lynchfourtwenty Posted January 8, 2009 Report Share Posted January 8, 2009 my trucks always kinda followed the runs an crap on the freeway an shit but lately its a little saucey... basicly she tugs both ways even when not going very fast, i mean not a jerk the wheel out of your hands kinda thing but u kinda gotta keep pressure on the wheel in opposite of the direction shes wondering.. if that makes sense.. plus on the free way it feels like shes got a shimmy or a wobble .. could this just be the Carrier bearing? i had to pry on the torsion bars a little to get the trans in and out a few times but nothin major.. think she just might need an alignment and a carrier bearing? or? Quote Link to comment
Pacific coast Datsun Posted January 8, 2009 Report Share Posted January 8, 2009 Could be a bad allignment..worn steering bushings. Check both, get the front end off the ground, grab the tire & see if it moves up & down excessively. Could also be a bad wheel bearing. Quote Link to comment
lynchfourtwenty Posted January 8, 2009 Author Report Share Posted January 8, 2009 last i knew there was no wheel play i will double check that, and would there be a sound the wheel bearing would make.. an if i recall correctly from when i did the beebani brake swap the bearings were in good condition.. you dont think tweakin the torsions a little to get the trans in an out would do anything? Quote Link to comment
Cuts metal like mad Posted January 8, 2009 Report Share Posted January 8, 2009 if the steering wheel will move back and forth with tires not moving much, you should tighten up the steering box, easy to do with the adjuster on top. This should help a little even if you can't tell there's play. Quote Link to comment
lynchfourtwenty Posted January 8, 2009 Author Report Share Posted January 8, 2009 (edited) hmm i havent thought about that... ok after some searching i cant find anything out about it so im gonna just ask is there anything special needed to adjust the steering box... and whats the procedure? Edited January 8, 2009 by lynchfourtwenty Quote Link to comment
Cuts metal like mad Posted January 8, 2009 Report Share Posted January 8, 2009 loosen the lock nut on the outside, tighten the center adjuster "bolt", tighten lock nut. This should be in the haynes, and also the fsm on 620 tech site. Quote Link to comment
yello620 Posted January 8, 2009 Report Share Posted January 8, 2009 hmm i havent thought about that... ok after some searching i cant find anything out about it so im gonna just ask is there anything special needed to adjust the steering box... and whats the procedure? Just have dwnshfter start four new threads to get your answer. Quote Link to comment
DISLEXICDIME Posted January 8, 2009 Report Share Posted January 8, 2009 I took all the old nasty crap out of my steering box and putt in hydrolic jack oil now it is easy to turn. also grease the tie rods. Quote Link to comment
lynchfourtwenty Posted January 8, 2009 Author Report Share Posted January 8, 2009 Just have dwnshfter start four new threads to get your answer. hahaha no thx I took all the old nasty crap out of my steering box and putt in hydrolic jack oil now it is easy to turn. also grease the tie rods. hmmm i will look into that Quote Link to comment
BEEBANI Posted January 8, 2009 Report Share Posted January 8, 2009 Has it been sitting for a while? Might be some flat spots in the tires. I was having the same problem after I got the front aligned, so I rotated the tires and it seemed to help a lot. Quote Link to comment
lynchfourtwenty Posted January 8, 2009 Author Report Share Posted January 8, 2009 yea its been sittin a while but my friend has been drivin it the past few days accross town an back.. i used to do construction clean up, an the dump truck tires did that... every morning for atleast the first 10 miles or so it was thump thump thump thump man that was so annoying.. but i did think about that, an it is possible i suppose.. basicly im gonna jack up the front wiggle the wheels around, adjust the streering box.. an if that doesnt help im gonna greese the tie rods an stuff.. if that dont work i will take her in for an alignment.. an when i get it fixed im gonna swap in some different fluid like mikey suggested.. wouldnt suprise me if it was sludge in there.. im think the carrier bearing may account for the slight vibration shimmy feel/sound on the freeway... Quote Link to comment
]2eDeYe Posted January 8, 2009 Report Share Posted January 8, 2009 Check your idler arm also, it's one of the first things to wear out. Nice tip about the hydraulic fluid. Quote Link to comment
