72 327 Posted September 1, 2007 Report Share Posted September 1, 2007 What size are the headlights on the 620 truck? Quote Link to comment
Pacific coast Datsun Posted September 2, 2007 Report Share Posted September 2, 2007 5 1/4 inches. I used some Mercedes high beams on my 74...cost $10 @ the yard :D Quote Link to comment
datsun dreamer Posted September 2, 2007 Report Share Posted September 2, 2007 They sell a European Headlight Conversion on ebay. Quote Link to comment
ggzilla Posted September 2, 2007 Report Share Posted September 2, 2007 There are basically only two size of round headlights: * small, for four-headlight system. Inner ones have two lead, outers have 3 * large, for two-headlight system. Except for very old six-volt ones, you can use any large one unless it's a euro conversion (flat face). Quote Link to comment
kiznook Posted September 2, 2007 Report Share Posted September 2, 2007 I thought it was 5 3/4?? mercedes bosch lights are teh sex! Quote Link to comment
yello620 Posted September 2, 2007 Report Share Posted September 2, 2007 I got a set of the clear mercedes bosch lenses and the H1 bulbs at the JY last week. Paid $15 for the pair of lenses and the bulbs. Now i need to order the 100w Hella bulbs, and install them. Jason Quote Link to comment
OL YELLER Posted September 2, 2007 Report Share Posted September 2, 2007 I got a set of the clear mercedes bosch lenses and the H1 bulbs at the JY last week. Paid $15 for the pair of lenses and the bulbs. Now i need to order the 100w Hella bulbs, and install them. Jason Would you then have any issues with the altenator?..as in not big enuff to handle the headlight amperage requirements?..I am asking because I don't know and/or don't remember if this has ever been discussed...so ....anybody?......Ron Quote Link to comment
datzenmike Posted September 2, 2007 Report Share Posted September 2, 2007 Roughly, the '70-'72 were 22 amp. '73-'80 were 28 amp. and 30 amp. '81-'84 were 50 and 60 amp. Two 100 watt lamps will draw 16.6 amps add the two 55 watt low beams that are on at the same time (I think) and you have 25.83 amp.s This does not include the marker, tail, and dash lights that will be on at the same time. Time to up-grade. Quote Link to comment
72 327 Posted September 3, 2007 Author Report Share Posted September 3, 2007 Well Im not too worried about the amps. LOL I have a 120 amp chevy alt. I ended up getting these lights on ebay. I love the tribar headlights. Like 120 after shipping but hell I got it why not. I think it will look sweet in my rod like datsun. Ebay link http://cgi.ebay.com/ebaymotors/5-3-4-BLACK-DOT-TRI-BAR-HOT-ROD-HEADLIGHTS-Set-of-4_W0QQcmdZViewItemQQcategoryZ33710QQihZ019QQitemZ8035102676 Quote Link to comment
datzenmike Posted September 3, 2007 Report Share Posted September 3, 2007 My first swap was a 720 60 amp unit requiring the 720 block mount and a 280Z lower hose inlet to block to make enough room for it. The idler arm grease nipple was still too close for my liking. The second one was a 90 amp Bosch from an '87 K car. I had two 200 watt 7" lamps from the airport runway lights plus the two 100 watt hi-beams plus the two 55 watt hi/low beams for just over 700 watts or about 58 amps of light. It worked great but being only human there was too much temptation to abuse their use, so I removed the 200 watters. I found that after using them, when you turn them off your eyes were so dazzled that the low beams were so faint that you would think they weren't on! Quote Link to comment
tnip Posted September 3, 2007 Report Share Posted September 3, 2007 jesus titty fucking christ that is a lot of light... Quote Link to comment
PtheDude Posted September 3, 2007 Report Share Posted September 3, 2007 ya, what were you doing with all that light, growing Pot? Quote Link to comment
spiffinspudater Posted September 3, 2007 Report Share Posted September 3, 2007 bah I was hopin they were smaller I was tempted to buy these lights till I saw what size you say I need...Head lights us truckers cant use:( Mislabled Truck Lights (too big for 510 use?) Quote Link to comment
kiznook Posted September 3, 2007 Report Share Posted September 3, 2007 spud- you can use those. 510 and 620 are the same Quote Link to comment
spiffinspudater Posted September 3, 2007 Report Share Posted September 3, 2007 spud- you can use those. 510 and 620 are the same wohoo... i want "halo" lights:P Quote Link to comment
lynchfourtwenty Posted September 3, 2007 Report Share Posted September 3, 2007 ya, what were you doing with all that light, growing Pot? cough cough Quote Link to comment
datzenmike Posted September 3, 2007 Report Share Posted September 3, 2007 ya, what were you doing with all that light, growing Pot? Melting asphalt mostly. Yeah I got rid of them. There was some construction out at the nearby military base and they were replacing the landing lights. I noticed they looked like car 7" headlights. Printed on the back was 12 volt 200 W. So I got a few and put them in a pair of Volvo pots and wired them up with relays. Each one drew almost 17 amps so had to use 10 gauge wire. Anyway it was just WAY too much for the street. I wanted more and more light and over did it I guess. Quote Link to comment
lynchfourtwenty Posted September 3, 2007 Report Share Posted September 3, 2007 im always cussing people out cause i cant see hahahaha.. cause They're lights are too bright! :P Quote Link to comment
banzai510(hainz) Posted September 4, 2007 Report Share Posted September 4, 2007 5.75 are the size . I have hellas bought from ralleylights.com I believe. Just hope those lenses are not plastic and catch on fire I have a 50 amper alternator(521 truck and I run the hella bulb 80/100 watter about 7.98$ apc. with these you wont need to use the Highs as often http://www.rallylights.com/hella/5.75_lo.asp these are the E codes and they SPEAD the light out better. Mostly spread as I said. Good quality glass.. The H4 bulds and these E codes will have a cut off so it doesnt go over i the face of oncomming driver. I would get the H4 wire harness(most are made in China but work)maybe get Hella relays later. No tofry the datsun wire and hook up at the batter /starter post just get the 80/100watt bulbs. forget the 55/60watt ones. But I dont know those lamps you bought so ck if alot of plastic on there Quote Link to comment
