G-Duax Posted November 19, 2016 Report Share Posted November 19, 2016 Doubtful if that would work, since the original head to shank strength would have been stronger than welded. 1 Quote Link to comment
thisismatt Posted November 19, 2016 Report Share Posted November 19, 2016 Doubtful if that would work, since the original head to shank strength would have been stronger than welded. But you get the added benefit of heating the bolt up to 6000+ degrees celsius 1 Quote Link to comment
datzenmike Posted November 19, 2016 Report Share Posted November 19, 2016 ..... got stuck and broke off inside.... ..... But the answer is the bolt broke flush..... ...... my heart sunk when that bolt snapped... that's also why it's in three threads ..... Good luck welding a nut on. 1 Quote Link to comment
Jester Posted November 20, 2016 Report Share Posted November 20, 2016 So my flywheel recently exploded.... Nevermind. 1 Quote Link to comment
Einbbx Posted November 23, 2016 Author Report Share Posted November 23, 2016 It's slow going... this damn thing is some sort of tough I tell you. But it's getting drilled. Could t punch a divot I to it so it's not exactly centered. Never the less I'll continue carefully until I get the whole wide then use something to try and break it apart and remove the chunks. -Thanks all for your input, glad to have your advice 1 Quote Link to comment
Einbbx Posted November 23, 2016 Author Report Share Posted November 23, 2016 My SPLODED flywheel. https://www.instagram.com/p/BM7qAKKgXbgMwIVcf6qF1daWYRD7VNdzwWOvQc0/ 1 Quote Link to comment
datzenmike Posted November 23, 2016 Report Share Posted November 23, 2016 Flex plate. 1 Quote Link to comment
Einbbx Posted November 29, 2016 Author Report Share Posted November 29, 2016 Lol ok flexplate.. so how do I pry off that rear spacer, this thing is mucking everything up 1 Quote Link to comment
datzenmike Posted November 29, 2016 Report Share Posted November 29, 2016 It's just clipped on there. Usually just falls off with the flexplate. Pry it off. 1 Quote Link to comment
Einbbx Posted November 29, 2016 Author Report Share Posted November 29, 2016 Got it off! Was stuck on hard, broken bolt was clipping it. Now for rethread.. either this bolt hole isn't 1/2 or my threading tool is not 1/2. Slightly aggro about this. Trying to find the right one to rethread this sucker. 1 Quote Link to comment
Lockleaf Posted November 30, 2016 Report Share Posted November 30, 2016 Not half. It's metric. M12 is likely the diameter 1 Quote Link to comment
Einbbx Posted November 30, 2016 Author Report Share Posted November 30, 2016 Is there a part number for those flexplate shims/spacers? 1 Quote Link to comment
Einbbx Posted November 30, 2016 Author Report Share Posted November 30, 2016 Oh snap, m12 no wonder I have the wrong tap kit.. also I believe the part number is 12330 and 12333 for the back and front spacer (in that order) 1 Quote Link to comment
Charlie69 Posted November 30, 2016 Report Share Posted November 30, 2016 Send me a PM I have extra set of spacers if I can find them. Quote Link to comment
Charlie69 Posted November 30, 2016 Report Share Posted November 30, 2016 This is what I have extra, The crank bolt thread size is 12mmx 1.25mm 1 Quote Link to comment
