Toneloc521 Posted December 4, 2020 Report Share Posted December 4, 2020 My name is Anthony I recently bought a 71 521 it ran great but now I can’t seem to get it to start, it try’s and try’s but doesn’t fully start. I am not sure where to start I have been doing a ton of research. It will turn over if I choke it but won’t idle for more then a minute any advice would be appreciated if more info is needed I can provide it and also photos 2 Quote Link to comment
KELMO Posted December 4, 2020 Report Share Posted December 4, 2020 Is the carb getting fuel? I am going to assume you have spark since it will idle for at least a minute. What motor is in this truck? 2 Quote Link to comment
mainer311 Posted December 4, 2020 Report Share Posted December 4, 2020 Clogged fuel filter? Plugged up needle on the fuel bowl? If you just bought it, was it sitting for a while prior to you buying it? Is it the stock L16? And what carb is on it? 2 Quote Link to comment
DanielC Posted December 4, 2020 Report Share Posted December 4, 2020 Compression, ignition, fuel. These three things are needed for an engine to run. If your engine has these three things in the right amount, your engine will run. Millions of engines prove that every day. Check the compression. For a L16, 159 PSI is the lower limit from the factory. The engine may run with less, but with more difficulty. Ignition timing factory setting is 10 degrees BTDC, 12 degrees may help. Spark should be strong, a fat blue one. New spark plugs will help, NGK BP6ES. Beware of imitation plugs on Ebay. Old gasoline will cause problems. Your gas tank could also have dirt or water in it. That will cause problems. Check the three things, report back, give details as you find them. 3 Quote Link to comment
Toneloc521 Posted December 4, 2020 Author Report Share Posted December 4, 2020 3 hours ago, KELMO said: Is the carb getting fuel? I am going to assume you have spark since it will idle for at least a minute. What motor is in this truck? It’s L16 and I believe so cause when I try to start it she smells like gas 2 Quote Link to comment
Toneloc521 Posted December 4, 2020 Author Report Share Posted December 4, 2020 2 hours ago, mainer311 said: Clogged fuel filter? Plugged up needle on the fuel bowl? If you just bought it, was it sitting for a while prior to you buying it? Is it the stock L16? And what carb is on it? It’s an L16 and I believe so it’s only has 81000 miles so I think it sat for a while I’m gonna changed the fuel filters then if all else fails replace my ignition system from the switch to the coil and maybe my points distributor cap and rotor I am not sure tho 2 Quote Link to comment
Toneloc521 Posted December 4, 2020 Author Report Share Posted December 4, 2020 2 hours ago, DanielC said: Compression, ignition, fuel. These three things are needed for an engine to run. If your engine has these three things in the right amount, your engine will run. Millions of engines prove that every day. Check the compression. For a L16, 159 PSI is the lower limit from the factory. The engine may run with less, but with more difficulty. Ignition timing factory setting is 10 degrees BTDC, 12 degrees may help. Spark should be strong, a fat blue one. New spark plugs will help, NGK BP6ES. Beware of imitation plugs on Ebay. Old gasoline will cause problems. Your gas tank could also have dirt or water in it. That will cause problems. Check the three things, report back, give details as you find them. I will definitely check it out I appreciate the advice and will let you know how it turns out 2 Quote Link to comment
datzenmike Posted December 4, 2020 Report Share Posted December 4, 2020 It will only run well when everything is set well. I would start with a good tune up to stock specs. This will eliminate some of the guess work, might even remove a problem you haven't even gotten to yet. If it was running great then all that's really changed is the cooler/cold weather.... Seems like you have a problem with a cold start. This is what the choke is for. An engine has to evaporate the gas to a vapor for it to burn and this is not a problem when the engine is warm or it's warm out. When cold the choke forces an over rich condition to assure that enough gas turns to vapor so the engine will run. The choke should remain on for up to 10 min depending on the outside temperature and you can decrease it as it warms up. To start with the choke depress the throttle twice and hold, then pull the choke out and release the throttle. This is needed to be done to set the fast idle. I would pull and check the plugs and if worn out replace them as part of your tune up. Running and starting with the choke will leave a lot of unburned carbon on them, maybe even wetness. Otherwise clean them. Visually inspect the plug wires. They should be clean and undamaged or replace them. Same with the distributor cap and rotor. 3 Quote Link to comment
Charlie69 Posted December 4, 2020 Report Share Posted December 4, 2020 (edited) If this is a points distributor it sounds like a fuel problem plus the points condenser might need changing. Bad condenser will start but not stay running. What distributor and carb do you have? ls it a mechanical or electric fuel pump? Edited December 5, 2020 by Charlie69 1 Quote Link to comment
wayno Posted December 4, 2020 Report Share Posted December 4, 2020 11 hours ago, Toneloc521 said: My name is Anthony I recently bought a 71 521 it ran great but now I can’t seem to get it to start, it try’s and try’s but doesn’t fully start. I am not sure where to start I have been doing a ton of research. It will turn over if I choke it but won’t idle for more then a minute any advice would be appreciated if more info is needed I can provide it and also photos Hi there Toneloc521 You said it ran great and then it would not start, how long did it sit without being started after the last time you drove it? 2 Quote Link to comment
