Giantsfan98 Posted February 11, 2015 Report Share Posted February 11, 2015 I was wondering,which way you think I should go I have a 4.3 and a 305 motors in my garage. And I want to put one of them in my 75 620 I Just got the frame I'm going to use it will be 4 wd with a 6 inch lift and on 33s so I was just wondering which motor would be best for this build Quote Link to comment
datzenmike Posted February 11, 2015 Report Share Posted February 11, 2015 4.3... a V6 is more likely to fit. I also had a 305 and measured it front to back and there's no room for the rad and the grill. 1 Quote Link to comment
Z-train Posted February 11, 2015 Report Share Posted February 11, 2015 Plus the 305 is a pile of shit. 2 Quote Link to comment
Stoffregen Motorsports Posted February 11, 2015 Report Share Posted February 11, 2015 So is the 4.3 for that matter. Is the 4.3 TBI or Vortec? 1 Quote Link to comment
datzenmike Posted February 11, 2015 Report Share Posted February 11, 2015 Plus the 305 is a pile of shit. Ha ha Well the cams in them sure are. Quote Link to comment
Giantsfan98 Posted February 11, 2015 Author Report Share Posted February 11, 2015 It's a vortex it came out of a 98 s10 they both need rebuilds so I will most likely be rebuilding the 4.3 Quote Link to comment
Stoffregen Motorsports Posted February 11, 2015 Report Share Posted February 11, 2015 I would never recommend a 4.3 TBI to anyone, but if it's a Vortec, I would use that one istead of the 305. How do you know it needs a rebuild? If it runs, do the swap with it running and then tear into it once you've got all the bugs worked out. When I do an engine swap, the motor comes in and out about 10 times before it's final anyway. Quote Link to comment
Dolomite Posted February 11, 2015 Report Share Posted February 11, 2015 4.3 vortec is better than a stock 305 all day long. Quote Link to comment
Z-train Posted February 11, 2015 Report Share Posted February 11, 2015 So is the 4.3 for that matter. Is the 4.3 TBI or Vortec? Since it has two more holes,it's the bigger pile of shit...by far. 1 Quote Link to comment
Giantsfan98 Posted February 11, 2015 Author Report Share Posted February 11, 2015 It runs like shit its knocking pretty bad so I was just gonna go for a rebuild Quote Link to comment
Giantsfan98 Posted February 11, 2015 Author Report Share Posted February 11, 2015 Well u guys r saying the 4.3 is also a piece of shit so what would be a good v6 motor for my build Quote Link to comment
denmarkboy Posted February 11, 2015 Report Share Posted February 11, 2015 As mentioned above the 4.3 is shorter always a bonus when your talkin datsun and swap in the same sentence . The 305 is a boat anchor at best , If you were thinking about v8 I would use something else . The challenge will be the same either way , the firewall is going to need work and so will the frame near the tranny mount,exhaust,driveline . All of these things are basically going to be the same . Quote Link to comment
denmarkboy Posted February 11, 2015 Report Share Posted February 11, 2015 Well u guys r saying the 4.3 is also a piece of shit so what would be a good v6 motor for my build 4.3 vortech is a good engine .i have never rebuilt one so i dont know what the cost will be . but i have had many of these engines over the years and 90% of them were very reliable and cheap to maintain . Quote Link to comment
Giantsfan98 Posted February 11, 2015 Author Report Share Posted February 11, 2015 Ok I have to do some research but this is the engine I'm gonna build Quote Link to comment
Power Tryp Posted February 11, 2015 Report Share Posted February 11, 2015 http://www.hotrod.com/how-to/engine/113-0208-chevy-43l-262ci-v6-engine-build/ I gotta say 4.3 Quote Link to comment
Stoffregen Motorsports Posted February 11, 2015 Report Share Posted February 11, 2015 Do you have any emissions testing in NC? If not, the sky's the limit as for engine swaps. How about a GM 3800SC? It's a 3.8L supercharged V6. Nissan VG would be an easy swap, but I don't particularly like those. Not much HP for the trouble. It's going to cost $1000 minimum to build that 4.3. What trans would you run behind it? Quote Link to comment
Dolomite Posted February 11, 2015 Report Share Posted February 11, 2015 Shit, forgot 4x4. My buddy had a 4.3 in a yota, not sure what trans he used though. I'll try to get hold of him to see. It was a 5spd but not sure what out of. Quote Link to comment
Giantsfan98 Posted February 12, 2015 Author Report Share Posted February 12, 2015 No there is no emissions test down here I'm trying to figure out what 6 cylinder to use I want one with some power Quote Link to comment
Giantsfan98 Posted February 12, 2015 Author Report Share Posted February 12, 2015 And if I do use the 4.3 I will have to find a new trans anyway the one that was in the truck it came out of was shot Quote Link to comment
Giantsfan98 Posted February 12, 2015 Author Report Share Posted February 12, 2015 Is there a better v6 out there that has more aftermarket parts fit it that would be a good engine for my build.... Quote Link to comment
Giantsfan98 Posted February 12, 2015 Author Report Share Posted February 12, 2015 It needs to be gm though so it will bolt to my t5 5 speed so. The transfer case will work its. I'm setting my 620 body on a s10 frame becuz my frame is trashed it's a lot of fab work but I can do it Quote Link to comment
DaBlist Posted February 12, 2015 Report Share Posted February 12, 2015 For crawling around in the woods and rocks in a smaller rig you can't go wrong with the GM 4.3. I'm not a fan of guys bouncing off of the rev limiter offroad trying to get the job done with low torque engines Quote Link to comment
Giantsfan98 Posted February 12, 2015 Author Report Share Posted February 12, 2015 I understand my only problem is from what I've read the heads suck ass as far as airflow Quote Link to comment
Lockleaf Posted February 12, 2015 Report Share Posted February 12, 2015 Then get vortec heads Quote Link to comment
