Jef-fro 24 Report post Posted April 4, 2020 I’m looking to purchase a single side draft carb for my L16.Any suggestions?and also I’m wondering how well the filters function on the air horns Quote Share this post Link to post
Jesse C. 12,298 Report post Posted April 4, 2020 The most common single side draft set up is the Canon Single Carb Manifold with a Weber. I had one and ran it with Air Horns. It was that or a filter, unless you have really short horns, the filter will not work with them . Pic off the web Quote Share this post Link to post
Jef-fro 24 Report post Posted April 4, 2020 Did you get good performance out of this setup? Quote Share this post Link to post
Jesse C. 12,298 Report post Posted April 4, 2020 It wasn't too bad, but, I did end up going back to my single downdraft weber before switching to dual carbs. If you have a cam and some mild work, it does make a difference. Quote Share this post Link to post
mhub91 1,106 Report post Posted April 4, 2020 Hi Jef-Fro, Here's my experience..... A few years back I decided to build an LZ23 for my B210. I just HAD to have all the cool race car parts. I decided to go with a pair of Weber 45 DCOE side draft carbs and a 2pc. short runner intake manifold(s). The old saying is that you can't have your cake and eat it too... Well, that holds true here. The dual side drafts produce and amazing, exciting induction sound. A quick, wind-snorting type of noise that will get you harder than a honey-moon-dick. But the problem with dual side draft its the lack of vacuum signal at low engine speeds -- which is necessary for idle and cruising speeds. Wide open throttle is no issue for dual DCOE. I can only imagine that a single side draft carb would have better idle and low engine speed operation - this is because TWO cylinder are being fed by ONE 'barrel' of the carb and will produce a better vacuum signal. If I could do it again I would have used a 38/38 Weber Outlaw, OR a single side draft DCOE. Quote Share this post Link to post
Jef-fro 24 Report post Posted April 4, 2020 Yeah I think your right I believe dual carbs might be to much do my stock l-16 thanks for the info Quote Share this post Link to post
banzai510(hainz) 4,655 Report post Posted April 4, 2020 Just get a Weber 32/36. Simple. unless some body has this single side draft as a Mikuni set up that is already to go and bolt up. mikuni has a better idle and low circuits . i don’t know why people even bother I would just get duals when doing sidedrafts. Quote Share this post Link to post
Crashtd420 4,421 Report post Posted April 4, 2020 11 hours ago, Jef-fro said: I’m looking to purchase a single side draft carb for my L16.Any suggestions?and also I’m wondering how well the filters function on the air horns If you go with the single side draft try to find a lynx intake... I have heard people struggle with tuning the cannon intake .... the benefit of the lynx intake is it pairs cylinders 1/4 and 2/3.... with the datsun firing order being 1-3-4-2 you can see how every induction pulse is the opposite side of the carburetor vs 2 pulses back to back from the same side ..... I have a modified L16 running the Lynx and a single 40 dcoe.... I have had to do alot of fine tuning but It runs great... 1 Quote Share this post Link to post
datzenmike 37,283 Report post Posted April 4, 2020 On the con side it has a less direct shot to the intake port. 3 and 4 have two 900 bends to go through but it does look shorter so will clear the brake master or booster better. Isn't there another intake that also bends upward slightly so the velocity stacks have more room? Quote Share this post Link to post
Jef-fro 24 Report post Posted April 4, 2020 If I was to go with a dual carb setup would I have to do any engine mods?larger cam Quote Share this post Link to post
datzenmike 37,283 Report post Posted April 4, 2020 Not if set up properly and the side drafts not too large. However a modest cam increase and some port matching will always add more power. Carried to an extreme a too large cam will move the power band higher in the RPM range at the expense of good drive ability in the low and mid range where 99.9% of driving is done. If you drive it daily on the street be conservative. Quote Share this post Link to post
Jef-fro 24 Report post Posted April 4, 2020 Do you think A set Weber dual 40s would be a good choice ? Quote Share this post Link to post
mhub91 1,106 Report post Posted April 4, 2020 (edited) 1 hour ago, Jef-fro said: If I was to go with a dual carb setup would I have to do any engine mods?larger cam Large cam = lower vacuum signal, which = poor low engine speed performance/idle quality... Sounds crazy, but it's true. The dynamic(?) compression ratio is diminished when you have more overlap from a big cam. In a race car scenario, guys who run big cams also run higher static compression ratio to compensate. My point is that unless you're high rpm and WOT a larger cam will not improve normal daily driving. Edited April 4, 2020 by mhub91 1 Quote Share this post Link to post
Jef-fro 24 Report post Posted April 4, 2020 This truck is just a weekend cruiser not a daily driver but I do want it to be dependable I like the look and sound of the side draft carbs but I don’t won’t to sacrifice functionality Quote Share this post Link to post
banzai510(hainz) 4,655 Report post Posted April 4, 2020 I bolted on a stock L18 and worked fine but it was a 40 mm set of mikunis On a 510.A 521 would be better as for the low heat ratio i hear the Weber’s the low speed circuits isn’t as good as the mikunis Do Not get 44/45mm sets as they too big 1 1 Quote Share this post Link to post
mhub91 1,106 Report post Posted April 5, 2020 3 hours ago, banzai510(hainz) said: i hear the Weber’s the low speed circuits isn’t as good as the mikunis 100% accurate. Also, they sneeze and pop at low engine speed if under load. While they look cool, sound cool and will woo folks at car shows/meets, dual DCOE is just so impractical. Seriously, use a damn 32/36 and fall in love with how easy it is to drive. Quote Share this post Link to post
mhub91 1,106 Report post Posted April 5, 2020 I'd really like to try out a lynx manifold with a single 40 dcoe. Quote Share this post Link to post
Jef-fro 24 Report post Posted April 5, 2020 I found a kit with a single Weber 45 that comes with everything I think I’m gonna go with do you think a 45 is to much even being a single? Quote Share this post Link to post
Jef-fro 24 Report post Posted April 5, 2020 I could not find any kits with Mikunis carbs Quote Share this post Link to post
mhub91 1,106 Report post Posted April 5, 2020 2 minutes ago, Jef-fro said: I could not find any kits with Mikunis carbs Here's the deal.... hard core, old timer datsun guys and Japanese racers always prefer Mikunis. The truth is there is more people running webers and a lot more support for them. It's all preference, IMO. 45 dcoe on an L16? I'll tell you this -- a Weber 32/36 smokes grey/black under wide open throttle on an L16 right out of the box (too rich). Don't expect great results from a 45 on an L16. You'll most likely (guaranteed) need smaller chokes and different jets. Quote Share this post Link to post
Jef-fro 24 Report post Posted April 5, 2020 Ok thanks for all the info I’ll keep shopping Quote Share this post Link to post
mhub91 1,106 Report post Posted April 5, 2020 1 minute ago, Jef-fro said: Ok thanks for all the info I’ll keep shopping It's just my opinion, man. Don't let me keep you from doing what you want. Quote Share this post Link to post
datzenmike 37,283 Report post Posted April 5, 2020 Doing anything to excess..... is how we learn. Quote Share this post Link to post
mhub91 1,106 Report post Posted April 5, 2020 1 minute ago, datzenmike said: Doing anything to excess..... is how we learn. My B210 was a prime example of this. Way back when I had a 32/36 but wanted dual 45s. Jesus what a mistake. Quote Share this post Link to post
Jef-fro 24 Report post Posted April 5, 2020 I’ve had a vw with dual carbs but this is my first Datsun I would rather listen👂 to good advice and make the right choice the first go around Quote Share this post Link to post
