Rasp933 Posted May 11, 2018 Report Share Posted May 11, 2018 Hi. I am trying to see if I can use gl-5 type oil in my 73 datsun 4 speed manual transmission?? Any ideas. Thanks Quote Link to comment
datzenmike Posted May 11, 2018 Report Share Posted May 11, 2018 NO!!! Only GL-4 oil in a Datsun transmission. The copper alloy synchro rings will be slowly eroded away by the extra anti scuff additives in GL-5. GL-5 is for differentials only that need it. The GL-4 should say 'yellow metal safe' or 'copper/brass compatible'. If in doubt don't use it keep looking. Yes GL5 is a superior HP high pressure gear oil to GL-4, but transmissions don't need it and it's no good for them. Don't let some parts counter monkey try to talk you into this 'upgrade'. 2 Quote Link to comment
Rasp933 Posted May 11, 2018 Author Report Share Posted May 11, 2018 Rite on man . Quote Link to comment
Rasp933 Posted May 11, 2018 Author Report Share Posted May 11, 2018 These dummies are all trying to sell me that crap Quote Link to comment
datzenmike Posted May 11, 2018 Report Share Posted May 11, 2018 The anti scuff additive is sulfur based and in high enough concentrations it bonds with the surface molecules of the copper and forms a hard wearing surface. This would be like having a sheet of glass covering your mattress. Any load on it and the surface shatters and sheds leaving a new surface for the anti scuff to bond to and it just keeps shedding. GL-4 has concentrations of about 4%, GL-5 is 6%. Now it might look like only 2% different but if you think about it 6 is 50% more than 4. Be informed, know as much as you can about your B-210 and what you are buying for it and why. These cars are over 40 years old and a lot of stuff today does not apply to them. 1 Quote Link to comment
kelowg Posted May 11, 2018 Report Share Posted May 11, 2018 Royal purple,sta lube r yellow metal safe. Pensoil syncromesh works too, but bit on thin side. 1 Quote Link to comment
Rasp933 Posted May 11, 2018 Author Report Share Posted May 11, 2018 Will synthetic blend of oil hurt the transmission?? Quote Link to comment
G-Duax Posted May 11, 2018 Report Share Posted May 11, 2018 I have had zero luck with anything with synthetic in it ! Red Line, Mobil-1, etc.. It won't shift correctly any longer if you try. Just go to Napa, and buy a jug of CRC StaLube # SL24239. And you may want to rethink the 75w90. Nissan Racings says to use 140wt on anything over 90* ambient. I run StaLube SAE 140 all year around, and my 38 year old Z 5-speed loves it, even on 40* days. It is # SL24238 Quote Link to comment
datzenmike Posted May 11, 2018 Report Share Posted May 11, 2018 Not at all, I'm using GM Delco Friction Modified Synchromesh Manual Transmission oil and am over the moon satisfied with it. Easier, shifting, faster shifting, less effort when cold, can down shift now whereas before it was very stiff or would grind slightly. HOWEVER.... synthetic is so thin/slippery it will leak out the rear seal if old and worn where GL-4 80w90 won't. I just replace the $4 seal. I am at 50th parallel so rarely gets much above 90F here but can dip briefly to 25F. But I don't drive in the winter. Quote Link to comment
banzai510(hainz) Posted May 11, 2018 Report Share Posted May 11, 2018 i went with the 90-140 stuff myself as my 521 is a leaker As with G Duax I stay away from the synthetics with my Yamaha RD350 i put 80wt synthetic in trans and now it leaks more than with the 30 wt standard. WTF. Old seals just dont like them. stuff is thinner even if you up the WT number(seems to me) as for GL4/5 I just run what I find at Walmart ir O rileys as having oil is better than no oil.(last 10years in 521) sta lube is on my list to get now Quote Link to comment
KELMO Posted May 11, 2018 Report Share Posted May 11, 2018 The NAPA StaLube gets my vote also. I have been using it at least the past 8 years if not more. Quote Link to comment
G-Duax Posted May 11, 2018 Report Share Posted May 11, 2018 I may try the Shell Synchromesh stuff in my S15-R 6-speed, been hearing a lot of good stuff about it. It's available from many different sources (OEM distribution), so it will be easy to find. Besides, I have no idea what lube Nissan wanted in that thing...... Quote Link to comment
Dolomite Posted May 11, 2018 Report Share Posted May 11, 2018 I’m using Lucas Oil synthetic in my zx 5 speed, it shifts nice and slick and lost the slight notchiness going into second it was developing. Quote Link to comment
datzenmike Posted May 11, 2018 Report Share Posted May 11, 2018 40 years ago Nissan recommended 80w90 GL4. Quote Link to comment
Rasp933 Posted May 11, 2018 Author Report Share Posted May 11, 2018 Good info right there guys. Quote Link to comment
Rasp933 Posted May 11, 2018 Author Report Share Posted May 11, 2018 I think I am going to try that Napa stalube for now.Thanks Quote Link to comment
docbainey Posted May 11, 2018 Report Share Posted May 11, 2018 Banzai Do you have your rd built? In the day those where assume drag bikes. Nothing like. A 2 stroke scream. 1 Quote Link to comment
