TENDRIL Posted February 17, 2015 Report Share Posted February 17, 2015 Jacob if you ca, could you post the rad dimensions of yours to compare ? Quote Link to comment
southern620 Posted February 20, 2015 Report Share Posted February 20, 2015 I'm real curious to see what this Radiator looks like installed. 1 Quote Link to comment
]2eDeYe Posted February 20, 2015 Report Share Posted February 20, 2015 Thanks :thumbup: Quote Link to comment
TENDRIL Posted February 20, 2015 Report Share Posted February 20, 2015 hmmmmm what are you up to steve? ^^^^ Quote Link to comment
Laecaon Posted February 20, 2015 Report Share Posted February 20, 2015 Yea, Ill do that... I have pictures of the intercooler measured, but not the radiator. Pretty sure its Identical though, but with a cap, and shittier welds. 2 Quote Link to comment
Laecaon Posted February 22, 2015 Report Share Posted February 22, 2015 So this is the CXRacing/Speed Daddy/whatever else they want to sell it as on ebay radiator. 2 Quote Link to comment
TENDRIL Posted February 22, 2015 Report Share Posted February 22, 2015 for same page comparison 3 Quote Link to comment
Laecaon Posted February 23, 2015 Report Share Posted February 23, 2015 In reality, the CXRacing radiator is silly wide. Here is how wide it is. I have opened up my radiator opening 1.5" on either side and Im still not even close to getting to the end tanks. How it looks through the core support on a 510: And from inside the bay, notice how close it is to the headlights... 2 Quote Link to comment
TENDRIL Posted February 23, 2015 Report Share Posted February 23, 2015 thats what i didnt like about the one i installed ....... but meh we will see hoe it ends up 1 Quote Link to comment
]2eDeYe Posted February 23, 2015 Report Share Posted February 23, 2015 hmmmmm what are you up to steve? ^^^^ Just like to see what the options are. :) 1 Quote Link to comment
ppeters914 Posted February 23, 2015 Report Share Posted February 23, 2015 The welds are nice. B) 1 Quote Link to comment
Charlie69 Posted February 23, 2015 Report Share Posted February 23, 2015 Redeye I have the CRX SR20 Radiator for my 66 520. It looks to be well made and yes is is wide. it has 2 1" cores. I also purchased the radiator shroud and 2 12" fans for it. 1 Quote Link to comment
DAT510 Posted June 27, 2016 Report Share Posted June 27, 2016 I just wanted to post this here for future searches, Dayco #71601 lower rad Jose works perfect with the 97 Jetta rad. As Creepycruisers method of using old radiator hose as a reducer it works perfectly. I'll post a picture of fitment later 1 Quote Link to comment
Docsis510 Posted April 25, 2018 Author Report Share Posted April 25, 2018 Bump!! Any new ideas... doing a single cam ka swap on my 68 510.. just want to see if anyone has new radiator ideas. 1 Quote Link to comment
paradime Posted April 25, 2018 Report Share Posted April 25, 2018 You can buy a core direct and you or they can mig the in, out, and fill cap where ever you want. https://radiatorsupplyhouse.com/products/custom-fabrication/ 1 Quote Link to comment
demo243 Posted April 25, 2018 Report Share Posted April 25, 2018 AFCO 80104n - https://www.summitracing.com/parts/afc-80104n You can see the hose numbers I used as well (Both needed to be trimmed down)- both the hoses I used do require a reducer on the engine side - each one needed to be reduced by 1/4" if I remember correctly - I also ended up going with an inline thermostat as well since I plugged the heater core outlet and had temp issues. Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr 3 Quote Link to comment
