Bandit240 Posted December 9, 2008 Report Share Posted December 9, 2008 Ive been working on fixing some dents in my bed. The only way to fix them would end up covering the seams, so i said the hell with it and went for it. Ive got the drivers side about 90% done. If youve been following my build thread in the project section you would see this. I think it looks good with smooth sides. Quote Link to comment
Pacific coast Datsun Posted December 9, 2008 Report Share Posted December 9, 2008 Thats a much cleaner look for the bedsides. Good work. Quote Link to comment
datsunfish Posted December 9, 2008 Report Share Posted December 9, 2008 Did you weld the seams shut? If not it is likely they will crack out. My friend used body filler on his and they cracked out before he ever got it on the road so he eventually welded it. They are two entirely different pieces that will flex and twist as you go down the road. You might be able to get away with it if you used stranded body filler such as long n strong or fiber fill. Looks good so far though. Quote Link to comment
slodat Posted December 9, 2008 Report Share Posted December 9, 2008 Did you fill them with straight bondo? No welding? What's to prevent that thick bondo from falling off in a big chunk? Quote Link to comment
datzenmike Posted December 9, 2008 Report Share Posted December 9, 2008 If/when I do mine I plan to weld them closed. Quote Link to comment
Bandit240 Posted December 9, 2008 Author Report Share Posted December 9, 2008 I sanded it down to bare metel and used bondo. I cant weld worth shit. Im going to be working a flatbed soon anyway. Quote Link to comment
1lo620 Posted December 9, 2008 Report Share Posted December 9, 2008 I am afraid that they are going to crack out sooner or later....But it looks good for now.... Quote Link to comment
datzenmike Posted December 9, 2008 Report Share Posted December 9, 2008 That daylight I see? If there is nothing behind to keep the bondo dry it will suck up water and .... You could try taring the inside to try and seal it. Quote Link to comment
datsunfish Posted December 9, 2008 Report Share Posted December 9, 2008 (edited) Yeah,you are gonna have some issues with that. You really need to at least have some sort of a backer or fibrous structure for that. Welding is the only real solution but You could back it out with fiberglass matt and coat it heavy so its protected. Make sure to finish the outside asap and get it painted so its protected too. Just thought of this. Since its not too high you could lay some 1.5" angle aluminum behind the holes,mounted to the bed floor(glue,epoxy,glass?)Goop around that for backing support...maybe Edited December 9, 2008 by datsunfish Quote Link to comment
Bandit240 Posted December 9, 2008 Author Report Share Posted December 9, 2008 Im going to epoxy coat the back side of the bondo. Im also making an inner wall for the bed of the truck to prevent anymore dents from the inside out. Quote Link to comment
Llittle_Llama Posted December 9, 2008 Report Share Posted December 9, 2008 looks good, but because of the cracking, im welding mine also. Quote Link to comment
datsunfish Posted December 9, 2008 Report Share Posted December 9, 2008 Im going to epoxy coat the back side of the bondo. Im also making an inner wall for the bed of the truck to prevent anymore dents from the inside out. Make sure your surface is completely clean and roughed up. Epoxy will not adhere well to glossy paint. Also,if you do inner bed walls do not seal them up. Make them easily removeable if possible. The reason is that moisture will collect with nowhere to go if sealed off. Debris will collect with openings. Doing inner walls does allow you to batter up the bondo. Quote Link to comment
Bandit240 Posted December 9, 2008 Author Report Share Posted December 9, 2008 The inner walls are just going to be wood slats. Quote Link to comment
rat tail dragger Posted December 9, 2008 Report Share Posted December 9, 2008 well the bondo will last for about a month or to ,my lower rear qtrs cracked out so i have to strip the crack and weld them smooth then fill them in but i think im going to grind the seams out and then use a small skimer of seam sealer and keep the seam but not as intense all that make sense hahah i was checkin for myself hahah Quote Link to comment
