78savage Posted October 6, 2008 Report Share Posted October 6, 2008 Where can you buy new R&P for the H190? I have searched some suppliers and I can not find the gears that I want. They have to be around a 3.40, and Im not sure if they are available.. I would like to find out before I go and build a 9", and spend too much. Thanks, Darren Quote Link to comment
yello620 Posted October 6, 2008 Report Share Posted October 6, 2008 3.70 gears are the lowest numerical # gear that i have heard of for a H190. Jason Quote Link to comment
banzai510(hainz) Posted October 17, 2008 Report Share Posted October 17, 2008 find a Nissanmotorsport book and get the part #s and go to nissanparts.cc and enter them if motorsport part eneter M- then the part # Quote Link to comment
datsunaholic Posted October 18, 2008 Report Share Posted October 18, 2008 H190s came in gear ratios from 3.700-5.429. 3.700 3.889 (known as the 3.90) 4.111 4.375 4.625 4.875 (known as the 4.88) 5.142 5.429 Last 2 were NISMO only units. Quote Link to comment
Dime Dave Posted November 11, 2008 Report Share Posted November 11, 2008 Hate to bring this one back up but the H190 axle in the '83 200SX uses a 3.54 gear, in a cast iron center section, don't know if that helps. I have an open diff one in the barn that I'd part with for $75 if you are interested. Splines match the truck not the roadster/510 wagon. Dave Patten Dunbarton, NH dwpatten@gsinet.net Quote Link to comment
datzenmike Posted November 11, 2008 Report Share Posted November 11, 2008 (edited) I think the '83 200sx uses an H-165-B 3.70 solid axle. The lowest H-190 I know of is in the '84-'86 720 with mileage option Z20 engine with a ratio of 3.364. Which is close to 3.40 Edited November 11, 2008 by datzenmike Quote Link to comment
Dime Dave Posted November 12, 2008 Report Share Posted November 12, 2008 Mike, I didn't know the 720 had such a tall gear, 3.364 would be a good Bonneville gear. With some digging I found hat ratio was also in the Maxima diesel from 7/80 to 6/82. The last of the 200SX solid axle cars had a H190 rear, 7/81 to the end. 6/81 and earlier had the H165. H190 has 10 bolts holding the carrier to the housing, the H165 has 8 bolts. Quote Link to comment
datzenmike Posted November 12, 2008 Report Share Posted November 12, 2008 (edited) Dave I love this site. Always something to learn. Thanks for that info. The mileage option 720 used a Z20(S) engine with 9.4 compression featuring an electronic detonation control system that adjusts timing in response to signals from a knock sensor in the head. This is an odd duck motor rear end combination that never really was accepted by the public. Likely because of it's lazy performance. Edited November 12, 2008 by datzenmike Quote Link to comment
RacnJsn95 Posted November 13, 2008 Report Share Posted November 13, 2008 With some digging I found hat ratio was also in the Maxima diesel from 7/80 to 6/82. You must be talking about the Maxima Diesel wagon, eh? My Maxima sedan has IRS. Didn't the 78+ 510 wagon have an H190? Quote Link to comment
Duncan Posted November 13, 2008 Report Share Posted November 13, 2008 (edited) Check this site. I've bought a couple of NOS R&P's from them and the price has been great both times. http://www.oem-surplus.com/nwp/index.htm I just checked and they have the 3.545 r&p in stock. 8211 8306 720 Truck : 2WD. (T+K/CAB). Z24 8107 83 200SX : Z22E.MT 8007 84 Maxima : W.L24E.MT.F5 : 39/11 = 3.545 H190 You need to CALL them for a price. I've bought two NOS units from them, and the price has been $125.00 or so both times. Edited November 13, 2008 by Duncan Quote Link to comment
datsunaholic Posted November 13, 2008 Report Share Posted November 13, 2008 Didn't the 78+ 510 wagon have an H190? No, the '78-81 510 (all versions, not just the wagon) had a H165. Only difference between the wagons and the sedan/HB was the Sedan/HB had 4-link coil spring suspension and the wagon used leaf springs. Quote Link to comment
