bigboy620 Posted March 28, 2023 Author Report Share Posted March 28, 2023 9 hours ago, RyanC said: Like the bloke here in Australia with a viper v12 in a 1200 ute! I just noticed your using a sniper throttle body. Been thinking about this setup on an L series be interested to see how it goes when running etc. You mean a viper V12 with a Ute attach to it aha. We'll see how this runs with it. Quote Link to comment
RyanC Posted March 28, 2023 Report Share Posted March 28, 2023 (edited) Here is the ute, sorry vipers are v10 whoops https://www.whichcar.com.au/events/summernats/datsun-1200-ute-with-twin-turbo-viper-v10-swap-debuted-at-summernats-35 are you running the sniper or super sniper? Whats the plan on how much booost? Edited March 28, 2023 by RyanC Quote Link to comment
bigboy620 Posted March 29, 2023 Author Report Share Posted March 29, 2023 5 hours ago, RyanC said: Here is the ute, sorry vipers are v10 whoops https://www.whichcar.com.au/events/summernats/datsun-1200-ute-with-twin-turbo-viper-v10-swap-debuted-at-summernats-35 are you running the sniper or super sniper? Whats the plan on how much booost? Thats a really nice looking Ute. Super sniper with an external boost reference fpr and a DUI distributor. Going for 7-8 psi. Quote Link to comment
hobospyder Posted March 30, 2023 Report Share Posted March 30, 2023 On 3/28/2023 at 3:28 PM, RyanC said: Here is the ute, sorry vipers are v10 whoops https://www.whichcar.com.au/events/summernats/datsun-1200-ute-with-twin-turbo-viper-v10-swap-debuted-at-summernats-35 are you running the sniper or super sniper? Whats the plan on how much booost? Damn that thing is all in there 1 Quote Link to comment
bigboy620 Posted March 30, 2023 Author Report Share Posted March 30, 2023 The dizzy is finally in! Along with the fpr. Been back to work this week, so the progress is going to slow down. 😑 3 Quote Link to comment
bigboy620 Posted April 2, 2023 Author Report Share Posted April 2, 2023 External water pump mounted. 1 Quote Link to comment
bigboy620 Posted April 2, 2023 Author Report Share Posted April 2, 2023 Expansion tank and overflow. Fuel system is done. 2 Quote Link to comment
RyanC Posted April 4, 2023 Report Share Posted April 4, 2023 (edited) Looking good, is there no room for radiator and intercooler upfront? Here in Australia with the 510's often a n14 pulsar radiator is used as its narrower and the intercooler is behind the grill ..or replaces it. Maybe they are putting the sr20's and fj's harder to the firewall? How much room from rear of engine to firewall? Is this because of other plumbing? Sorry not critisizing just questions 👍 Edited April 4, 2023 by RyanC 2 Quote Link to comment
bigboy620 Posted April 4, 2023 Author Report Share Posted April 4, 2023 There was room but very little. It was too hot inside the engine bay. If i would have just relocated the turbo to the back I probably would have been fine. But knowing me I like to get myself into fun and challenging projects. Quote Link to comment
bigboy620 Posted April 4, 2023 Author Report Share Posted April 4, 2023 (edited) Edited April 4, 2023 by bigboy620 Quote Link to comment
RyanC Posted April 5, 2023 Report Share Posted April 5, 2023 (edited) Yes and you have the issue of the steering, brake and clutch where the turbo could be sitting which we do here in australia. Heaps of room around the v6 if you take out the turbo or are RHD like us and can run the exhaust around to the LHS. Alwasy though a VG30e/de in a 510 woule be fun when I had it but hard here due to restrictions. The 620 has heaps more room though. Thanks for those pics great to see clearances etc Edited April 5, 2023 by RyanC 1 Quote Link to comment
bigboy620 Posted April 5, 2023 Author Report Share Posted April 5, 2023 1 hour ago, RyanC said: Yes and you have the issue of the steering, brake and clutch where the turbo could be sitting which we do here in australia. Heaps of room around the v6 if you take out the turbo or are RHD like us and can run the exhaust around to the LHS. Alwasy though a VG30e/de in a 510 woule be fun when I had it but hard here due to restrictions. The 620 has heaps more room though. Thanks for those pics great to see clearances etc That's why I'm doing it! Because it's challenging fun aha. 1 Quote Link to comment
bigboy620 Posted April 6, 2023 Author Report Share Posted April 6, 2023 How much oil flow would the turbo need? Would it hurt it, if i had a constant flow even at idle. I will see if i can control pumps with Holley super sniper ecu. I have a speed control that works nice. From a couple rpms to ALOT shah. Also have a needle valve with a bypass hose going back to the reservoir. To adjust flow direction. Any opinions greatly appreciated. Quote Link to comment
Stoffregen Motorsports Posted April 6, 2023 Report Share Posted April 6, 2023 I do know that if you get too much oil in the turbo, it will most likely show up in the exhaust as blue smoke. Too much oil in a turbo is mostly from an insufficient drain hose. 1 Quote Link to comment
bigboy620 Posted April 6, 2023 Author Report Share Posted April 6, 2023 (edited) It's going to have a constant flow, since the pump if going to draw from the oil tank and the turbo drain at the same time. Two check valves to help from oil going back to the turbo Edited April 6, 2023 by bigboy620 1 Quote Link to comment
bigboy620 Posted April 10, 2023 Author Report Share Posted April 10, 2023 Engine is 98% done. Now gotta do the in dash wiring.😂 1 Quote Link to comment
bigboy620 Posted April 11, 2023 Author Report Share Posted April 11, 2023 The cockpit. Quote Link to comment
bigboy620 Posted April 11, 2023 Author Report Share Posted April 11, 2023 The pilot and co pilot! 4 Quote Link to comment
bigboy620 Posted April 15, 2023 Author Report Share Posted April 15, 2023 Just want to leave this here. https://youtube.com/shorts/IAqytRbEg8E?feature=share 3 Quote Link to comment
bigboy620 Posted April 15, 2023 Author Report Share Posted April 15, 2023 It runs!!! Now to fine tune everything! Wanted to make sure it was going to start! 3 Quote Link to comment
bigboy620 Posted April 17, 2023 Author Report Share Posted April 17, 2023 That sound! https://youtube.com/shorts/pWLXBnXU-S0?feature=share 2 Quote Link to comment
RyanC Posted April 17, 2023 Report Share Posted April 17, 2023 Sounding good. 1 Quote Link to comment
bigboy620 Posted April 21, 2023 Author Report Share Posted April 21, 2023 It's on the ground! Took it for a spin. Man i forgot the effort the non power steering system takes aha. Needs some more fine adjustment. It bogs under slight acceleration. There's many parameters to adjust on this sniper EFI. But man this thing feels like it's going to fly 💸 1 Quote Link to comment
RyanC Posted April 21, 2023 Report Share Posted April 21, 2023 Good looking truck, love how fat the rears can be with flares what size rubber are you running? I have 265s sitting on the rear, no body to worry about as its a tray back, yet to test them out. 1 Quote Link to comment
