INDY510 Posted October 10, 2008 Author Report Share Posted October 10, 2008 I plan on building a custom oil pan so I can move the motor forward 2-3 inches, because right now the mounts are 8 inches farther back than stock, and that rusty L16 mount is too close to the steering box: Here is my idea to modify the stock CA16DE intake: Quote Link to comment
Cuts metal like mad Posted October 10, 2008 Report Share Posted October 10, 2008 heh... where you gonna put the motor mounts? if you are doing this just to avoid flipping the x-member, bad plan bro, flip it, its easy compared to what you got goin now. Quote Link to comment
Icehouse Posted October 10, 2008 Report Share Posted October 10, 2008 It looks like the throttle body is upside down :D Not that it maters or anything. Have you picked up a tranny yet? Quote Link to comment
INDY510 Posted October 25, 2008 Author Report Share Posted October 25, 2008 (edited) Motor #3: a L18 with dual 44mm mukunis, and a 280zx 5-speed all for $700, it even included a shortened drive shaft What's up with the oil filter? Edited October 25, 2008 by INDY510 Quote Link to comment
slodat Posted October 25, 2008 Report Share Posted October 25, 2008 That looks like a good deal for $700, at least in my opinion. You are installing that instead of the CA? Quote Link to comment
INDY510 Posted October 25, 2008 Author Report Share Posted October 25, 2008 WARNINGPICS Quote Link to comment
510er Posted October 25, 2008 Report Share Posted October 25, 2008 what is going on here? are you doing the motorcycle engine? or the CA inside the firewall? or the L18? and did you just rattle can over the dirt? :lol::lol::lol: Quote Link to comment
INDY510 Posted October 25, 2008 Author Report Share Posted October 25, 2008 are you doing the motorcycle engine? or the CA inside the firewall? or the L18? and did you just rattle can over the dirt? The L18 has the best chances of running this year.... But I have a fiberglass 510 with a busa motor on the drawing table.... And no I did not rattle can over dirt:fu: Quote Link to comment
slodat Posted October 25, 2008 Report Share Posted October 25, 2008 That L-18 doesn't look too shabby to me. Run it. Driving a dime in progress is a lot more fun that looking at one while you figure out your plans for it :D Quote Link to comment
INDY510 Posted October 26, 2008 Author Report Share Posted October 26, 2008 Mmmm.... rattle can over dirt:fu: I'm off to go scrub my engine block.... :blink: Quote Link to comment
INDY510 Posted November 2, 2008 Author Report Share Posted November 2, 2008 (edited) Edited November 2, 2008 by INDY510 Quote Link to comment
Cuts metal like mad Posted November 2, 2008 Report Share Posted November 2, 2008 and the big hole in the firewall? Quote Link to comment
charlie6178 Posted November 3, 2008 Report Share Posted November 3, 2008 a couple questions. #1 wheel demesions, size and offset? and are you running spacers? #2 tire size? #3 what approach did you use to get the rear end sooo low? i love the way yours looks, i'm not planning on going quite that low, but i want something to go off of. Quote Link to comment
Duke Posted November 3, 2008 Report Share Posted November 3, 2008 You might want to open the cowel drain back up, or you will end up with either a bunch of water pouring into the interior or stuck in the cowel. Quote Link to comment
INDY510 Posted November 3, 2008 Author Report Share Posted November 3, 2008 It looks like the throttle body is upside down :D Not that it maters or anything. a couple questions.#1 wheel demesions, size and offset? and are you running spacers? #2 tire size? #3 what approach did you use to get the rear end sooo low? Panasport 16x8 +12mm offset, 225/40/16 tires, and a 3/8" spacer, and they fit that low with stock 510 struts that are shortened and re-threaded. The coilovers hit the tires if I go any lower, they can go 2" lower. #3 The rear end is stock with really old springs that were cut. I will do something better someday. But for now I have the only 510 with bags in the trunk: You might want to open the cowel drain back up, or you will end up with either a bunch of water pouring into the interior or stuck in the cowel. Yeah,,, I think I have to shave the cowl, even though it will look wierd and the windshield will fog up.......and yes I regret cutting the firewall....:blink: Sorry Duke.....................my car might be lower... Quote Link to comment
charlie6178 Posted November 4, 2008 Report Share Posted November 4, 2008 well that gives me something to go off of. that is a great looking car. and the wheels are perfect for it!! Quote Link to comment
bonvo Posted November 4, 2008 Report Share Posted November 4, 2008 so what about the ca? you setting it aside for now? Quote Link to comment
jay cky Posted November 6, 2008 Report Share Posted November 6, 2008 yes wicked looking car:) Quote Link to comment
SIXTY-NINE-DIME Posted November 30, 2008 Report Share Posted November 30, 2008 haha dude put it where the back seats should be... 16k rpms??? damnnn fuck a vtec lol Quote Link to comment
INDY510 Posted April 27, 2009 Author Report Share Posted April 27, 2009 ...:cursing: :fu:My new Gopher Killer:fu: Quote Link to comment
datto510 Posted April 27, 2009 Report Share Posted April 27, 2009 I wondered what happened to this car. Looking a lot better with that L18 in there!:D Quote Link to comment
INDY510 Posted May 19, 2009 Author Report Share Posted May 19, 2009 (edited) Check out the new stance::eek: The valence is too high off the ground with the 16x8's: Stock ride height:lol: I think it is finally low enough... and it even rolls The valence is about 2" off the ground... :w00t: Edited May 19, 2009 by INDY510 Quote Link to comment
fo0manchu Posted May 19, 2009 Report Share Posted May 19, 2009 Got this thing running yet? Quote Link to comment
