Rebello engines
Stock L20B flywheel in cars was 200mm, 225 in trucks.  You can probably use either.
The clutch bearing collar will depend on the height of the pressure plate diaphragm.
motor mounts- I don't know if truck mounting is different in the 521, but your comment should be correct.
Other comments look correct.
  • Replies 44
42 minutes ago, Socalman said:
The oil pan and oil pickup tube off the original L16  Yes
The original water pump unless the L20B already has a non-clutch pump. You can run the L20B clutch fan if there is room.
225mm Clutch and 6 bolt flywheel. You can run what ever size clutch you like even the 200mm as long as the release bearing is matched to it.
The throwout bearing collar (is this part it?)https://www.carid.com/sf-pl-mpn/pid-0-mmyid-113392-ofmpnid-4806746843.html?gad_source=1&gclid=EAIaIQobChMIwoXPg7-IhQMVDxetBh2mWw6vEAQYAiABEgLUhvD_BwE&gclsrc=aw.ds The throwout  bearing collar has to match the clutch pressure plate you select. There were several 225mm PPs, the collar for one won't match the other. Select a clutch from a specific use truck or car and get the collar for it. The one linked is for an '80 A10 HL510 and will be for a 200mm PP.
 The original L16 motor mounts. Yes the rubber isolators and the two engine brackets
If you buy a clutch kit, they almost always come with the "correct" throwout collar.
OK if you get that Fidanza flywheel thats  200mm then use the 510/521 t/O bearing and sleeve
and use this clutch kit .this is a Roadster replacement lkit (600KG) it will use same as L16 510 and 521 stuff .I personally keep the 510/521 trans thowout arm to the slave cylinder as I like the adjustment better .Exedy kit come with a 200mm T/O bearing but NO SLEEVE!!!!!!!
That $400kit looks cool but yu dont want to drive around with that strong of a clutch.  I bought a SPEC 2 for my 521 but the clutch ripped the center disc up and left me stranded. I went to the weak stock 350KG 521 kit and its fine for stock type daily driver
https://www.ebay.com/itm/233202857988?fits=Make%3ADatsun&itmmeta=01HSKYF5733MNRRKTH7PJMWETW&hash=item364bf93804:g:~JkAAOSwIetk9Q1Y&itmprp=enc%3AAQAJAAAA0OfrPf%2BVBYMIJ92RMXxqWDOtq3CDvfIDaYmM6rMJ%2FAYXVjqQ3c%2BZkGFvs4XSUxs1UmHHG8Dt4G5dixFK5RjVNGg2xGgti3B%2FRCDRGMoPuXhm4NmuMPhN1fw6OSMQ5%2B3GTgt853jfD9O5OxKWJFw6DkOyaDb8MM4Dn6XnjQTBLDKK1JWhX936J%2F5mJrTpnIpx%2FO%2B4WFzKP5sxx5ttyzB0HO1Ze7joOpfgKFX7ebFWPJfUjxyuiiJ2JM10q3VVkOwqVO43rCfEypmnHNLuEGdXRuw%3D|tkp%3ABk9SR9bTvP7MYw
400$ for a flywheel is a bit much. I found a used one
you sure yur truck weighs 1600pounds?
I went to the trash dump I swear my weight said near 2400 or 2100
Edited by banzai510(hainz)
Yes, its 1600 pounds, no front or rear bumpers, roll pan and all fiberglass front end (fenders, hood), no A/C or heating. aluminum wheels.
So basically, youre saying if I use that flywheel I posted, I can use all my existing clutch components from the 521??
also 4 wheel disk brakes, you would be surprised on the weight difference I felt during the swap, I believe my calipers are aluminum. it all adds up.
Yes your Fidanza 77-79 200sx is the same flywheel  just aluminum all other stuff from your stock L16 will work with this kit.
I will be honest. I didnt think putting a alum flywheels was all that its crackd up to be. Lucky I got a used one
well just swap the flywheel as you got everything else I guess L16 is 5 bolt L20 is 6 bolt otherwise its the same
those pressure plates(spec2) are strong but I had a stage 1 and it sheard my disc. So I wount buy another. the fingers worn in also
I stay with exedy myself.
Posted (edited)
That’s really good news/info. I like the feel of the aluminum, it revs up faster and if going downhill and off throttle it saves braking to slow down, revs down faster. One downside I don’t like is, sucks going from a stop on a hill. Lol. Hopefully it’s better with the L20b
Edited by Socalman
  • 3 months later...
i saw tankers offer
if your budget is unlimited go with the motor from tanker
YOU WILL LOVE IT
i have a 2150 Rebello in my 68 510 Dave said it dynode at 160 Dave doesn't over state or brag about horsepower from what i have seen
I also have a 3.2 Rebello in my z with modified su carbs its 241 hp but capable of closer to 300 with the right carbs
he builds great strong reliable motors and when on the throttle they sing a beautiful tune
  • Like 3
1 hour ago, Ranman72 said:
i saw tankers offer
YOU WILL LOVE IT
Your a little late he went with a single cam KA. the pinnacle of engines.
8 hours ago, Ranman72 said:
i saw tankers offer
YOU WILL LOVE IT
I bought a 2400 Rebello built engine. Z24 block with a KA head.
  • 2 weeks later...
I get that the check valve for oil filter is to bypass filter when dirty or high pressure. Reason is dirty oil is better than no oil. I don’t know why and maybe someone does is the benefit if any for plugging it up???
I bought a L20B and rebuilt it that also had the oil filter bypass plugged.  I assumed it was done to help with cleaning out the oil passages.  From what I remember the bypass is not needed because most oil filters have a built in bypass.  An OEM Nissan filter may be the exception.  I would make sure that whatever oil filter you get has the built in bypass.  I'm still learning so hopefully someone can correct me if I am wrong.
