slowlearner 142 Posted August 30, 2020 Author Report Share Posted August 30, 2020 Thanks Mike. 🙂 Quote Link to post
datzenmike 38,316 Posted August 30, 2020 Report Share Posted August 30, 2020 The fan belt may need a simple tightening or it may be glazed so just replace it. 1 Quote Link to post
slowlearner 142 Posted August 31, 2020 Author Report Share Posted August 31, 2020 Hi guys, looking for some more datsun wisdom. Having a slight issue getting the dogleg box from 1st into 2nd gear. Doesn't want to find 2nd. 3rd to 2nd is fine. Thoughts? Quote Link to post
datzenmike 38,316 Posted August 31, 2020 Report Share Posted August 31, 2020 On the underside of the 63A is a large nut. (middle picture) This holds a post up inside with a lever like a teeter-totter. First and reverse have to go through this lever which reverses the striking rod travel from a forward to a backward throw. Without it the shift pattern would be ... 1..2..4 R..3..5 Instead of... R..2..4 1..3..5 Is this nut loose? which might affect getting out of first? If in reverse will it shift directly into 2nd? Quote Link to post
slowlearner 142 Posted August 31, 2020 Author Report Share Posted August 31, 2020 No, it comes out of 1st ok. Just engaging 2nd after 1st is the issue. Once the revs drop it will go in, but not revved up. I can't tell if it's temperature sensitive. Quote Link to post
Lockleaf 4,912 Posted August 31, 2020 Report Share Posted August 31, 2020 What happens if you double clutch it? Quote Link to post
slowlearner 142 Posted September 1, 2020 Author Report Share Posted September 1, 2020 11 hours ago, Lockleaf said: What happens if you double clutch it? Speaking of the clutch, I thought I'd start back at first principles. This morning I bled the clutch slave cyl, tightened up the linkage and adjusted the pedal. I'm hoping this is the real issue, because I'd noticed the pedal had sunk a little since I started driving it. Quote Link to post
datzenmike 38,316 Posted September 1, 2020 Report Share Posted September 1, 2020 22 hours ago, slowlearner said: No, it comes out of 1st ok. Just engaging 2nd after 1st is the issue. Once the revs drop it will go in, but not revved up. I can't tell if it's temperature sensitive. Idle in neutral. Depress the clutch and put in reverse like you were going to back up. Does it grind gears at all???? Bet it does. Clutch is not disengaging. Low on fluid or air is in the line. Quote Link to post
slowlearner 142 Posted September 2, 2020 Author Report Share Posted September 2, 2020 Ok, so the clutch is working fine. Adjusted up, bled, etc. The car doesn't like shifting from 1st to 2nd when warm, at medium to low revs. It will shift fine at higher revs with blip in between. This is good, because it means I can do events and not fear it shifting. Double clutching also works. So I have options. I'm going to drop the oil tomorrow and change it. I'm also going to add some Molybond trans treatment to the trans and hope that works. Stew Wilkins said he doesn't really like the 63A trans, prefering the 71B and 71C. So maybe I'll keep an eye out for them in my travels. I also need to change the tank breather lines. They're leaking = stinky interior. My other issue is the car running on about every 4th or 5th time when I switch it off. I'll go looking for that issue soon. New plugs I guess and maybe timing. And the SUs are sticking and not idling quite right. I think I'll drop the car out to Stew for a going over during the school holidays or similar. I'll get him to look at the back springs at the same time. It's a scooch too high and has very slight positive camber. The loner WRX I have goes back this weekend. So its all on for being a daily driver. It needs some tunes, but I'm getting a bluetooth speaker for father's day this weekend, so that should be nice. 🙂 I like driving it. I'd really like to convert to EFI now, but there are a few other things going on around here I need to sort out first. I think an EFI conversion will have to wait til the new year. 😞 Quote Link to post
datzenmike 38,316 Posted September 2, 2020 Report Share Posted September 2, 2020 22 hours ago, datzenmike said: Idle in neutral. Depress the clutch and put in reverse like you were going to back up. Does it grind gears at all???? Bet it does. Clutch is not disengaging. Low on fluid or air is in the line. Did you try this? If grinding it could also be a damaged pressure plate or disc. Quote Link to post
slowlearner 142 Posted September 2, 2020 Author Report Share Posted September 2, 2020 41 minutes ago, datzenmike said: Did you try this? If grinding it could also be a damaged pressure plate or disc. Yep, there's no grinding. Just a nice, "snick" and in it goes. Quote Link to post
nad015 7 Posted September 2, 2020 Report Share Posted September 2, 2020 Where abouts are you? I might be able to sell you a 71b box next time I get up to nsw. I have a few if you get a 71c box, you’ll need to put a bellhousing on it from a Lseries 71b box. 71c boxes are sr,ca boxes That’s what I have in my car. Quote Link to post
