78 620, L20B foreign matter in combustion chamber.
Atikin9000
  • Replies 448
I fucking hate links. (I hate PB too)
I know. Today I learned that Canadian football is actually American football even though we play on a longer wider field, have 3 downs and an extra player to make the game faster and more enjoyable. Canadian football (AKA American football) is closer to European football (AKA Soccer) Go figure...
Damn socialist system.
  • 3 weeks later...
Looks like they made it work, but boy are those valves sunk in the head. Did they adjust valve lash for you? I'm sure they either needed thinner pads or they had to "tip" the valves to make it work.
That's half an engine rebuild right there.
Nah the lash needs to be set still, both the machinist and a mechanic I stopped by said the head needs to be back on before they can adjust it.
Absolutely not.  Its not a pushrod motor.  Everything that needs to be checked and adjusted can be done on the bench, then installed as a full assembly.  Their reply was a cop-out.  In fact, they could have ground the valve tips before assembly so you wouldn't have to buy new shims.  Given the varying valve depths in the photos, they made a real mess for you.
