Icehouse Posted July 6, 2022 Report Share Posted July 6, 2022 I know my Datto family spends lots of time hunting for parts. If anyone runs across a parts truck let me know. We need the 4.6 gears for our racecar. They are apparently the only low long nose R180 gears. I've only ever seen a few L series 720 4x4's so my guess is it's a rare unit. Thanks datto family! 1 Quote Link to comment
datzenmike Posted July 6, 2022 Report Share Posted July 6, 2022 Two possibilities.... 1/ The '80 720 4X4 LONG BED used an R-180 with 4.625 gears. Needed 2/ All Z24i equipped '86-'89 WD21 Pathfinders used an R-180 front differential with 4.625 gearing. The VG Pathfinders were R-200 and they never used the KA in them. From '90 on they were All VG powered. These are the only 4.625 R-180s that I know of, and it had to be geared for a puny L20B to pull a heavy loaded long bed or Z24i to pull Pathfinder around.. 1 Quote Link to comment
Icehouse Posted July 6, 2022 Author Report Share Posted July 6, 2022 4 hours ago, datzenmike said: Two possibilities.... 1/ The '80 720 4X4 LONG BED used an R-180 with 4.625 gears. Needed 2/ All Z24i equipped '86-'89 WD21 Pathfinders used an R-180 front differential with 4.625 gearing. The VG Pathfinders were R-200 and they never used the KA in them. From '90 on they were All VG powered. These are the only 4.625 R-180s that I know of, and it had to be geared for a puny L20B to pull a heavy loaded long bed or Z24i to pull Pathfinder around.. The D21 used a R180 short nose 😞 Quote Link to comment
datzenmike Posted July 6, 2022 Report Share Posted July 6, 2022 I thought the picture looked shorter. Gear set should be the same but the Pathfinder went to M11 bolts and 4 pinion. I've never seen anything but VG powered Pathfinders. Jesus the gear set is almost $700 Canadian. Quote Link to comment
thisismatt Posted July 7, 2022 Report Share Posted July 7, 2022 Gear set won't be the "same" as the pinion snoot is shorter 1 Quote Link to comment
banzai510(hainz) Posted July 7, 2022 Report Share Posted July 7, 2022 i got a r180(240z with 510 stubs it has 411 I think. But I told Dakota could have it for 100 Quote Link to comment
Icehouse Posted July 8, 2022 Author Report Share Posted July 8, 2022 On 7/6/2022 at 6:04 PM, banzai510(hainz) said: i got a r180(240z with 510 stubs it has 411 I think. But I told Dakota could have it for 100 I thought 240z had 3.5 or 3.3 gears. 1 Quote Link to comment
datzenmike Posted July 11, 2022 Report Share Posted July 11, 2022 Correct but the '84 and up CA20E in the S12 used a long nose R-180 and they were all 4.11 Quote Link to comment
banzai510(hainz) Posted July 11, 2022 Report Share Posted July 11, 2022 On 7/8/2022 at 1:10 PM, Icehouse said: 240z had 3.5 or 3.3 gears. yes but this one was changed Quote Link to comment
SLO720 Posted July 13, 2022 Report Share Posted July 13, 2022 This just popped up in my fb feed as a part out https://www.facebook.com/groups/720Owners/permalink/2250831758417816/ Quote Link to comment
thisismatt Posted July 13, 2022 Report Share Posted July 13, 2022 36 minutes ago, SLO720 said: This just popped up in my fb feed as a part out https://www.facebook.com/groups/720Owners/permalink/2250831758417816/ Have to join the group to see anything Quote Link to comment
SLO720 Posted July 14, 2022 Report Share Posted July 14, 2022 I'd say worth the join Quote Link to comment
datzenmike Posted July 14, 2022 Report Share Posted July 14, 2022 On 7/6/2022 at 3:59 PM, Icehouse said: The D21 used a R180 short nose 😞 On 7/6/2022 at 5:11 PM, thisismatt said: Gear set won't be the "same" as the pinion snoot is shorter Well if that's all that's available lengthen the driveshaft. Quote Link to comment
thisismatt Posted July 14, 2022 Report Share Posted July 14, 2022 Looks like a 2wd? Quote Link to comment
thisismatt Posted July 14, 2022 Report Share Posted July 14, 2022 Just now, datzenmike said: Well if that's all that's available lengthen the driveshaft. Short nose mount a lot differently than a long nose... Quote Link to comment
datzenmike Posted July 14, 2022 Report Share Posted July 14, 2022 That's what wire feed wrenches are for. Quote Link to comment
620slodat Posted July 14, 2022 Report Share Posted July 14, 2022 2 hours ago, SLO720 said: Where is the 720 located? I could use the bed if it is a standard bed, and shipping and condition is not too bad. Pics are rather small, and I'm not able to get them any bigger. So, the condition can't be checked. Don Quote Link to comment
SLO720 Posted July 14, 2022 Report Share Posted July 14, 2022 (edited) Looks like seller was located out of Idaho. It's definitely 4x4 with transfer case shifter in cab and manual hubs upfront. Have to join fb group to message seller, but link is there to specific post @620slodat @Icehouse https://www.facebook.com/groups/720Owners/permalink/2250831758417816/ Edited July 14, 2022 by SLO720 Quote Link to comment
NC85ST Posted July 14, 2022 Report Share Posted July 14, 2022 I’m pretty sure that’s a long bed. Look at the length between the back of the cab and the front of the rear wheel. Quote Link to comment
datzenmike Posted July 14, 2022 Report Share Posted July 14, 2022 That's a regular cab long wheelbase truck with the 'long box'. There were also regular cab short wheelbase trucks having the same cab but shorter box on the back. The king cab is also on a long wheelbase frame but with an extended cab and using the short wheelbase box. The difference between a long and short box is about the difference between a regular cab and a king cab about 9.4" Quote Link to comment