datzenmike 38,316 Posted September 2, 2020 Report Share Posted September 2, 2020 OK then not likely a clutch problem. Quote Link to post
slowlearner 142 Posted September 2, 2020 Author Report Share Posted September 2, 2020 15 minutes ago, nad015 said: Where abouts are you? I might be able to sell you a 71b box next time I get up to nsw. I have a few if you get a 71c box, you’ll need to put a bellhousing on it from a Lseries 71b box. 71c boxes are sr,ca boxes That’s what I have in my car. I'm in Sydney. I'll PM you. Quote Link to post
slowlearner 142 Posted September 3, 2020 Author Report Share Posted September 3, 2020 Alright. So I changed the gear oil this morning and bled the hydraulic clutch system again last night. Having done so I took the car for a drive. When cold, it's not too bad. As it warms up, the issues return. I think now, the issue is the clutch not releasing properly as it gets warm. Wondering what might cause this, but I think it means pulling the trans out... 😞 Fun times. Quote Link to post
datzenmike 38,316 Posted September 3, 2020 Report Share Posted September 3, 2020 When warmed up try the idle in neutral and placing into reverse. If it goes is quietly then clutch is releasing. Quote Link to post
slowlearner 142 Posted September 3, 2020 Author Report Share Posted September 3, 2020 The gearbox has had three different oils in it today, and molybond treatment. No cigar. Still not shifting properly. So I think it's time to pull it out and find one that works. @nad015 And the oil pan is leaking now too. More fun. 😞 Quote Link to post
datzenmike 38,316 Posted September 3, 2020 Report Share Posted September 3, 2020 I'm guessing this is a long 31.5" dogleg 5 speed from a 610SSS? aka 180B? that you guys got and we didn't. A late z or zx 71B should fit right in there. The 71B is strong enough for a non turbo 2.8 liter six cylinder engine. Quote Link to post
slowlearner 142 Posted September 3, 2020 Author Report Share Posted September 3, 2020 It's an 810sss 5 speed, but yeah probably the same. Quote Link to post
datzenmike 38,316 Posted September 3, 2020 Report Share Posted September 3, 2020 31.5"???? long? We did not get the long 63A doglegs but they show up every now and then, probably on import engines. Our 810s had L24 six cylinder engins and are slightly longer in the front. Norway got the 810SSS also. Quote Link to post
slowlearner 142 Posted September 5, 2020 Author Report Share Posted September 5, 2020 Look what I found at SW Motorsport... It's a second handy, but hopefully it works well. Otherwise we're in for a rebuild. Quote Link to post
datzenmike 38,316 Posted September 5, 2020 Report Share Posted September 5, 2020 That's an '80 or newer71B and appears to be an L series so 280zx or Maxima (I think 910 there) Nice!! Put in first gear, turn input spline 20 times, count output spline turns 5.5 times is a wide ratio box with 3.592 first 6.0 is a mid ratio with a 3.321 first gear. Likely this 6.5 is a close ratio from a 280zx with 3.062 first 1 Quote Link to post
slowlearner 142 Posted September 5, 2020 Author Report Share Posted September 5, 2020 5 hours ago, datzenmike said: That's an '80 or newer71B and appears to be an L series so 280zx or Maxima (I think 910 there) Nice!! Put in first gear, turn input spline 20 times, count output spline turns 5.5 times is a wide ratio box with 3.592 first 6.0 is a mid ratio with a 3.321 first gear. Likely this 6.5 is a close ratio from a 280zx with 3.062 first Did some testing as suggested. I think it's the mid ratio box like you said. Which is probably a good thing with only a L18 pushing it. Quote Link to post
datzenmike 38,316 Posted September 5, 2020 Report Share Posted September 5, 2020 I think the mid ratio the best all round. The close ratio is certainly ok on a very light 2,300 pound 510 but an effort to use on a heavier car or truck. The over drive is an insane 25% and useless except on the highway.... after all it was intended for a 2.8 liter engine. I have a wide ratio for the lower first gear and coupled with a 4.11 it revs smartly from a start and pulls very well in all gears but there is a lot of rowing through the gears in town. In 5th gear it's close to 4th in a mid ratio box and on a long trip I can still get into the low 30s on an imperial gallon. Quote Link to post
slowlearner 142 Posted September 7, 2020 Author Report Share Posted September 7, 2020 Managed to pull the 63a on Sunday arvo and then the clutch last night. Clutch looks ok, so I'm still guessing all the issues are with the gearbox, thank God. 71b is the same dimensions as the as the 63a but not a dogleg. Throw out bearing and.clutch lever are the same too. Gotta love the datsun parts bin. I just need a few longer bolts to put through the top of the belhousing into the motor and I'm set to go. Quote Link to post
