Start over 210
  • Replies 285
toyota1515, with those wheels they will rub without spacers. But since you are getting custom wheels no problem with the right offset
Well for now i am running these wheels with 1 inch spacers cuz they will not fit the factory 210 hub and with the spacer it is about 3/4 of an inch away for it so i guess with the 280zx struts that tuck the tires in 15mm it will be about 1/4 of an inch away with the spacers on but the wheel tire combo will be the way i want it tucked it,
I was gonna cut / customize these wheels to be 5 inch wide instead of 7 and use a 135 R 15 tire but change my mind and opt to leave the wheel 7 inches and buy 195-55-15 they will be more road friendly that the others,
Just little changes we do on the fly you know!
  • 2 weeks later...
  • 4 weeks later...
OOOHHHH YEEAAAHHH!!! Seeing this makes me miss my b310 Sunny back in the Caribbean . I wish I could bring it here...u should get the jdm marker/turnsignal lights too to complete the jdm look.
  • 1 month later...
