Busta Nut Posted March 4, 2017 Author Report Share Posted March 4, 2017 ......aaaaaaand just when you think you're done...... ............you're not........ This car gave me a shit ton of grief....... .......got it running and ran great..... First break in drive I got stuck in 5 minutes of traffic and it started warming up........ :poop: ....I ended up having multiple issues before it finally left... :poop: Temp sensor for the aftermarket pusher fan was not turnung the fans on soon enough... ...tried hard wiring a switch in.....still warmed up in traffic.... .....changed to a cooler t-stat......still warmed up..... Fuckin piece of shit VW radiator......finally got a Koyo.....got rid of the stupid pusher fan..... ...but guess what....they cut out the radiator support....so had to make a bracket.... :no: .....added a fixed fan and BAM.........good to go..... 3 days later...........head gasket starts leaking coolant externally...... ......I gave you one last chance FELPRO....you are truly :poop: :poop: :fu: Redo head gasket and FINALLY continued with break in......... 3 Quote Link to comment
Busta Nut Posted March 4, 2017 Author Report Share Posted March 4, 2017 MOAR.............. 4 Quote Link to comment
Busta Nut Posted March 4, 2017 Author Report Share Posted March 4, 2017 Helped out Demo..... 3 Quote Link to comment
Busta Nut Posted March 4, 2017 Author Report Share Posted March 4, 2017 Uh oh...... 1 Quote Link to comment
S30Jay Posted March 4, 2017 Report Share Posted March 4, 2017 Do you think the headgasket went because it ran hot, or do you think that was unrelated? I always found bad radiators to cause heating up when the car was in motion... usually under load like climbing a long grade or whatever. If the car cools down as soon as it's in motion but heats up again when it's not, like in traffic, it's probably got enough radiator but not an efficient enough fan. I had a 70 Dodge Dart a while ago that I swapped a 400 v8 into, I also put the biggest aluminum radiator I could fit.... it was massive. Even though it was a big block with only a flex fan it ran too cool actually, to the point where the temp needle was barely reading anything, except idling. If it SAT even for a short period or would boil over. Finding the appropriate fan setup solved that problem. Quote Link to comment
russaroll Posted March 4, 2017 Report Share Posted March 4, 2017 where do you get all these L20b from? i can't even find 1. 1 Quote Link to comment
Busta Nut Posted March 5, 2017 Author Report Share Posted March 5, 2017 Do you think the headgasket went because it ran hot, or do you think that was unrelated? I always found bad radiators to cause heating up when the car was in motion... usually under load like climbing a long grade or whatever. If the car cools down as soon as it's in motion but heats up again when it's not, like in traffic, it's probably got enough radiator but not an efficient enough fan. I had a 70 Dodge Dart a while ago that I swapped a 400 v8 into, I also put the biggest aluminum radiator I could fit.... it was massive. Even though it was a big block with only a flex fan it ran too cool actually, to the point where the temp needle was barely reading anything, except idling. If it SAT even for a short period or would boil over. Finding the appropriate fan setup solved that problem. It may have been....but I never let it get past 220-230........shouldn't have leaked........ where do you get all these L20b from? i can't even find 1. :ninja: Actually.....one was an L18....I think a canada model or something.... ....smog stuff was missing....has a nice exhaust mani without the air injection ports :thumbup: ....crank pulley had only one groove also..... 3 Quote Link to comment
Busta Nut Posted March 5, 2017 Author Report Share Posted March 5, 2017 This one is an L20......... :D 5 Quote Link to comment
mrbigtanker Posted March 6, 2017 Report Share Posted March 6, 2017 were is all this money coming from 1 Quote Link to comment
mrbigtanker Posted March 6, 2017 Report Share Posted March 6, 2017 I don't know where I left off but let's just assume this one is done........ Is this your car. Quote Link to comment
russaroll Posted March 6, 2017 Report Share Posted March 6, 2017 I want 1. Just 1 :( Quote Link to comment
Draker Posted March 6, 2017 Report Share Posted March 6, 2017 If you ever take a trip north.. you can basically get them for nothing. Quote Link to comment
Busta Nut Posted March 6, 2017 Author Report Share Posted March 6, 2017 were is all this money coming from Don't need monies for these....... :sneaky: Is this your car. Negative....belongs to CanYouSpareADime..... I want 1. Just 1 :( .....what he said..........vv If you ever take a trip north.. you can basically get them for nothing. 1 Quote Link to comment
HOGIE Posted March 6, 2017 Report Share Posted March 6, 2017 If you ever take a trip north.. you can basically get them for nothing. Was trying to give away a L20 core for months. Finally sold some dude the rods. Block, crank, and main caps still up for grabs locally Quote Link to comment
Busta Nut Posted March 6, 2017 Author Report Share Posted March 6, 2017 Shit....if you guys can store a couple of them for me I'll make a run up there to grab them....... .......and have some beers with everyone of course!! :thumbup: :thumbup: 1 Quote Link to comment
HOGIE Posted March 7, 2017 Report Share Posted March 7, 2017 the L20 core is yours if your come up to get it, but thats what I've said to a few people aleady. Its still just sitting here 1 Quote Link to comment
Busta Nut Posted March 7, 2017 Author Report Share Posted March 7, 2017 the L20 core is yours if your come up to get it, but thats what I've said to a few people aleady. Its still just sitting here I'll be makin a trip up this year......not just Canby..... .....if you still have it.....I'll take it!! 2 Quote Link to comment
Busta Nut Posted March 9, 2017 Author Report Share Posted March 9, 2017 Back to the engines I picked up......... Engine #1..... YIKES......... ......don't think this one's gonna make it...... 2 Quote Link to comment
Busta Nut Posted March 9, 2017 Author Report Share Posted March 9, 2017 One LZ.......just stole some parts off it...... 2 Quote Link to comment
Busta Nut Posted March 9, 2017 Author Report Share Posted March 9, 2017 Case in the office looks nice....... ...........for the moment..... 3 Quote Link to comment
Busta Nut Posted March 9, 2017 Author Report Share Posted March 9, 2017 Until this showed up............he saw the shiny things on 5Teezy and said........ I want that shit too...... 4 Quote Link to comment
Lockleaf Posted March 9, 2017 Report Share Posted March 9, 2017 One LZ.......just stole some parts off it...... This appears to be just a Z, not LZ. Or is it a ZL, a Z head on an L block...that seems mostly useless... 2 Quote Link to comment
KoHeartsGPA Posted March 9, 2017 Report Share Posted March 9, 2017 the L20 core is yours if your come up to get it, but thats what I've said to a few people aleady. Its still just sitting here Wasn't Ryan going to get it?, He asked me about it....Few months ago... 1 Quote Link to comment