athoose Posted March 30, 2009 Report Share Posted March 30, 2009 A few questions What models have an H190a-ml 12mm ring gear that is higher (numerically) than 3.73? Is the H190b ring gear interchangeable with the H190a? Thanks! Quote Link to comment
datzenmike Posted March 30, 2009 Report Share Posted March 30, 2009 Good question.. I don't know. Wouldn't it be easier to just pull the 'bum' (or third member) out and just swap it as a unit? Here's an H-190-AL: http://i138.photobucket.com/albums/q251/datzenmike/rearendNissanH190aluminumcarrierLSD.jpg[/img]"] (I think that's an LSD so this may be from a Roadster) Quote Link to comment
Bugeye Posted March 30, 2009 Report Share Posted March 30, 2009 (I think that's an LSD so this may be from a Roadster) that would be an lsd, notice the clutch discs Quote Link to comment
athoose Posted March 30, 2009 Report Share Posted March 30, 2009 Good question.. I don't know. Wouldn't it be easier to just pull the 'bum' (or third member) out and just swap it as a unit? I am looking at installing an LSD, so I will be breaking it down. But any info on the differences between the 190a and b would be useful. Quote Link to comment
Dime Dave Posted April 3, 2009 Report Share Posted April 3, 2009 (edited) For some good Nissan LSD info go to this site: http://www.gordon-glasgow.org/lsdtech.html From the information there 4:11/4.375 is the breakpoint between the A/B differentials. I do not have a copy of my Nissan Comp catalog handy to verify which is the A or B. The difference between the A and B LSD's is the position of the ring gear flange. The one for the 4.375 is closer to the pinion gear and will only work with the 4.375 and higher ratios. The one for 4.11 and below will work with all ratios, but requires a spacer between the ring gear and LSD unit if you are using a 4.375 or higher ratio. My Datsun 1200 uses an H190 rear. The 4.625 ratio I just had installed required the spacer behind the ring gear to get the proper gear engagement. Additional LSD and ratio information is also available in the Bob Sharp's Datsun Competition Prep Manual (for Roadsters) on line at the following link: http://www.datsun.org/roadster/info/dcpm11.pdf I realize this doesn't help fully, but might give you enough information to ask the right questions. Edited April 3, 2009 by Dime Dave 1 Quote Link to comment
Duncan Posted April 3, 2009 Report Share Posted April 3, 2009 Check this site http://www.oem-surplus.com/nwp/index.htm You can browse OEM parts by model of car, or look lower on the page and browse by part-type (radio,driveshaft, etc, etc) CALL THEM before you buy anything to verify stock and price. I have had very good luck with them. Quote Link to comment
pl521sss Posted April 3, 2009 Report Share Posted April 3, 2009 For some good Nissan LSD info go to this site:http://www.gordon-glasgow.org/lsdtech.html From the information there 4:11/4.375 is the breakpoint between the A/B differentials. I do not have a copy of my Nissan Comp catalog handy to verify which is the A or B. The difference between the A and B LSD's is the position of the ring gear flange. The one for the 4.375 is closer to the pinion gear and will only work with the 4.375 and higher ratios. The one for 4.11 and below will work with all ratios, but requires a spacer between the ring gear and LSD unit if you are using a 4.375 or higher ratio. My Datsun 1200 uses an H190 rear. The 4.625 ratio I just had installed required the spacer behind the ring gear to get the proper gear engagement. Additional LSD and ratio information is also available in the Bob Sharp's Datsun Competition Prep Manual (for Roadsters) on line at the following link: http://www.datsun.org/roadster/info/dcpm11.pdf I realize this doesn't help fully, but might give you enough information to ask the right questions. Thanks for this info Dave!! Your name sounds familiar Think you won many big races and one not too long ago Quote Link to comment
athoose Posted April 4, 2009 Report Share Posted April 4, 2009 Thanks for the links Dime Dave. I think you 1 Quote Link to comment
