420n620 Posted December 22, 2008 Report Share Posted December 22, 2008 I'm not a welder by trade so thats why the question. I was wondering if someone could tell me if I could weld on this tube, It looks to be made of stainless steel, can I use my wire feed wire for fixing it or could I put a copper collar/sleeve on it and soldier it to give it more strength-en in that area so this wont happen again. Quote Link to comment
datzenmike Posted December 22, 2008 Report Share Posted December 22, 2008 Solder has too low a melting temp and does not stick to SS or steel very well. Quote Link to comment
Llittle_Llama Posted December 22, 2008 Report Share Posted December 22, 2008 soldier is fail, lol Quote Link to comment
420n620 Posted December 23, 2008 Author Report Share Posted December 23, 2008 the soldier was just a thought and wood be a fail. can the tube be welded on or will I have to find another one. this is stopping me from getting the motor back into the 620.chit does anyone have a good one for sale,,, opps I guess I'll ask that on the wanted thread. thats not a fail. ha ha Quote Link to comment
racerx Posted December 23, 2008 Report Share Posted December 23, 2008 Can you cut it where it is cracked and bolt it in, if not I would try to find a replacement. Not sure about where you live and smog laws because if it leaks, it will not pass. Quote Link to comment
Llittle_Llama Posted December 23, 2008 Report Share Posted December 23, 2008 if you just need it for a few minutes to pass inspection, JB weld will hold on for a little while.... i cut mine off and put a bolt in it...... just a thought. Quote Link to comment
420n620 Posted December 23, 2008 Author Report Share Posted December 23, 2008 smog laws are not required where I live - as of yet. I just want to keep the trk stock and original as possible, its low mileage, been repainted once and not alot of bad rusted out areas. I'm going to try tomorrow and see if I can weld it up, got to get this part of the project done so I can get on the other 2 - 620's finished by summer. plus I have a pontiac motor to put together, another project that needs finished by summer. to much chit going on. Quote Link to comment
jesusno2 Posted December 23, 2008 Report Share Posted December 23, 2008 Pretty sure those egr tubes are SS I'm guessing if you try hitting it with a wire feed you'll blow it out bigger, I hope you have SS wire in your machine??. I'm not 100% but ya might be able to braze it . The best method would have someone tig weld it for you. I'd help ya out with the tig process, but I'm a long ways away Quote Link to comment
Pacific coast Datsun Posted December 23, 2008 Report Share Posted December 23, 2008 Id say tig too. Observation here...why would Datsun make that pipe so curvy? :rolleyes: Quote Link to comment
420n620 Posted December 23, 2008 Author Report Share Posted December 23, 2008 (edited) thats what I'm afraid of, blowing a bigger hole in it. I''ll look around and see if I can find someone to tig it or go to a JY and find one, what ever is the cheapest route. Thanks for ur inputs, very appreciated. curvy, I wish I knew that answer. Edited December 23, 2008 by 420n620 Quote Link to comment
banzai510(hainz) Posted December 23, 2008 Report Share Posted December 23, 2008 Weld????? JB WELB!!!!!!!!!! Is there high temp JB weld????? Quote Link to comment
datzenmike Posted December 23, 2008 Report Share Posted December 23, 2008 thats what I'm afraid of, blowing a bigger hole in it. I''ll look around and see if I can find someone to tig it or go to a JY and find one, what ever is the cheapest route. Thanks for ur inputs, very appreciated. curvy, I wish I knew that answer. It's S shaped to allow for heat expansion and it's easier to line up the ends to get the threads started. Maybe to allow the inert exhaust to cool some before it's injected into the intake. The Z engines are even longer and go around behind the head to the passenger side to the intake. I think the tubes are SS too. I've worked with SS and it turns a dull golden or straw color when heated above 700 degrees.Stainless may not rust but it's not impervious to the corrosive exhaust gasses over time. I've seen lots of 720 ones rotted along the length like an exhaust pipe. Quote Link to comment
MikeRL411 Posted December 23, 2008 Report Share Posted December 23, 2008 Have you thought of getting some stainless steel tape like JC Whitney et al sell for patching holes and taking a few turns around the cracked area and then fastening it in place with a screw type hose clamp? You could Ratsun your way thru any inspection. Quote Link to comment
420n620 Posted December 23, 2008 Author Report Share Posted December 23, 2008 I haven't thought of that but I dont want a temporary repair.. on a nauther note:: I might have located one here in the LC valley.. but as I like to say, nothing is for sure until it's in your hands. Quote Link to comment
rusty510 Posted December 23, 2008 Report Share Posted December 23, 2008 x3 JB WELD! Quote Link to comment
banzai510(hainz) Posted December 23, 2008 Report Share Posted December 23, 2008 why would Datsun make that pipe so curvy? its used to try to keep the vibration from cracking the pipe so they add curves and make it longer as a stress relief(flex) But I could be talking out my ass on this one. Keep the pipe from shearing. Quote Link to comment
