Sign in to follow this
datzenmike
How does this bumper look???
Think the '71 Camaro had 'bumperettes' like the Corvette also..
Share this post
Link to post
Took the plunge with a 6" angle grinder...
Very rough mock up.
Had more than a few dents and scrapes which throws everything off. Hammered them out from the back side.
I'm thinking big tacks where it lines up really well then pull into or hammer into smooth joint as I weld the back. Then one long weld on the front and grind down. Had to remove two 5.25" sections. One had a dent.
Share this post
Link to post
cut the bottom off it at the style line and use the top half... too thick
Share this post
Link to post
Maybe.... But then the license plate will look like it's dragging the ground. Well you aren't the first to say that, it's a thought and I can better decide once it's on. Again the valance is hideous and I would like to cover it.
Share this post
Link to post
I guess so.
I can change the title to should I cut or not.
Share this post
Link to post
I bet you'd want to re-chrome it after the cut.  What about blacking out the portion with plasti-dip just to see how it looks.  Possibly enamel it black if you like it.
Share this post
Link to post
Christ that would cost! I imagine shipping to Vancouver and back on top, if, there's a place that does this. I doubt it will be good enough to chrome, I was just going to paint it.
Share this post
Link to post
paint them it will dim it down
they are a bit fat but might look ok without the bling
Share this post
Link to post
Well long way to go before the final decision. Was thinking dark gray as Hang510 suggested. Blacking it out would work to make it look thinner. Again I don't want to have the valance visible if possible. I guess it's wait and see.
Share this post
Link to post
Well took the plunge. Tacked it in several places with the edges lined up as best I could. In places there was high and lows so I hammered the lows from the underside out till even. When it wouldn't go out any more I hammerde the chrome side down.
Still have to grind down the weld. I even bought a cheap little sander as well.
Share this post
Link to post
The crack shows, the chrome went blue from the weld and I'm painting it anyway. I did both sides..
Share this post
Link to post
Trimming will be easy. Let me get it presentable and mounted first.
I did grind down the weld and then proceed to sand it down smooth. Using 80 grit but needs something more aggressive. Maybe an orbital sander. Also the weld may be harder than the bumper.
Share this post
Link to post
It will take forever with an orbital sander, get a grinding wheel that fits in a drill and take your time.
I use flap disc's myself, or a grinding wheel that fits on a small angle head grinder, I use the small Dewalts, I even have an 18V cordless one also for small jobs.
Share this post
Link to post
Mike. You must have a pneumatic grinder yes?
Share this post
Link to post
Na just some hand tools and lots of time.
Share this post
Link to post
Just spend a $100.00 for a small 120V Dewalt angle head grinder, then buy a few cutting discs and flap discs.
You have to take off the guard off to use the cutting discs and maybe the flap discs, but anywhere you cut metal it turns an hour job into a 5 minute job, these tools are so handy, you can even put an orbital sander attachment onto them and it will work way better than a regular electric orbital sander.
They even sell 18V Dewalt angle head grinders without the battery for under a $100.00, but the battery is expensive, you can find 2 packs for around a $100.00 or less on Ebay.
The only bad thing about them is if you try using them without eye protection you will end up at the eye doctors having them get some shit out of your eye, the doctor says one of my eyes looks like the moon, craters everywhere, I have not gotten anything in my eyes in years now.
Share this post
Link to post
Yes. I have an angle grinder with the guard removed. On your recommendation I looked for and found a flap disc for it. Never noticed them before. I have prescription glasses and can't see stuff up close with them on so I use safety goggles anyway and it keeps the glasses from getting fucked up too. Thanks again, good info. Can't wait to get home tonight. Tomorrow is supposed to ne sunny all day too.
Share this post
Link to post
I forgot to mention, the round nut holding whatever disc your using, especially the cutting discs needs to be put on upside down on the small Dewalt grinders, otherwise the cutting/flap disc will not get tight, so if your disc is loose after you tighten it down, put the round nut on the other way.
Some grinding discs have threaded holes so you don't need the round nut, but you do need the round disc mount nut on most everything else.
Share this post
Link to post
It's a Makita? or Ryobi and yes some cutting/grinding disc don't tighten up right.
Share this post
Link to post
The "nut" should have a raised lip on one side and smooth on the other. Raised lip toward machine for thick discs (grinding), flat side toward machine for thin (cutting, flap disks).
Flap discs single handedly changed the finish quality of my work. I love those things
Share this post
Link to post
Beautiful fall day, time for some work. The left side is so so...
Right side came out fair. Rather than fuck with it I'll fill divots with paint.
Will use the bumper shocks as a template for mounts to the 'frame'. The ends that stick out still have to attach to the actual bumper. I still have the original chevy attachment points to it's frame so maybe they can simply be grafted together. I can then use the chrome carriage bolts.
Another thing, this sat out all week in the rain and not a speck if rust. Could the chrome have mixed with the weld?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