volksmike Posted January 11, 2009 Report Share Posted January 11, 2009 make sure the AIR pressure is right. If they are not balanced, or too low, or even too much it will screw with the way it tracks. Quote Link to comment
volksmike Posted January 11, 2009 Report Share Posted January 11, 2009 front and BACK the rear tires can change the way the truck tracks too... Quote Link to comment
hang_510 Posted January 12, 2009 Report Share Posted January 12, 2009 Just have dwnshfter start four new threads to get your answer. :lol: i was wOndering that as i wAndered in :P Quote Link to comment
lynchfourtwenty Posted January 13, 2009 Author Report Share Posted January 13, 2009 :lol:i was wOndering that as i wAndered in :P hey i was stoned man, hence the creative name to begin with.. i could just named the thread.. my truck dont steer straight sometimes lol Quote Link to comment
sanitys Posted February 1, 2009 Report Share Posted February 1, 2009 hey i was stoned man, hence the creative name to begin with.. i could just named the thread.. my truck dont steer straight sometimes lol lynch, you adjust the steering box yet? Dude at the alignment shop told me mine was loose. Figure it was as my truck wanders as well. Just slightly tho. How much of an improvement did it make? Anyone have links for oil to replace the stock stuff in the steering box? Im sure there is supposed to be a certain weight oil in there... Gonna check the fsm Quote Link to comment
lynchfourtwenty Posted February 1, 2009 Author Report Share Posted February 1, 2009 trucks lent out so havent had a chance to doit yet Quote Link to comment
datzenmike Posted February 1, 2009 Report Share Posted February 1, 2009 (edited) Jack the front up on both sides so the wheels are free to turn. Loosen lock nut and turn screw in. (I think this reduces the gear lash) Keep in mind that most gear wear is in the middle straight ahead position and if you remove all the slop the gears may bind when turning out of the wear area. Nothing worse than making a tight turn and the steering wheel won't return!!! Make a small adjustment and then turn lock to lock with one finger looking for any tightness. Adjust as close as you can but still smooth and easy to turn. Tighten lock nut and test again. Over-tight box will only wear it out sooner. Use the same GL-4 oil used in the transmission 80 W 90 will do. Do NOT use hydraulic oil!. Who knows what lubricating properties and anti scuff additives it has to protect the gear surfaces and bearings Steve's right on about the idler arm. Pull and tug on all steering components there should be no looseness or play in any of the ball joints. Remember the steering box has a ratio of 19 to 1 so 0.052" of play will produce 1" of steering free play. There could be a small amount in several components... it all adds up. Edited February 1, 2009 by datzenmike Quote Link to comment
izzo Posted February 1, 2009 Report Share Posted February 1, 2009 does anyone have a pic of the steering box, and can tell me wich to loosen & tighten? Quote Link to comment
sanitys Posted February 1, 2009 Report Share Posted February 1, 2009 Jack the front up on both sides so the wheels are free to turn. Loosen lock nut and turn screw in. (I think this reduces the gear lash) Keep in mind that most gear wear is in the middle straight ahead position and if you remove all the slop the gears may bind when turning out of the wear area. Nothing worse than making a tight turn and the steering wheel won't return!!! Make a small adjustment and then turn lock to lock with one finger looking for any tightness. Adjust as close as you can but still smooth and easy to turn. Tighten lock nut and test again. Over-tight box will only wear it out sooner. Use the same GL-4 oil used in the transmission 80 W 90 will do. Do NOT use hydraulic oil!. Who knows what lubricating properties and anti scuff additives it has to protect the gear surfaces and bearings thanks:) Quote Link to comment
datzenmike Posted February 1, 2009 Report Share Posted February 1, 2009 (edited) does anyone have a pic of the steering box, and can tell me wich to loosen & tighten? There's only one nut with a screwdriver slot in the center. Here's another box (200sx) but you get the idea... http://i138.photobucket.com/albums/q251/datzenmike/Standardsteering80200sx.jpg[/img]"] Anyone notice this looks like a 510 box??? Edited February 1, 2009 by datzenmike Quote Link to comment
izzo Posted February 1, 2009 Report Share Posted February 1, 2009 mike, u rock i will take some pics tomorrow, thank you!! Btw, you have more pictures of datsun parts then mr heffner has of girls... Quote Link to comment
