bilzbobaggins Posted December 10, 2020 Report Share Posted December 10, 2020 5 minutes ago, Toneloc521 said: Should I replace the vacuum advance? is it bad? Quote Link to comment
Toneloc521 Posted December 10, 2020 Author Report Share Posted December 10, 2020 4 minutes ago, bilzbobaggins said: is it bad? I’m not sure honestly Quote Link to comment
Toneloc521 Posted December 10, 2020 Author Report Share Posted December 10, 2020 Also if my timing is off and Am I gonna wanna adjust the points in the distributor will that help with my timing? Quote Link to comment
Toneloc521 Posted December 10, 2020 Author Report Share Posted December 10, 2020 (edited) Edited December 10, 2020 by Toneloc521 Quote Link to comment
Toneloc521 Posted December 10, 2020 Author Report Share Posted December 10, 2020 Quote Link to comment
mainer311 Posted December 10, 2020 Report Share Posted December 10, 2020 That throttle return spring setup is special. You should set the timing at idle with the vacuum advance disconnected. The vacuum timing only comes into play at cruising speeds at part throttle. It advances the timing about 5 degrees to help with efficiency when you're holding a steady speed. At low speeds and wide open throttle, there isn't enough vacuum to get it to actuate, so it doesn't do anything during those conditions. 1 Quote Link to comment
Toneloc521 Posted December 10, 2020 Author Report Share Posted December 10, 2020 1 Quote Link to comment
Toneloc521 Posted December 10, 2020 Author Report Share Posted December 10, 2020 2 Quote Link to comment
bilzbobaggins Posted December 10, 2020 Report Share Posted December 10, 2020 you would apply vacuum/suck on the nipple to the advance canister and watch for the breaker plate in the distributor to rotate slightly. If you apply vacuum and it leaks off, the diaphragm would be bad. If the plate does not move, it might be stuck in place. 2 Quote Link to comment
datzenmike Posted December 10, 2020 Report Share Posted December 10, 2020 1 hour ago, Toneloc521 said: Should I replace the vacuum advance? Take the vacuum advance hose off and suck on the end while watching the rotor with the cap off. It should turn clockwise about an inch??? whatever. Hold the vacuum with your tongue over the end. The rotor should not return until you release the vacuum. If you have this it can be assumed that the vacuum advance is working. This is an absolutely terrible return spring set up. The spring should be in line with the throttle cable pull and should be no larger (stiffer) than needed to return the throttle plate to idle. Anything else will gring the throttle plate bushings away. 57 minutes ago, mainer311 said: That throttle return spring setup is special. You should set the timing at idle with the vacuum advance disconnected. The vacuum timing only comes into play at cruising speeds at part throttle. It advances the timing about 5 degrees to help with efficiency when you're holding a steady speed. At low speeds and wide open throttle, there isn't enough vacuum to get it to actuate, so it doesn't do anything during those conditions. Vacuum advance is ported above the throttle plate so if the idle is set properly, and it should be so that centrifugal advance is not messing your timing settings, there will be NO vacuum advance. Idle for the 521 is 600-650. Not sure when centrifugal advance starts so set not much higher than 750. All carburetors since the late '60s use ported vacuum advance for emissions purposes. Once timing is set, connect or disconnect the hose and there should be no change in timing either way. Above idle the throttle plate lifts up to the vacuum advance port above it and begins sending a vacuum signal to the distributor. There are 9 to 11 degrees advance @ 14.5 to 16.5 inches of mercury vacuum on a '71 distributor. Vacuum advance is load dependent. The more you step on the gas the less there the vacuum signal, the less the advance. 2 Quote Link to comment
