mainer311 Posted December 21, 2020 Report Share Posted December 21, 2020 50 minutes ago, banzai510(hainz) said: read the instruction on how to adjust a weber DGV or you tube. once I get the motor running enough I adjust the mixture screw at the base of the case IN/Out till it runs the best adjust the speed screw also , some the screw wont even touch the lever some maybe a half to a full turn should be more than enoughh I believe the throttle stop screw needs to hold the butterfly open just a tiny amount, or air won't pass the butterflies at all. It basically needs to be cracked open, but still cover the lowest transition hole. 1 Quote Link to comment
Stoffregen Motorsports Posted December 21, 2020 Report Share Posted December 21, 2020 3 minutes ago, mainer311 said: I believe the throttle stop screw needs to hold the butterfly open just a tiny amount, or air won't pass the butterflies at all. It basically needs to be cracked open, but still cover the lowest transition hole. This and the timing work together to get the idle smooth. If the timing is wrong, and the idle is set high, it will sound ok, but still run like shit. Also, if the idle is too high, the engine will diesel on shut down. Webers have an anti-dieseling solenoid (at least some do) and if this is not connected, the car may not run at all. 2 Quote Link to comment
