST SET UPS WITH THAT SWAP YET OR KNOW HOW RESTRICTIVE IT WOULD BE TO MAKE A 2into1 SYSTEM FOR THAT MOTOR WOULD BE BUT IF I CAN JUST PRETTY MUCH BOLT A DOGLEG IN THAT MIGHT BE THE BEST OPTION TILL I CAN FIGURE OUT WHAT I WANT TO DO. CUZ ONCE I START GETTING INTO MODDING THE SHAFT AND MOUNTS I MAY ASWELL JUST DO THE MOTOR SWAP AT THE SAME TIME CUZ I DONT WANT TO HAVE TO DO THINGS TWICE Edited November 6, 2009 by JDM510 Quote Link to comment
slodat Posted November 6, 2009 Report Share Posted November 6, 2009 What's with the caps lock? That is really hard to read.. Quote Link to comment
izzo Posted November 6, 2009 Report Share Posted November 6, 2009 Won't you have to cut the tranny tunnel too also to make the 280 trans fit? Quote Link to comment
JDM510 Posted November 6, 2009 Report Share Posted November 6, 2009 (edited) What's with the caps lock? That is really hard to read.. im sooo sorry i just noticed that i hit the caps lock im on one of these new stupid lil laptops and i guess my fingers are hitting every button but the one i want lol also my first 510 i did the zx swap and mods included: cutting the tunnel for the shifter cuz its futher back, shorting the drive shaft, and on my car all i had to do was flip the tranny x memeber around and it bolted right up Edited November 6, 2009 by JDM510 Quote Link to comment
bigjoe619 Posted November 6, 2009 Report Share Posted November 6, 2009 i believe you have to cut the tunnel 4 in and if im mot mistaken the drive shaft to 37 3/4in from center to center and in a wagon u could use a stock 2 door drive shaft Quote Link to comment
banzai510(hainz) Posted November 6, 2009 Report Share Posted November 6, 2009 (edited) the dogleg is a bit of a pain when racing due to 1 being down and 2nd up and to the right which you can blow a shift . sometimes put it in reverse. thinking its 1st. Frank/Jeff might have drivelines cut already in the correct length But its a EZ swap putting the doglegin. if you dont race around its fine in my book. the ZX is alot beefier. but needs shorting. Carter said Dave Carrol has made soem new X members and is taking orders from yesterday:Carter Boad [CarterB@Electroimpact.com] Great news guys. We finally have a new batch. It is currently being powder coated so I can take orders again and ship next week. Let me know if you are still interested. I have nine available in this first batch and the next batch won’t be too far out. The crossmembers are still $75 each. $10 shipping to the lower 48. I also have some experimental engineering idler bushing kits in stock at $32 each and a few T/C kits available as well for $28 each. I also have the last of the experimental engineering wheel spacers available in 1/2” and 5/8” for $50/pr. No additional shipping charges will be added if any of these items are included with your crossmember order. Thanks! --carter If you are doing a KA or SR swap, the crossmember *should* still be a bolt-in but depending on your engine’s location, you may have to increase the slot length or drill new mounting holes. Reports from customers have been about half and half. For the L-motor stuff - it is VERY rare that it is not a true bolt in. --carter also get the Cysler door hinge kit to use the brass side bushing for the shifter. the plastic ones suck HELP brand 38377 or the mutipack 38374 from Schucks Being a Z car has such a high ratio diff I dont think youll see any difference in MPG Maybe 1st will be to low in the ZX trans combined with a lower diff ratio in a 510 Edited November 6, 2009 by banzai510(hainz) Quote Link to comment
Bleach Posted November 6, 2009 Report Share Posted November 6, 2009 1980-83 have the taller 5th gear. 1979 and older are close to what the 620 truck had as far as gear ratios. If your rear gear is the same then you should be just fine with the tall geared 5-speed. Quote Link to comment
hang_510 Posted November 6, 2009 Report Share Posted November 6, 2009 the dogleg is a bit of a pain when racing due to 1 being down and 2nd up and to the right which you can blow a shift . sometimes put it in reverse. thinking its 1st. :lol: i only do that at stop signs! :GRIND: :o racing: thats only an issue from a stop! in the cyns, the straight 2-3-2 shifting is the :poop: i have both, they are used for different applications. the goon will have the ZX, the sedan has a dogleg (and i wouldnt swap it either!) Quote Link to comment
DRIVEN Posted November 6, 2009 Report Share Posted November 6, 2009 :lol: i only do that at stop signs! :GRIND: :o racing: thats only an issue from a stop! in the cyns, the straight 2-3-2 shifting is the :poop: i have both, they are used for different applications. I read somewhere on the 1200 site that the dogleg pattern was actually a racing development because the 4-5 and 5-4 shifts being the most common on a road course. In response to the OP - I would probably use the dogleg just because it is a more direct swap. Related question: What is the difference between the 200sx dogleg and the one used in the 720 w/L20B? Quote Link to comment
datzenmike Posted November 6, 2009 Report Share Posted November 6, 2009 The dogleg overdrive is second only to the two '80-'83 280zx 5spds. Quote Link to comment
izzo Posted November 6, 2009 Report Share Posted November 6, 2009 I read somewhere on the 1200 site that the dogleg pattern was actually a racing development because the 4-5 and 5-4 shifts being the most common on a road course. In response to the OP - I would probably use the dogleg just because it is a more direct swap. Related question: What is the difference between the 200sx dogleg and the one used in the 720 w/L20B? dogleg didn't come stock. was installed afterwards, i believe the 80 720 with l20 came with a 4sp Quote Link to comment
DRIVEN Posted November 6, 2009 Report Share Posted November 6, 2009 What are the odds? I've driven 2 1980's with doglegs. You sure they didn't come that way? Quote Link to comment
izzo Posted November 6, 2009 Report Share Posted November 6, 2009 What are the odds? I've driven 2 1980's with doglegs. You sure they didn't come that way? In a 720? I don't think they did. Could be wrong! Datzenmike probly knows :D Quote Link to comment
DRIVEN Posted November 6, 2009 Report Share Posted November 6, 2009 Datzenmike probly knows :D Man, if I had a nickle for every time someone said that:lol:. Quote Link to comment
novita1021 Posted November 6, 2009 Report Share Posted November 6, 2009 over all dogleg is a good trany i like it behind my L16 which only has a weber 32/36 petronics ignition with msd coil..that gear patern makes it feel like a race car..haha its funny to trip ppl out..lol.. Quote Link to comment
Dime Dave Posted November 6, 2009 Report Share Posted November 6, 2009 My Nissan Parts CD shows only the standard pattern 5 speed for the '80 720. The direct drive competition 5 speeds, 71 series, had the dog leg shift pattern. The cases on this transmission are the same as the 280ZX 5 speed cases. Quote Link to comment
