the510keeper
Chris' 68 4 door bluh bluh bluh Datsun
Started this project in March 2013, wow time flies. Actually picked it up then but knew it would not be started for awhile.
Chris lives in Socal and we were heading to Eagle Rock so figured we would kill 2 birds 1 stone.
Car had been at a body shop down there for sometime and nothing was getting done nor was it getting done right.
I don't have many pics of before but a few of now.
Trying to wrap up old projects in the shop so this is next to go.
We stripped the car chemically and left it to rust
Needed a front radiator support, inner left fender well, and a T/C rod mount
Chris has some cool GL taillights he also wanted to use.
G/L taillights are like bluebird taillights as far as the mods needed. I have done this mod on 4 cars, so no problem.
Share this post
Link to post
Extra clip
drilling spot welds
This is a repair the other shop did, yep bondo
Had to fix the damage to the upper frame
  • Like 4
Share this post
Link to post
The upper frame was pushed down an inch, so I had to heat up the damaged area while lifting the end of the frame with a jack, pushed it right back in place.
Found a cherry hood to work with fitment, already had this hood on and off this car 20+ times
  • Like 6
Share this post
Link to post
yet another awesome build that i'm sure to be jealous of. B)
Share this post
Link to post
installed the radiator support realized shit didn't line up with the hood
So I made a red neck frame rack in my booth using the door jambs as solid posts, what a fucking day that was.
  • Like 3
Share this post
Link to post
Once I got the hood to fit, I had to make the left side look like the right side, 68s had a spot welded plate not a bump, the 72 inner fender well had a bump.
So I shaved it.
20150407_180346_resized_2_zpsw7svrfdz.jp
On to the trunk lid, Its been the straightest part on the car
Off to blast the complete car, there is a shop in Medford so I took a 10 hour road trip
  • Like 5
Share this post
Link to post
What shop in Medford does the blasting? I never had any luck with sand blasters when I lived there
Share this post
Link to post
James you make this stuff look so easy
and I know its not
nice work
Share this post
Link to post
You seem to perform magic on things that most people would consider scrap. I look forward to seeing where this goes, very nice work.
-Jack
Share this post
Link to post
Some of these steps have been gone over before but for the new guys and gals and the owner, here it goes.
Seam sealed with a 2-part seam sealer the trunk area using the factory rubber we pulled (goes between the inner quarter panel and the trunk floor).
We salvage the used rubber, clean all the old hard and cracking seam sealer off, clean with lacquer thinner, then scuff with used sand paper.
Once ready we seam seal first the gap where the rubber fits into, while seam sealer is wet install the rubber then seam seal over it. Smoothing it with a throw away brush. Of course you need to blow out the crap and vac any remain crap out.
Once seam sealed we take a house painting roller and brush and roll and brush a DTM oil enamel chassis paint. The roller helps seal factory gaps in sheet metal.
Car came with doors but they needed more work then doors I have, so to save time I used 4 of my doors to make less work.
I stripped these sanded them with 80grit on a DA, metal prepped them and sprayed an epoxy reinforced urethane primer surface 3 coats. Ready for the 1st blocking.
  • Like 4
Share this post
Link to post
Let me know if this is boring ya all
Sealed the inside of the roof and everything
  • Like 3
Share this post
Link to post
Next step radiator support welded on,
In order to do this successfully you need to bolt up the entire front clip.
20150629_172501_resized%201_zps9ntfhnmi.
The back of the hood was limp in the middle, so ez fix is to shove a board under it and lower it down to push the damage in to place.
No bad for a poor white boy from Linda :)
  • Like 6
Share this post
Link to post
Had to remove this piece to get the inner fender off, now we need to put it back
Used a weld through primer on the back side
20150702_165148_resized%201_zpsyohqogdb.
  • Like 3
Share this post
Link to post
I love seeing tricks people do that I will forget and forget where I saw it when the time comes for me to try it.
As always, lookin good.
Share this post
Link to post
Hey James,
 Does that DTM oil enamel chassis paint come in any other color besides black?
Share this post
Link to post
This thing had a blown out antenna hole, so we fixed it. And shaved the wiper stubs.
Share this post
Link to post
Also had broken bumper bracket nuts so we welded new ones in to place using 280zx top strut nuts. Same tread pattern and large 17mm head to weld to.
Using a bumper bracket to insure there welded in the right place.
Share this post
Link to post
Shaving the wiper stubs
Heated the area up to red hot hammer and dolly flat, using a socket make a circle, using a carbide bit duplicate that circle, use same socket and scrap piece of sheet metal cut out a circle and weld that sucker in there
welded in this part
20150702_171345_resized%201_zpsdpa4wyxq.
Fit pretty good considering everything that went on
Left side on the hood hinge holes were opened up for a larger bolts so we need them to match the other side, weld them up and make drill em out.
20150702_174946_resized%201_zpsjo1uajeo.
Share this post
Link to post
Got a bunch of old pics on the build, summer 2013
these 2 pics are from previous work that was done on the car. I always wondered how long the paint job would of stayed on
Share this post
Link to post
welded in this part20150702_171345_resized%201_zpsdpa4wyxq.20150702_165152_resized_zpsasoys21d.jpgFit pretty good considering everything that went on20150702_165201_resized_zpsdni8g3zy.jpg20150704_155428_resized_zpsijgkqs9p.jpg
Morning, have a question. Whats the purpose welding that plate together on the suspension towers and upper side of the car..? It's because the alignment work you did heat torch,stretching and compressing shaping back to its normal place and the plates will hold and give more support to the damage area that was corrected?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