banzai510(hainz) Posted December 4, 2020 Report Share Posted December 4, 2020 this is a simple fix. runs with choke or pushing the the gas???? if yes then the idle and main jet might be plugged does it squirt gas when you push the gas (cycle it) look in carb if yes then its getting gas then look for NO spark at the center coil wire , place near ground then try to start see if you get spark. Maybe ballast wire fell off. or at the coil wire fell off 2 Quote Link to comment
mainer311 Posted December 4, 2020 Report Share Posted December 4, 2020 2 hours ago, banzai510(hainz) said: does it squirt gas when you push the gas (cycle it) look in carb if yes then its getting gas The accelerator pickup is at the bottom. Just because the accelerator pump is squirting gas doesn't mean the bowl isn't running out or very low. Low bowl = low level in the nozzles. Harder for the venturis to pick up any gas. 2 Quote Link to comment
datzenmike Posted December 4, 2020 Report Share Posted December 4, 2020 2 hours ago, banzai510(hainz) said: this is a simple fix. runs with choke or pushing the the gas???? if yes then the idle and main jet might be plugged does it squirt gas when you push the gas (cycle it) look in carb if yes then its getting gas then look for NO spark at the center coil wire , place near ground then try to start see if you get spark. Maybe ballast wire fell off. or at the coil wire fell off It's a check that it's getting gas although on the older Hitachi carbs there is a large window on the front and a white level line which is easier to check. You can't set the fast idle simply by pulling the choke to on. You have to step on the gas and hold while pulling the choke on, or after. Without fast idle set it will flood and quit. 2 Quote Link to comment
banzai510(hainz) Posted December 4, 2020 Report Share Posted December 4, 2020 1 hour ago, mainer311 said: The accelerator pickup is at the bottom. Just because the accelerator pump is squirting gas doesn't mean the bowl isn't running out or very low. Low bowl = low level in the nozzles. Harder for the venturis to pick up any gas. I always think weber DGV as its on the side, the diaphrame most Hitachi's are gone by now 2 Quote Link to comment
mainer311 Posted December 5, 2020 Report Share Posted December 5, 2020 1 hour ago, banzai510(hainz) said: I always think weber DGV as its on the side, the diaphrame most Hitachi's are gone by now yeah, they were made out of leather! 2 Quote Link to comment
datzenmike Posted December 5, 2020 Report Share Posted December 5, 2020 I heard specifically they were made out of kangaroo hide. Can't find the leather ones any more... all neoprene now. 2 Quote Link to comment
Toneloc521 Posted December 5, 2020 Author Report Share Posted December 5, 2020 9 hours ago, wayno said: Hi there Toneloc521 You said it ran great and then it would not start, how long did it sit without being started after the last time you drove it? Like four days Max 2 Quote Link to comment
Toneloc521 Posted December 5, 2020 Author Report Share Posted December 5, 2020 7 hours ago, banzai510(hainz) said: this is a simple fix. runs with choke or pushing the the gas???? if yes then the idle and main jet might be plugged does it squirt gas when you push the gas (cycle it) look in carb if yes then its getting gas then look for NO spark at the center coil wire , place near ground then try to start see if you get spark. Maybe ballast wire fell off. or at the coil wire fell off Yea it did like when I was I traffic I’d have to rev my engine to keep a float 2 Quote Link to comment
datzenmike Posted December 5, 2020 Report Share Posted December 5, 2020 20 minutes ago, Toneloc521 said: Yea it did like when I was I traffic I’d have to rev my engine to keep a float Was the engine warmed up fully? Was the choke shut off? If yes... Turn the idle speed screw up. 2 Quote Link to comment
Toneloc521 Posted December 5, 2020 Author Report Share Posted December 5, 2020 14 hours ago, datzenmike said: Was the engine warmed up fully? Was the choke shut off? If yes... Turn the idle speed screw up. It might not have been, the Weber carb on it is a DGAV but they swapped the choke out with a electrical choke and the wire connection piece on the choke isn’t connected to anything. My dad has a shop I took it to and we turned up the idle so it wouldn’t die in traffic r when I stopped but I mean it still had problems like on the way home I was driving and I would shift into 3rd or 4 th gear and try to accelerate and it wouldn’t make any noise nor engage then I’d pump the gas a bit and eventually it would catch and accelerate we flushed it with carb cleaner and it Miss fired a few times while high revving 2 Quote Link to comment
datzenmike Posted December 5, 2020 Report Share Posted December 5, 2020 See, we all assumed you had a stock carburetor because you didn't say anything about a Weber. Anything else that's not original??? So electric choke that never shuts off????? Get a switched supply of battery to the electric choke and this will solve most of your problems. Clean the plugs or new NGK B6ES or BP6ES... they are probably balls of carbon by now. 2 Quote Link to comment
mainer311 Posted December 6, 2020 Report Share Posted December 6, 2020 I still think the bowl is running out, or the jets are clogged with crap. 3 Quote Link to comment
datzenmike Posted December 6, 2020 Report Share Posted December 6, 2020 Perhaps but no denying that running with the choke on constantly is not right. I'd call that roll coal. 2 Quote Link to comment
banzai510(hainz) Posted December 6, 2020 Report Share Posted December 6, 2020 if you know the wire wasdnt hooked up find a 12volt wire to hook it up. It might even haver a cut off selinoid also but this wasn't mention either so Photos or it don't happen show the carb close up pitcture!!!!!!!! 2 Quote Link to comment
Toneloc521 Posted December 6, 2020 Author Report Share Posted December 6, 2020 4 hours ago, banzai510(hainz) said: if you know the wire wasdnt hooked up find a 12volt wire to hook it up. It might even haver a cut off selinoid also but this wasn't mention either so Photos or it don't happen show the carb close up pitcture!!!!!!!! How do I attach photos it won’t let me 2 Quote Link to comment
