Bryant Posted March 27, 2022 Report Share Posted March 27, 2022 I am considering a real axle swap for my 1970 Datsun 521. What would be good options to pair with the KA24 and 5speed? Any info would help Quote Link to comment
carterb Posted March 27, 2022 Report Share Posted March 27, 2022 I had a Mazda RX7 rear axle with disk brakes and LSD built for my 620. John Wallum in OR made it for me. 2 Quote Link to comment
datzenmike Posted March 27, 2022 Report Share Posted March 27, 2022 There's nothing wrong with the H-190 that's in your truck. It's good for 280 ft lbs of torque, more than strong enough for a KA. Gearing is a little low at 4.375 but there are plenty of ratios available from later trucks. Maybe a 3.70 or 3.889 from a 720 truck? The differentials are a bolt in third member and easy enough to swap. It's not like the KA makes so much power you spin the tires in every gear that you would need an LSD. As far as brakes, the 10" drums will stop you just as well as disc, it's just that disc are way less maintenance. 2 Quote Link to comment
thisismatt Posted March 27, 2022 Report Share Posted March 27, 2022 Keeping it 6 lug, an early 79-84(?) 4wd Toyota axle will get you way more LSD & gear options, but no good disc brake options from what I've found. 1 Quote Link to comment
Bryant Posted March 27, 2022 Author Report Share Posted March 27, 2022 Datzmike yeah I agree I don’t necessarily need to upgrade for the power that the KA will be putting out but I don’t want to deal with drums brakes and so far I have had a really hard time finding any parts in general for that rear axle. Quote Link to comment
Stoffregen Motorsports Posted March 27, 2022 Report Share Posted March 27, 2022 X2 on the Toyota axles. 4x4 truck axles have the six lug bolt pattern and the 8" diffs are very strong with tons of aftermarket support. Gearsets are $225, bearing kits $100, LSD units $650. Try that with a Nissan diff. It will be three times the cost if you can even find those parts. Quote Link to comment
datzenmike Posted March 27, 2022 Report Share Posted March 27, 2022 2 hours ago, Bryant said: Datzmike yeah I agree I don’t necessarily need to upgrade for the power that the KA will be putting out but I don’t want to deal with drums brakes and so far I have had a really hard time finding any parts in general for that rear axle. The Toyota axle is a bit wider. The Isuzu Trooper rear caliper and 6 bolt rotor can be fitted by making caliper mounts for the axles. 1 Quote Link to comment
greenthumb Posted March 28, 2022 Report Share Posted March 28, 2022 There is another way. I used a Honda Passport axle. Factory LSD with disc brakes and internal e brake which is adapatable to the 521 linkage. Ratio is 4.30. The early Passports were built with cooperation from Isuzu. Turns out they used a Dana 44. It’s not a boltin however. I had to shorten and respline my axles, but the win of factory discs was worth it to me along with a properly functional e brake 2 Quote Link to comment
greenthumb Posted March 28, 2022 Report Share Posted March 28, 2022 Also 6 lug 2 Quote Link to comment
Stoffregen Motorsports Posted March 28, 2022 Report Share Posted March 28, 2022 Narrowing an axle is not a bad way to go. The early Toyota 4x4 pickup axles were 55." wide. How wide are the 320, 521, 620 axles? 1 Quote Link to comment
Stoffregen Motorsports Posted March 28, 2022 Report Share Posted March 28, 2022 Oh yeah, and Toyota drum brakes work awesome. No need to upgrade to discs. Quote Link to comment
Stoffregen Motorsports Posted March 28, 2022 Report Share Posted March 28, 2022 Also - disc vs disk. Brakes are disc. Floppy drives are disk. Quote Link to comment
thisismatt Posted March 28, 2022 Report Share Posted March 28, 2022 20 minutes ago, Stoffregen Motorsports said: Narrowing an axle is not a bad way to go. The early Toyota 4x4 pickup axles were 55." wide. How wide are the 320, 521, 620 axles? 521, according to internet/ratsun sources, is... 53" 52-7/8" 52-9/16" 2 Quote Link to comment
Stoffregen Motorsports Posted March 28, 2022 Report Share Posted March 28, 2022 So an inch per side. Nobody would ever notice. Quote Link to comment