dat620 Posted December 9, 2008 Report Share Posted December 9, 2008 yep, welded mine, all over the truck, smooth as babies butt, now just need to finish body and paint, yea some vibration and she is all cracked up if not welded, or a little water and also all cracked up, welded is best way to go..:D Quote Link to comment
nisrod720 Posted December 9, 2008 Report Share Posted December 9, 2008 just wind turbulence will crack it pretty soon,,i welded the ones on my 720 also(the second time!!) Quote Link to comment
Guest DatsuNoob Posted December 10, 2008 Report Share Posted December 10, 2008 I'm gonna scrap my welded bed. It's just beat, and I'm tired of trying to get it back to half way fair. On the next one, I thought about using Marglass instead of welding to prevent warping. Marglass is very tough, and guys in the autobody world use this stuff all the time for filling seams, and dents around 1/4" or so. Who knows, I might weld the next one anyway, I'll just need to stitch it down more frequent prior to filling, so it wont warp this time. Quote Link to comment
Jekyl.Hyde.Kustoms Posted January 18, 2009 Report Share Posted January 18, 2009 I'm gonna scrap my welded bed. It's just beat, and I'm tired of trying to get it back to half way fair. On the next one, I thought about using Marglass instead of welding to prevent warping. Marglass is very tough, and guys in the autobody world use this stuff all the time for filling seams, and dents around 1/4" or so. Who knows, I might weld the next one anyway, I'll just need to stitch it down more frequent prior to filling, so it wont warp this time. If you are going to a body shop that is flling 1/4" dents, you should definitely turn around and leave. That's just being lazy, dents should be pulled to as close as possible, and any seam or hole that is going to be smoothed, absolutley should be welded. Anything else will not last whatsoever. As for warpage, you have to weld in small spurts, 3/4" at a time, and skip around so that the heat doesn't build up. Take your time and it will turn out fine and you will be happier in the end. Quote Link to comment
Guest DatsuNoob Posted January 18, 2009 Report Share Posted January 18, 2009 My bed is just plain beat. I'll be looking for a new one very soon. I think I'm going to use it as a practice for learning how to roll a fender. What I was saying about Marglass is that it can be used for filling seams without having to weld them. It's much stronger than most body fillers, and can handle the job without cracking. I stich welded my seams, and they still warped, so maybe just a spot weld at a time and a wet towel for the next one Quote Link to comment
Figbuck Posted January 18, 2009 Report Share Posted January 18, 2009 I used a little propane or MAPP gas torch to solder the seams in the front fenders. But they didn't work for the bed because it was just too big of a heat sink. I used an acetylene torch that I have for plumbing work and big bars of 50/50 solder I get at the sheet metal/HVAC supply house. I had to use a small amount of tinner's fluid after I scarfed out the joint of all paint and crap to get it to stick. It took me a minute to get the feel for how hot to get the metal, but I got it to flow out well and fill the joint pretty fast. I didn't have to grind like with a wire feed, just sand it with a little pneumatic disc. I acid washed the bare metal and used a metal conditioner to neutralize the flux and acid wash. I used virtually no bondo. So far, after a year and a half of pounding over the three nasty speed bumps on my street no cracks. :) Quote Link to comment
slayer Posted January 19, 2009 Report Share Posted January 19, 2009 i have used this before to patch hole in the floor but i wonder if it would work to smooth out the bed Quote Link to comment
78kingcab Posted January 19, 2009 Report Share Posted January 19, 2009 hey guys im a newbe to the ratsun but not a newbe to shaving bed seams you got to weld them up. trust me they will come back if you dont Quote Link to comment
Guest DatsuNoob Posted January 20, 2009 Report Share Posted January 20, 2009 i have used this before to patch hole in the floor but i wonder if it would work to smooth out the bed Yeah... I'll bet that stuff will work. It's the same stuff dwnshifter uses to weld together c-notches and his four link so it must be good.:lol: Quote Link to comment
