1967 Galaxie 500 Project, aka Jules
Shocks mounts are done-ish...
large.20200711_130912.jpg.311a688e23c13a
Nervous about getting the curve right but got lucky nailed it first try...
large.20200711_131028.jpg.b4e477b1d00009
Going down here soon...
large.20200711_131017.jpg.916cbfb890edf5
You  may be able to see that they are slightly angled to the outside, and that was by design. It gets the point where the shock attaches farther towards the wheel than where the mount gets welded on.
It'll make sense later...  😄
  • Replies 886
Shape of lower control arm mount laid out...
large.20200715_164456.jpg.005d014bcc110c
Drilled and rough cut...
large.20200715_173128.jpg.7302252932a596
Gonna clean them up a bit, then they get welded on like so...
large.20200715_173319.jpg.b8b6b9bd2f461f
I was originally going to cut the leaf spring pads off and make LCA mounts that would be welded onto the axle tube. It was a very happy accident that the leaf spring pads on the Explorer diff are within 1/8" of being the same width as the spacing between the stock axle's lower control arm mounts. So it seemed more prudent to just weld the LCA mounts to the spring pads. And since we will be using adjustable heim-jointed rods instead of the stock LCAs, they can easily be shimmed to take up that 1/16" difference per side. 👍
  • Like 6
57 minutes ago, Duncan said:
I have a couple of these, and they are inexpensive and work really well.
https://www.amazon.com/profile-gauge/s?k=profile+gauge
Fast, easy, and cheap.  My kinda tool..
Yeah, I was about to buy one of those to use for guitar neck building anyway...  😁
On those I used a hole saw that was within 1/8" on the diff tube size and got lucky.
Edited by datsunfreak
12 hours ago, EDM620 said:
This build is coming along nicely.
Thanks! I feel like I learned a lot of lessons on my 1200 build, namely that I should really try harder to keep things simple. It keeps me motivated, makes things move along quicker, and ends up being a lot less expensive in the long run (in both time and money).
The only two big (in my mind) projects I have planned for this are the rear axle swap (which is going fairly well so far, jinx!), and converting it to a manual transmission (which will also require a fair bit of fab).
Once those two are done, it's a fairly fast downhill slide. Redo the brake lines and master, rewire the whole car (less scary than it sounds), and try to spiff up the interior a bit. My goal is to be driving it by December of 2021 (jinx again!), so we'll see how that goes...  😁
1 hour ago, datsunfreak said:
The only two big (in my mind) projects I have planned...
I learned to make a to-do list on my phone that helps keep me on track - easy to add stuff as I discover/think about it, and tracks my progress as I check off each task.
Like you said, doing the rewire isn't quite so terrifying as those old vehicles simply didn't have a whole lot of circuits in them, and you can eliminate many potential issues in the long run.
That's a good idea. 👍
I normally use a paint marker and write different tasks on the windshield with it, then just scrape them off with a razor blade when they are done. That won't work here because this fat bitch has to live outside.   😁
I was pretty nervous the first time. But me and Tim have done enough of them that by now it doesn't seem like a hassle at all. And as you said, it saves me countless hours down the road chasing electrical gremlins due to old wiring. This will have the bare minimum of circuits as well. Just lights, ignition, horn, and gauges. Maybe, maybe, wipers.  😁
Also, these make it easy. All the wires are labeled every five inches, so it's basically just a matter of running looms where they need to go, and then installing connectors. If you pay close attention, you can bang it out in a day.
If you can use cable tubes and but the wires in a box/frame, rubber seals to places where needed to keep them from rubbing. I think you know the basics. This keeps things out of elements and they last a long time. Use hollow section wax on the inside of the body structure to keep the  metal from rusting insideout. The corrosion is a huge issue here in our climate, do not know what it is like for you guys in there. Most cars rust from the inside to the outside, because of condensation and humid climate, add salt on the winter roads to that. A perfect place to return your metal to nature as rust. Hope to see an update on this build soon.
We don't salt the roads here in Texas as we see very little snow/ice.
Oddly, here in Texas, this would be considered a "very rusty" car. In the Northeast it would probably be considered almost rust free. 😄
5 hours ago, datsunfreak said:
I'm feeling like you didn't click the link...  😁
LOL totally got me on that, no I didn't immediately but later.
While the kit would be good, I'd prefer to get the wires on separate spools to build my own harnesses. Kit = buying what you don't need or not enough of what you do.
That is what we are doing on the 1200 monster truck.
large.20191120_180814.jpg.c81153909b41d8
Quote
I just don't like building/assembling my own fuse boxes. This kit is ideal for what I need/want on most of my builds. 👍
This is a valid point.  On every one of those kits I have installed, circuits have been re-purposed and/or stripped right out of the harness.
This is also a valid point.  I know it has John scratching his head over why I'm going that route on the Baja 1200.  Well, the short answer is, "I dunno." and the long answer is, "IIIIIIIIIII doooooooooonnnnnnnnn't knoooooooooooowwwwwwwwwwww."
OK now I gotta ask - since the EZ wiring website doesn't show that you can buy bulk wire, are those spools from them ( & therefore labeled) or a different source? Just curious because I appreciate the complexity of building your own harnesses.
No, those spools came straight from Satan himself... oops!  I mean Amazon!  They came from Amazon (All Hail Our Dark Lord, Bezos-abub).  They are not labeled in any way.
Edited by dimlight65
Spelling "came" correctly
Tim did me solid and did some welding yesterday...
large.20200722_162454.jpg.de0341504ca663
So the lower control arm mounts and shock mounts are all done...
large.20200722_175507.jpg.892d8b580bf3dd
Next step is to see if I can remove the spring pads from the original axle and weld them to this one, if not we will have to make our own. Then it's on to making the upper control arm/panhard rod mount. 👍
And somehow, inexplicably, I did. With zero damage to them.    😄
large.20200725_110322.jpg.009610df7631fb
And as you can see, they were not very rusty, thankfully. 👍
Got the diff level, and got the pads propped up on there in a level position...
large.20200725_110308.jpg.ea9fe6e48eee0b
Tim did some zookage for me...
large.20200725_112414.jpg.03f501a38a46ee
And all sorted...
large.20200725_120326.jpg.da80e8899d74d8
Now on to the last step, making the upper control arm/panhard mount. Unfortunately, the pieces I have (2x4 box) were deemed to be not "big" enough. For safety and strength, we have decided we need 2x6 (or 2x7 if they have it) box so that it wraps around the diff tube more (this will make sense later). I will pick that up on Monday and hopefully I can make what I need for the mount on Wednesday. 👍
On 7/24/2020 at 12:09 AM, Aibast said:
On 7/24/2020 at 3:11 PM, dimlight65 said:
We have considered it.  I think the need for welding another pickup point to the frame is what put the kibosh on the idea... but I could be wrong there.
It has been, and most will likely continue to be, a source of much debate. 😁
I like it, but not sure the added work/complexity of it justifies the benefits. I think a better cost/benefit could be to either build a much longer panhard rod, or possibly switch to a "j bar" panhard rod?
What I want to try first is a stock length panhard bar, run the axle through it's effective range, and then we can see how much side-to-side deflection we get. It's possible we are trying to fix a problem that isn't really a problem. And I do that a lot. 😄
  • datsunfreak changed the title to 1967 Galaxie 500 Project, aka Jules