Toneloc521 Posted December 11, 2020 Author Report Share Posted December 11, 2020 (edited) 8 hours ago, datzenmike said: Take the vacuum advance hose off and suck on the end while watching the rotor with the cap off. It should turn clockwise about an inch??? whatever. Hold the vacuum with your tongue over the end. The rotor should not return until you release the vacuum. If you have this it can be assumed that the vacuum advance is working. This is an absolutely terrible return spring set up. The spring should be in line with the throttle cable pull and should be no larger (stiffer) than needed to return the throttle plate to idle. Anything else will gring the throttle plate bushings away. Vacuum advance is ported above the throttle plate so if the idle is set properly, and it should be so that centrifugal advance is not messing your timing settings, there will be NO vacuum advance. Idle for the 521 is 600-650. Not sure when centrifugal advance starts so set not much higher than 750. All carburetors since the late '60s use ported vacuum advance for emissions purposes. Once timing is set, connect or disconnect the hose and there should be no change in timing either way. Above idle the throttle plate lifts up to the vacuum advance port above it and begins sending a vacuum signal to the distributor. There are 9 to 11 degrees advance @ 14.5 to 16.5 inches of mercury vacuum on a '71 distributor. Vacuum advance is load dependent. The more you step on the gas the less there the vacuum signal, the less the advance. So going back to the throttle spring are we talking the small one hooked up to the throttle or the black bigger spring? The black one hooked up there has an arm on it but it is stiff Edited December 11, 2020 by Toneloc521 2 Quote Link to comment
mainer311 Posted December 11, 2020 Report Share Posted December 11, 2020 Yes, the black one needs to go away. If the small silver spring is not strong enough, you can always trim some of it off, and then bend the last loop so that you can put it back on the screw. 2 Quote Link to comment
banzai510(hainz) Posted December 11, 2020 Report Share Posted December 11, 2020 (edited) we almost need to start over whats the proplem???? NOW you have 2 set of points and hopefully you put the correct wire back in the orginal spots. I thought the bIG condenser is the main points and should be a blk red wire and the 2nd condenser is blk yel or yel black. I MIGHT BE WRONG ON THIS but that what I had when I had 2 set of points. YOUR PHOTO show the blk/yel on the main set of points and a BLUE wire on the 2nd set of points. WHER does this BLUE wire go????????? Maybe you got them reversed BUT maybe that was my 510 colors, Cause I see the dist CLOCKED HARD to one side on the timming plate also anyway you only need 1 set(with the bigger condenser) to run the truck anyways I never used the second set and didn't use the blk/yellow wire. I switch to a Pertronix ignition and don't use any of those now. You GAP the points???????? if there is NO SPARK Since this is a weber carb did you cycle the gas linkage and see if gas is squirting in there?????????? If not then you don't have fuel in the carb You poull the center coil wire from the dist cap and place near ground like a bolt asnd see if it spark when you trying to start the truck? IF Yes then your fine. If not then you got a point issue or no power to the coil or a HOT start issue a BAD vacuum advance is not going to cause a NO START this is a SIMPLE FIX Edited December 11, 2020 by banzai510(hainz) 2 Quote Link to comment
Toneloc521 Posted December 12, 2020 Author Report Share Posted December 12, 2020 (edited) 8 hours ago, banzai510(hainz) said: we almost need to start over whats the proplem???? NOW you have 2 set of points and hopefully you put the correct wire back in the orginal spots. I thought the bIG condenser is the main points and should be a blk red wire and the 2nd condenser is blk yel or yel black. I MIGHT BE WRONG ON THIS but that what I had when I had 2 set of points. YOUR PHOTO show the blk/yel on the main set of points and a BLUE wire on the 2nd set of points. WHER does this BLUE wire go????????? Maybe you got them reversed BUT maybe that was my 510 colors, Cause I see the dist CLOCKED HARD to one side on the timming plate also anyway you only need 1 set(with the bigger condenser) to run the truck anyways I never used the second set and didn't use the blk/yellow wire. I switch to a Pertronix ignition and don't use any of those now. You GAP the points???????? if there is NO SPARK Since this is a weber carb did you cycle the gas linkage and see if gas is squirting in there?????????? If not then you don't have fuel in the carb You poull the center coil wire from the dist cap and place near ground like a bolt asnd see if it spark when you trying to start the truck? IF Yes then your fine. If not then you got a point issue or no power to the coil or a HOT start issue a BAD vacuum advance is not going to cause a NO START this is a SIMPLE FIX You talking about this wire? If so this wire goes now where literally just hanging out there i am doing the work this weekend Edited December 12, 2020 by Toneloc521 Quote Link to comment
