datzenmike 38,316 Posted September 8, 2020 Report Share Posted September 8, 2020 Make sure you use the bearing collar or housing that was on the 63A. It's mated to the clutch you have on there. If there's one on the 71B it could be for a different clutch and give you problems. Quote Link to post
slowlearner 142 Posted September 10, 2020 Author Report Share Posted September 10, 2020 Spent 13 hours on Nana today. Gearbox went in, then out, hole drilled out, then trans back in again. I always learn the hard way. It works and shifts well. I like the shorter gearstick better too. Doesn't hit my knee so much. My other job was pulling out the oil pan and resealing it. What a nightmare. Took me hours and numerous tricks to remove it. The good news was it has a good factory baffle in it. Also, the bottom end looked tidy and clean, which is great. 1 Quote Link to post
slowlearner 142 Posted September 12, 2020 Author Report Share Posted September 12, 2020 Quote Link to post
slowlearner 142 Posted September 13, 2020 Author Report Share Posted September 13, 2020 I'm an idiot. I ran the car out of fuel again tonight. Damn faulty gauge. Quote Link to post
datzenmike 38,316 Posted September 13, 2020 Report Share Posted September 13, 2020 Use NGK plugs, what the factory supplied your Datsun with. Quote Link to post
nad015 7 Posted September 13, 2020 Report Share Posted September 13, 2020 Found yourself a gearbox I see! Nice. they’re pretty sloppy in the shifter. Make sure you replace the shifter bushings and nylon cup on the end if they’re worn. I actually made a short throw shifter when I had one of these boxes in my car. You have to make the end that goes into the gearbox longer, makes the shifter feel 100x better. I also think maddat sell a short throw shifter for these boxes. I ended up putting a 71c box in mine, basically the same as a 71b box I think, it just has the nicer shifter mechanism used in sr and cr boxes. Quote Link to post
datzenmike 38,316 Posted September 13, 2020 Report Share Posted September 13, 2020 Have extra shifters so cut 1/2" off of one and welded it onto mine. Drill new holes 1/2" higher... It was a big change but now I'm used to it and don't notice it at all. Had to learn new foot/hand co-ordination. Sideways through the neutral gate is the same The 71C is about twice as strong as the 71B. Larger counter bearing, larger diameter 1st/2nd shift rod, larger shift forks, much better synchros and gears made wider for strength. 1 Quote Link to post
slowlearner 142 Posted September 14, 2020 Author Report Share Posted September 14, 2020 Thanks guys. The 71b is MUCH nicer to use than the 63a. I don't think I'm going to mess around with short shifts. 2nd gear is a little crunchy, but it's more than usable. I've been dailying it again today. Running the kids to school and pottering to work. I managed to advance the timing and bring the idle down. It starts first time without touching the throttle too. However, I think the SUs make it a bit thirsty. I also think my oil pan is leaking again. I'll pay someone with a hoist to fix it next time. Quote Link to post
nad015 7 Posted September 14, 2020 Report Share Posted September 14, 2020 13 hours ago, datzenmike said: Have extra shifters so cut 1/2" off of one and welded it onto mine. Drill new holes 1/2" higher... It was a big change but now I'm used to it and don't notice it at all. Had to learn new foot/hand co-ordination. Sideways through the neutral gate is the same The 71C is about twice as strong as the 71B. Larger counter bearing, larger diameter 1st/2nd shift rod, larger shift forks, much better synchros and gears made wider for strength. Yeah pretty much what I did aswell. Makes a huge difference Quote Link to post
nad015 7 Posted September 14, 2020 Report Share Posted September 14, 2020 Where abouts is your oil leak? Sump? Or is it rear main seal? Quote Link to post
slowlearner 142 Posted September 14, 2020 Author Report Share Posted September 14, 2020 11 hours ago, nad015 said: Where abouts is your oil leak? Sump? Or is it rear main seal? It was the sump last time for sure. It shouldn't be the rear main. I replaced that just recently. Quote Link to post
nad015 7 Posted September 15, 2020 Report Share Posted September 15, 2020 Hope not the rear main. That wouldn’t be fun doing that with the engine in the car Quote Link to post
slowlearner 142 Posted September 16, 2020 Author Report Share Posted September 16, 2020 (edited) 19 hours ago, nad015 said: Hope not the rear main. That wouldn’t be fun doing that with the engine in the car Yeah, I really doubt it. It wasn't leaking with the old box in, or for that matter with the auto either. I made a point of replacing it before I went manual. It's also got sealant around the outside of it. Seriously entertaining starting on injection sooner rather than later. It would just be nice to have programmable ignition. Edited September 16, 2020 by slowlearner Quote Link to post
slowlearner 142 Posted September 16, 2020 Author Report Share Posted September 16, 2020 I found my oil leak! 🙂 It's the oil pressure sender. So that should be easy to fix. Quote Link to post
datzenmike 38,316 Posted September 16, 2020 Report Share Posted September 16, 2020 SUs are fun to drive hard and where your gas is going. Tuned right I think at least the same mileage. It shouldn't be disastrously bad or something isn't right. Quote Link to post