thisismatt Posted March 28, 2022 Report Share Posted March 28, 2022 3 hours ago, Stoffregen Motorsports said: So an inch per side. Nobody would ever notice. Yep, and I need that inch for my rays/nismo wheels 👍 1 Quote Link to comment
gene knight Posted April 7, 2022 Report Share Posted April 7, 2022 On 3/27/2022 at 6:53 PM, greenthumb said: There is another way. I used a Honda Passport axle. Factory LSD with disc brakes and internal e brake which is adapatable to the 521 linkage. Ratio is 4.30. The early Passports were built with cooperation from Isuzu. Turns out they used a Dana 44. It’s not a boltin however. I had to shorten and respline my axles, but the win of factory discs was worth it to me along with a properly functional e brake what year of passport? how much did you have to shorten the axles? did you use honda axles or datsun axles Quote Link to comment
greenthumb Posted April 8, 2022 Report Share Posted April 8, 2022 Not exactly sure what year. It would have been one of the earliest years when they were built with cooperation and parts from Isuzu. I removed the Honda axles and had Dutchman shorten and respline them. I can’t recall exactly how much we narrowed it. Maybe 1 1/2” -2” on each side? 1 Quote Link to comment
Oilspot Posted April 10, 2022 Report Share Posted April 10, 2022 So on the Toyota 4x4 rear end swap..... I've got a 83' Toyota 4x4 parts truck. That would be a 4.10 r&p which would be a great mild improvement from the stock 4.375 with my stock L16. Things I'd have to address.... Standard to metric on the brake lines, but I could do that at the rear T easy enough. As far as drive shaft issues? Anybody happen to know the difference in third member snout lengths??? If the Toyota unit is longer I can get the stock Datsun driveshaft shortened locally easy enough. If it's shorter I'm looking at a bit more of a problem. Quote Link to comment
datzenmike Posted April 10, 2022 Report Share Posted April 10, 2022 Mild improvement??? Depends what you want. 4:10 will have less torque multiplication in all gears. Engine RPMs will be slightly lower at all speeds and all gears, not much and an L16 should be able to handle it. I should imagine Toyotas use metric too. Quote Link to comment
Oilspot Posted April 10, 2022 Report Share Posted April 10, 2022 (edited) 10 minutes ago, datzenmike said: Mild improvement??? Depends what you want. 4:10 will have less torque multiplication in all gears. Engine RPMs will be slightly lower at all speeds and all gears, not much and an L16 should be able to handle it. I should imagine Toyotas use metric too. Isn't 521 sae!?!? Trucks got more than enough torque for a little truck!!! The 4.10 would give me +4mph at 4000 in 4th gear. I feel like I just said 4 way to many times in a sentence! Edited April 10, 2022 by Oilspot Quote Link to comment
Stoffregen Motorsports Posted April 14, 2022 Report Share Posted April 14, 2022 I always thought the 521 was the introduction to metric. Maybe I'm wrong. The diff lengths are similar. You do understand it is vital to get accurate measurements, right? If the shaft is too long, it can damage the trans, diff or both. If the shaft is too short, it can slip out and cause a very bad day. Quote Link to comment
greenthumb Posted April 14, 2022 Report Share Posted April 14, 2022 Mechanically they are metric. All the body fasteners are SAE NF 1 Quote Link to comment
Oilspot Posted April 14, 2022 Report Share Posted April 14, 2022 2 hours ago, Stoffregen Motorsports said: I always thought the 521 was the introduction to metric. Maybe I'm wrong. The diff lengths are similar. You do understand it is vital to get accurate measurements, right? If the shaft is too long, it can damage the trans, diff or both. If the shaft is too short, it can slip out and cause a very bad day. A lot on the 521 is SAE!!! I've had to have a driveshaft shortened so Ill get the length in spec. Thank you for looking out though!!!!! 1 Quote Link to comment
the510 Posted May 14, 2023 Report Share Posted May 14, 2023 Anyone have John Wallums contact info? Quote Link to comment
mainer311 Posted May 14, 2023 Report Share Posted May 14, 2023 (edited) DP and I just did disc brake conversions on the stock rear axle, so I’m not sure what this “can’t find parts” business is about. Edited May 14, 2023 by mainer311 Quote Link to comment
