AtomChurch Posted March 18, 2013 Report Share Posted March 18, 2013 When do we get pictures? Quote Link to comment
mklotz70 Posted March 18, 2013 Author Report Share Posted March 18, 2013 Here's a couple for now. :) 1 Quote Link to comment
AtomChurch Posted March 19, 2013 Report Share Posted March 19, 2013 Rad! That's exciting! Quote Link to comment
AtomChurch Posted March 19, 2013 Report Share Posted March 19, 2013 Also those are super clean. Ever thought about making some drop spindles? :) Quote Link to comment
mklotz70 Posted March 19, 2013 Author Report Share Posted March 19, 2013 Thanks guys :) dropped spindles? Yep....thought about it. Have it kinda figured out in my head, but I'm not sure it will ever make the project list. Quote Link to comment
mklotz70 Posted May 5, 2013 Author Report Share Posted May 5, 2013 first real progress in months! :) 2 Quote Link to comment
datsunwizard Posted August 19, 2013 Report Share Posted August 19, 2013 Mike, look into the QA-1 small body shocks, they use a 1.875" ID spring. This is what I had to use in my IRS A-arm project because of many of the same problems that you are running into. They are in the circle track catalog. I called technical at QA-1 and said that they would be fine on the street, the only problem is you can't get over 350-400 lb. spring rate because of the size of the spring. Quote Link to comment
mklotz70 Posted August 19, 2013 Author Report Share Posted August 19, 2013 Thanks for the info!! I have no plans of using coilovers, but I know there's a couple of guys following this that will appreciate that info. Do you know what the OD on the coil is? With 1/2" wire, it would be 2-5/8". That may be small enough to fit between the bumpstop mounts. I'll try to check next time I'm on it. Quote Link to comment
datsunwizard Posted August 20, 2013 Report Share Posted August 20, 2013 I will measure the OD for you, the springs aren't with me right now. Quote Link to comment
datsunwizard Posted August 22, 2013 Report Share Posted August 22, 2013 Measured the springs and they are 2 5/8" on a 280 LB spring. Quote Link to comment
Eagle_Adam Posted August 22, 2013 Report Share Posted August 22, 2013 coming along mike! Hows next weekend to work on brakes? Quote Link to comment
mklotz70 Posted August 23, 2013 Author Report Share Posted August 23, 2013 wiz....thanks for the dimension! Quote Link to comment
wayno Posted August 24, 2013 Report Share Posted August 24, 2013 Looking good Mike! :thumbup: Quote Link to comment
mklotz70 Posted August 25, 2013 Author Report Share Posted August 25, 2013 Thanks :) They're coming along slowly. Quote Link to comment
mklotz70 Posted August 25, 2013 Author Report Share Posted August 25, 2013 There will be some more vid of this later. Drew the sway bar mount in CAD. I can either make them from 2x4 rect tubing or cut/bend them from 2" x 1/8" bar. Quote Link to comment
mklotz70 Posted October 5, 2013 Author Report Share Posted October 5, 2013 There's been a few vids in between the 51 and this one. They were more specifically about creating the bending dies to make the above part. If you really want to see them, you can check my youtube channel.....link in sig. Quote Link to comment
Charlie69 Posted May 8, 2014 Report Share Posted May 8, 2014 Hey Mike any progress? Quote Link to comment
