bigboy620 Posted April 21, 2023 Author Report Share Posted April 21, 2023 41 minutes ago, RyanC said: Good looking truck, love how fat the rears can be with flares what size rubber are you running? I have 265s sitting on the rear, no body to worry about as its a tray back, yet to test them out. Thank you! Needs some tlc been sitting for awhile. I have 265x60r15 on some 15x12 wheels. Fronts are 15x10 with 225x50r15. I had to raise the rear to have more clearance for the under bed turbo. Now there is more room for more rubber aha Quote Link to comment
RyanC Posted April 21, 2023 Report Share Posted April 21, 2023 Now to get those mixtures right, interested to see how much she makes and how the sniper handles the turbo. Don't see much info/youtube infor with it setup with turbos and config etc. What boost is it at now? Quote Link to comment
bigboy620 Posted April 21, 2023 Author Report Share Posted April 21, 2023 6 minutes ago, RyanC said: Now to get those mixtures right, interested to see how much she makes and how the sniper handles the turbo. Don't see much info/youtube infor with it setup with turbos and config etc. What boost is it at now? 8lbs. Once everything gets dialed in. Let's hope it makes good HP. Quote Link to comment
datzenmike Posted April 21, 2023 Report Share Posted April 21, 2023 8 hours ago, bigboy620 said: It's on the ground! Took it for a spin. Man i forgot the effort the non power steering system takes aha. Needs some more fine adjustment. It bogs under slight acceleration. There's many parameters to adjust on this sniper EFI. But man this thing feels like it's going to fly 💸 I had 31 x 10.5s at one time and had to park across the lot at WallMart so I could just get in and drive away. It was manageable when moving but was not nimble. It was s l o w to maneuver if you suddenly had to avoid something. 1 Quote Link to comment
bigboy620 Posted April 22, 2023 Author Report Share Posted April 22, 2023 13 hours ago, datzenmike said: I had 31 x 10.5s at one time and had to park across the lot at WallMart so I could just get in and drive away. It was manageable when moving but was not nimble. It was s l o w to maneuver if you suddenly had to avoid something. It sucks making 3 point u turns aha. Since my turning radius is limited do to the offset of the wheels. 🥲 Quote Link to comment
datzenmike Posted April 22, 2023 Report Share Posted April 22, 2023 I designed a bracket and mounted a Hardbody PS pump and used a '79 280zx PS box on the 620. Insane but it worked perfectly and eventually 33 x 12" tires. Quote Link to comment
bigboy620 Posted April 22, 2023 Author Report Share Posted April 22, 2023 8 minutes ago, datzenmike said: I designed a bracket and mounted a Hardbody PS pump and used a '79 280zx PS box on the 620. Insane but it worked perfectly and eventually 33 x 12" tires. Did you mount it on the driver side of the engine? I'm curious. Quote Link to comment
bigboy620 Posted April 22, 2023 Author Report Share Posted April 22, 2023 DRIVE NUMBER 3 WAS SUCCESSFUL. I have to adjust my throttle cable as I floor it and pedals literally hits the floor. The throttle is only 74% open according to the TPS. Man the work that has gone into it feels good 😊. 5 Quote Link to comment
RyanC Posted April 23, 2023 Report Share Posted April 23, 2023 Sounds good on the road, was good to see in the Youtube feed this morning. What size is your exhaust? 3 inch? 2 Quote Link to comment
bigboy620 Posted April 24, 2023 Author Report Share Posted April 24, 2023 12 hours ago, RyanC said: Sounds good on the road, was good to see in the Youtube feed this morning. What size is your exhaust? 3 inch? It sounds way better in person. I was driving it without the quad tips. Just the cherry bomb extreme 1 to 2 outlets muffler. I raised the rear and it interfered with the exhaust. And the tips were way too low. It sounds deep without the tips. I welded them back on yesterday. Stock headers to 1"-7/8 to merge collector. From there it goes to 2" about to where the cab ends, then it's 2-1/2 to turbo and then to glass pack with dual outlets that lead to quad tips. Quote Link to comment
bigboy620 Posted April 24, 2023 Author Report Share Posted April 24, 2023 Sounds real crisp with the tips. Quote Link to comment
bigboy620 Posted April 27, 2023 Author Report Share Posted April 27, 2023 Registered and insured. READY TO ROLL ! 1 Quote Link to comment
six2ohyea Posted April 27, 2023 Report Share Posted April 27, 2023 Congrats!! 1 Quote Link to comment
bigboy620 Posted April 27, 2023 Author Report Share Posted April 27, 2023 (edited) Drove it for 30 mins at cruising speeds. Seems to be doing fine. Just killed a bunch of bugs 😞🐛. Couple more touch ups here and there. Had to space the hood to clear the carb hat. Edited April 27, 2023 by bigboy620 Quote Link to comment
RyanC Posted April 27, 2023 Report Share Posted April 27, 2023 Those tips are a little small aren't they!! Great work on getting it all legal. 2 Quote Link to comment
thisismatt Posted April 27, 2023 Report Share Posted April 27, 2023 So what was/is your smog status/solution? 1 Quote Link to comment
bigboy620 Posted April 27, 2023 Author Report Share Posted April 27, 2023 It passed smog with flying colors 😜 1 1 Quote Link to comment
bigboy620 Posted April 29, 2023 Author Report Share Posted April 29, 2023 Driving this thing thru town makes the truck look like a celebrity aha. Breaks necks for sure 😁 Quote Link to comment
paradime Posted April 30, 2023 Report Share Posted April 30, 2023 5 hours ago, bigboy620 said: Driving this thing thru town makes the truck look like a celebrity aha. Breaks necks for sure 😁 As it should. You did a great job. Well done Dattos are celebrities anywhere you go. Have fun snapping necks bro. 1 Quote Link to comment
bigboy620 Posted April 30, 2023 Author Report Share Posted April 30, 2023 21 hours ago, paradime said: As it should. You did a great job. Well done Dattos are celebrities anywhere you go. Have fun snapping necks bro. Thank you! We will always find ways to keep improving our datsuns! Quote Link to comment
paradime Posted April 30, 2023 Report Share Posted April 30, 2023 1 hour ago, bigboy620 said: Thank you! We will always find ways to keep improving our datsuns! True Dat... 1 Quote Link to comment
bigboy620 Posted May 3, 2023 Author Report Share Posted May 3, 2023 New headlights look real nice! Hard to get a good picture that'll do them justice. 2 Quote Link to comment
six2ohyea Posted May 3, 2023 Report Share Posted May 3, 2023 Head lights from where? Quote Link to comment
bigboy620 Posted May 4, 2023 Author Report Share Posted May 4, 2023 19 hours ago, six2ohyea said: Head lights from where? Amazon HOYUZA 5 3/4 Headlight with White Halo DRL and Yellow Light 5.75 Inch Motorcycle Headlight Compatible with Harley Sportster 1200 Triple Dyna Low River Wide Glide Iron 883 Street Bob https://a.co/d/iyphNVc 1 Quote Link to comment
bigboy620 Posted May 4, 2023 Author Report Share Posted May 4, 2023 They fit perfectly. Quote Link to comment
