Charlie69 Posted June 23, 2015 Report Share Posted June 23, 2015 There should be a law with having that much Datsuns in one place. Lol Why? Quote Link to comment
Busta Nut Posted July 14, 2015 Author Report Share Posted July 14, 2015 I should be back at it this week...... ^^.......so much for that plan......... OK.........let's go...... 1 Quote Link to comment
Busta Nut Posted July 14, 2015 Author Report Share Posted July 14, 2015 Got the L20 on a stand...... .......this is the first good look I've had at it..... Nut's inside number four.......and the whole looks a little big....... ........don't know if they make spark plug sleeves that big.......anyone?? :confused: I did get a ratchet on the crank......it was rough to turn at first but it eventually freed right up...... .....youtube won't upload the vid...... I had it going so good that oil started coming out of the filter stand..... .......air was blowing out of all 4 cylinders also.... Good candidate for the next engine.......this one will go to CanYouSpareADime...... ........he'll be up here in a few weeks for the swap... 2 Quote Link to comment
Kalani Posted July 14, 2015 Report Share Posted July 14, 2015 LETS GET TO IT!! 3 Quote Link to comment
q-tip Posted July 14, 2015 Report Share Posted July 14, 2015 They make a welder that fills a hole that big. But you might be able to get a thread insert that will be that big. 1 Quote Link to comment
Busta Nut Posted July 15, 2015 Author Report Share Posted July 15, 2015 Time-sert? :confused: Quote Link to comment
Draker Posted July 15, 2015 Report Share Posted July 15, 2015 http://www.timesert.com/ 1 Quote Link to comment
Draker Posted July 15, 2015 Report Share Posted July 15, 2015 timesert > helicoil $$$$$$ $ Quote Link to comment
Busta Nut Posted July 15, 2015 Author Report Share Posted July 15, 2015 timesert > helicoil $$$$$$ $ Yes.....but I don't think heli coil makes one that thick..... ........I'll see what my machine shop recommends...... Thx Draker.......... Quote Link to comment
Draker Posted July 15, 2015 Report Share Posted July 15, 2015 They'll fix you up right either way. 2 Quote Link to comment
q-tip Posted July 15, 2015 Report Share Posted July 15, 2015 Not time-sert, a key locking thread insert, the real thread insert. I think one for a spark plug would be close to an inch on the o.d. 2 Quote Link to comment
Lockleaf Posted July 15, 2015 Report Share Posted July 15, 2015 If nothing else, assuming the hole is LOTS bigger than the 14mm thread, it might be as easy as anything to have your machine shop cut you a custom insert that you cement in to the block. You could even thread the block and thread the insert in, custom helicoil style. 3 Quote Link to comment
Mattndew76 Posted July 15, 2015 Report Share Posted July 15, 2015 http://www.amazon.com/15-0mm-Time-Sert-Spark-Insert-44129/dp/B003SFSHCM http://www.amazon.com/TIME-SERT-14MM-Spark-Repair-4412E/dp/B0025NDK7U/ref=pd_bxgy_263_img_z http://www.amazon.com/LocTite-Threadlocker-High-Temp-Strength/dp/B003WRH8DA/ref=pd_sim_263_4?ie=UTF8&refRID=1WYP36N233X68ZN3BCRD 4 Quote Link to comment
Draker Posted July 15, 2015 Report Share Posted July 15, 2015 If nothing else, assuming the hole is LOTS bigger than the 14mm thread, it might be as easy as anything to have your machine shop cut you a custom insert that you cement in to the block. You could even thread the block and thread the insert in, custom helicoil style. You mean like this... http://www.timesert.com/html/5141S-short.pdf 2 Quote Link to comment
Lockleaf Posted July 15, 2015 Report Share Posted July 15, 2015 Yup. My point was simply that there are times one off custom can be preferable. Just putting that out there. Those are some seriously hardcore inserts those guys make. I've never heard of that company before. Good to know. 2 Quote Link to comment
Draker Posted July 15, 2015 Report Share Posted July 15, 2015 If you want something done right... time-sert. They make inserts for everything.. oil drain plugs, head bolts, main bearing caps.. etc. They are tough.. no shitty heli coil. They won't leak either. 4 Quote Link to comment
Kalani Posted July 15, 2015 Report Share Posted July 15, 2015 Firstdime gettin it the 4th spark plug socket is fucccccd. big enough for a rats head to get through.... SURPRISE!!! Homie wont have his nuts for winter! :sick: pistons and cylinders looked great :thumbup: :thumbup: :thumbup: :thumbup: 3 Quote Link to comment
Busta Nut Posted July 15, 2015 Author Report Share Posted July 15, 2015 Thx Kalani and Firstdime!! :thumbup: :thumbup: 2 Quote Link to comment
Busta Nut Posted July 15, 2015 Author Report Share Posted July 15, 2015 Burnt the valve in #4........ 1 Quote Link to comment
Farmer Joe Posted July 15, 2015 Report Share Posted July 15, 2015 what the fuck is in that cylinder?! 2 Quote Link to comment