MikeRL411 3,265 Posted September 16, 2020 Report Share Posted September 16, 2020 2 hours ago, slowlearner said: I found my oil leak! 🙂 It's the oil pressure sender. So that should be easy to fix. Remember BTS not SAE thread. Adapters readily available, look in the aftermarket dash gauge section of your auto parts store. Quote Link to post
slowlearner 142 Posted September 16, 2020 Author Report Share Posted September 16, 2020 6 hours ago, datzenmike said: SUs are fun to drive hard and where your gas is going. Tuned right I think at least the same mileage. It shouldn't be disastrously bad or something isn't right. Yeah I'm trying hard to moderate hard driving for fuel consumption. 😆😆 They don't really love idling either. Stewart Wilkins mentioned that issue to me too. They get hung up at 1500rpm or slowly drop right down to dying. Quote Link to post
datzenmike 38,316 Posted September 16, 2020 Report Share Posted September 16, 2020 If this was normal for all SUs they wouldn't have used them. You need an airflow meter to synchronize the two carburetors so they are both using the same amount of air and doing equal work. Are the dash pots filled? with the same oil Quote Link to post
slowlearner 142 Posted September 17, 2020 Author Report Share Posted September 17, 2020 9 hours ago, datzenmike said: If this was normal for all SUs they wouldn't have used them. You need an airflow meter to synchronize the two carburetors so they are both using the same amount of air and doing equal work. Are the dash pots filled? with the same oil How much oil should be in them? I can't seem to find where to measure that. Quote Link to post
slowlearner 142 Posted September 17, 2020 Author Report Share Posted September 17, 2020 (edited) Been a big day today datto wise. Got the oil send cleaned up and resealed, put an accessory fan back in ready for summer, ran all new breather lines for the fuel tank. I discovered I put the fuel gauge sender in upside down last time I got it out. Oh well. Now half a tank means there's not much left. Took my son out to collect something he'd bought and Nana got it's first go on the freeway. Cruises nicely at 60mph, although I think the speedo is reading a little fast (not a bad thing). It also wasn't darting around or too noisy which is really nice. There were however, a fuel misses at low throttle. Also, turning it off, it dieseled really bad and was running on quite a bit. Same at home afterwards. I think it's time to go to SW Motorsport and get it tuned properly. Checking the oil sender, it's weeping so I'll definitely need a new one of those. I also found out the radiator is weeping down the bottom. The car isn't getting hot per se (according to the gauge), but I can't leave it like this. I guess it's another thing in a long list of 50yo parts showing their weaknesses. Found these 3 core rads on fleabay... https://www.ebay.com.au/itm/3-ROW-ALUMINUM-RADIATOR-For-Nissan-Datsun-1600-510-Petrol-1-6L-4cyl-L16-Manual/114388038008?hash=item1aa20ef178:g:fQoAAOSwzV5fTv9y Was just wondering if anyone has had any experience with them? The price is right, but I don't want to have to replace it again with something proper. Thoughts? Edited September 17, 2020 by slowlearner Quote Link to post
datzenmike 38,316 Posted September 17, 2020 Report Share Posted September 17, 2020 You may never solve or completely get rid of 'run on' or 'dieseling'. Learn to hold the brake, place in 4th, let up the clutch to load the engine down and turn the ignition off. Engine will stall right away. Only when fully stopped, let the clutch up all the way. For an automatic, turn off in drive, then place in park. For or five times and it becomes smooth and automatic when stopping. Quote Link to post
slowlearner 142 Posted September 23, 2020 Author Report Share Posted September 23, 2020 The good news. The car idles and doesn't run on anymore. 10deg BTDC on idle and works like a charm. The bad news. It stinks of petrol, this after replacing EVERY line around the fuel tank. Still trying to ascertain what the issues is and where the smell is coming from. Also, there's a terrible exhaust leak, but it's getting that sorted tomorrow. My new radiator also arrived yesterday, so I'm looking forward to installing that. Probably on Saturday. Yay, antifreeze. Quote Link to post
wayno 8,759 Posted September 23, 2020 Report Share Posted September 23, 2020 Look at the over flow tubes on your SUs, look below the tubes and see if anything is wet, SU floats can go bad and sink causing fuel to get dumped out the over flow tube, also check all the fuel lines in the engine compartment, maybe one is dripping. 1 Quote Link to post
slowlearner 142 Posted September 23, 2020 Author Report Share Posted September 23, 2020 4 hours ago, wayno said: Look at the over flow tubes on your SUs, look below the tubes and see if anything is wet, SU floats can go bad and sink causing fuel to get dumped out the over flow tube, also check all the fuel lines in the engine compartment, maybe one is dripping. Yeah, it's the boot and interior that smell, not under the bonnet. Carbs are working quite well really. Quote Link to post
MikeRL411 3,265 Posted September 23, 2020 Report Share Posted September 23, 2020 SUs occasionally jam due to gas tank crud making it through the fuel filter and jamming the float arm. Just jiggle the wire protruding from the underside of the carb. If this clears the over flow, you just saved yourself a whole lot of trouble at no cost. Quote Link to post
