...datlife......always Bustin' Nuts......
......aaaaaaand just when you think you're done......
............you're not........
This car gave me a shit ton of grief.......
.......got it running and ran great.....
First break in drive I got stuck in 5 minutes of traffic and it started warming up........ :poop:
....I ended up having multiple issues before it finally left... :poop:
Temp sensor for the aftermarket pusher fan was not turnung the fans on soon enough...
...tried hard wiring a switch in.....still warmed up in traffic....
.....changed to a cooler t-stat......still warmed up.....
Fuckin piece of shit VW radiator......finally got a Koyo.....got rid of the stupid pusher fan.....
...but guess what....they cut out the radiator support....so had to make a bracket.... :no:
.....added a fixed fan and BAM.........good to go.....
3 days later...........head gasket starts leaking coolant externally......
......I gave you one last chance FELPRO....you are truly :poop:  :poop: :fu:
Redo head gasket and FINALLY continued with break in.........
E06A502B-6EAE-4B9B-91E2-2FC21A51F2E5_zps
C3E2D31D-75F9-47C2-9C25-2FD7E4A665EF_zps
B030A74D-E17B-43B9-B59F-CCEC34AC8BB3_zps
  • Like 3
  • Replies 1.4k
Do you think the headgasket went because it ran hot, or do you think that was unrelated?
I always found bad radiators to cause heating up when the car was in motion... usually under load like climbing a long grade or whatever. If the car cools down as soon as it's in motion but heats up again when it's not, like in traffic, it's probably got enough radiator but not an efficient enough fan.
I had a 70 Dodge Dart a while ago that I swapped a 400 v8 into, I also put the biggest aluminum radiator I could fit.... it was massive. Even though it was a big block with only a flex fan it ran too cool actually, to the point where the temp needle was barely reading anything, except idling. If it SAT even for a short period or would boil over.
Finding the appropriate fan setup solved that problem.
It may have been....but I never let it get past 220-230........shouldn't have leaked........
where do you get all these L20b from?  i can't even find 1.
:ninja:
Actually.....one was an L18....I think a canada model or something....
....smog stuff was missing....has a nice exhaust mani without the air injection ports :thumbup:
....crank pulley had only one groove also.....
12B7997D-E8EE-40D7-A8AD-F725B0806E76_zps
  • Like 3
were is all this money coming from
Don't need monies for these....... :sneaky:
Is this your car.
Negative....belongs to CanYouSpareADime.....
I want 1. Just 1 :(
.....what he said..........vv
If you ever take a trip north.. you can basically get them for nothing.
Shit....if you guys can store a couple of them for me I'll make a run up there to grab them.......
.......and have some beers with everyone of course!! :thumbup:  :thumbup:
the L20 core is yours if your come up to get it, but thats what I've said to a few people aleady. Its still just sitting here
I'll be makin a trip up this year......not just Canby.....
.....if you still have it.....I'll take it!!
One LZ.......just stole some parts off it......
C158CB37-1826-4857-B62B-205CF3C56860_zps
E2A09932-45DF-4C61-83A7-14D952DF0F63_zps
This appears to be just a Z, not LZ. Or is it a ZL, a Z head on an L block...that seems mostly useless...
  • Busta Nut changed the title to ...datlife......always Bustin' Nuts......
