wobble Posted June 26, 2016 Author Report Share Posted June 26, 2016 I hate metal work. I'm still not finished, but we forge on 3 Quote Link to comment
Lockleaf Posted June 26, 2016 Report Share Posted June 26, 2016 Nicely done. Hand built rocker, I like it. 2 Quote Link to comment
Charlie69 Posted June 26, 2016 Report Share Posted June 26, 2016 Kicking ass on the metal work! Looks great. 1 Quote Link to comment
]2eDeYe Posted June 26, 2016 Report Share Posted June 26, 2016 Nicely done :cool: 2 Quote Link to comment
skyblue Posted June 27, 2016 Report Share Posted June 27, 2016 Woa!! Glad to see the truck is still moving forward. Agreed, great metal work. 1 Quote Link to comment
datzenmike Posted July 15, 2016 Report Share Posted July 15, 2016 Doesn't weld. Takes welding course. This! 3 Quote Link to comment
wobble Posted July 17, 2016 Author Report Share Posted July 17, 2016 It's been a blast working on the car. Getting close now I can't wait to get this thing going 1 Quote Link to comment
wobble Posted August 6, 2016 Author Report Share Posted August 6, 2016 I got some time to finish off the last panel Then things took a strange and unexpected turn. I got another Datsun! Its a parts car, it has a L20B with twin Dellorto carburetors floor shift, this will be a massive improvement on the J15 column shift. this a major departure from original plan of keeping its stock and just lowering it. but $750 for the lot was too cheap to pass up 4 Quote Link to comment
Charlie69 Posted August 6, 2016 Report Share Posted August 6, 2016 Keep the complete parts truck until you complete this build. If you have the room keep it after the build. You have the Datsun addiction, just live with it and enjoy! 2 Quote Link to comment
wobble Posted August 7, 2016 Author Report Share Posted August 7, 2016 So I checked out the motor a little more today the head on the L20b is an A87. The Dellorto's are DHLA40. 2 Quote Link to comment
banzai510(hainz) Posted August 7, 2016 Report Share Posted August 7, 2016 fucking COOL!!!!!!!!!!!!!!!! 1 Quote Link to comment
wobble Posted August 14, 2016 Author Report Share Posted August 14, 2016 Here's a couple of photos with the tray walls on 3 Quote Link to comment
wobble Posted August 14, 2016 Author Report Share Posted August 14, 2016 I started stripping the 620 this weekend So I have taken off the 620 the motor and box and drive line, I might take the diff i need to check the ratios in the 521, I will be taking the front brakes and brake booster. 4 Quote Link to comment
wobble Posted August 27, 2016 Author Report Share Posted August 27, 2016 I've been putting off doing this side, due to some previous accident damage the panel had been welded on. I had to cut the panel off to fix the rust and I decided to just weld it back on. Done. I used Ankor wax to protect the car from rust This are going well, not that much more to do. finish off the door cards and some wiring glitches 3 Quote Link to comment
Charlie69 Posted August 27, 2016 Report Share Posted August 27, 2016 Looking good. Great save on the fender. 2 Quote Link to comment
wobble Posted September 17, 2016 Author Report Share Posted September 17, 2016 Ive Ankor waxed the whole ute now, it worked really well i just need to buff it out 3 Quote Link to comment
mrbigtanker Posted September 18, 2016 Report Share Posted September 18, 2016 Not a flat bed fan but very nice mate.. Keep it up. Cheers 1 Quote Link to comment
Charlie69 Posted September 18, 2016 Report Share Posted September 18, 2016 I love the old flat trays you have in Australia. 1 Quote Link to comment
Charlie69 Posted September 18, 2016 Report Share Posted September 18, 2016 I do not know if you have the links but here are some that might help you. Rubber http://www.scottsoldautorubber.com.au/DATSUN%201300%20PICK%20UP%201964-72%20520.htm http://www.ebay.com/itm/Datsun-Nissan-1300-1500-520-521-Ute-Door-Front-1-4-Vent-Window-Rubber-Rubbers-/262603539317?hash=item3d24640375:g:XiQAAOSwXshWsZ7y&vxp=mtr Manual PDF downloads scroll down on the page http://www.davidcmurphy.com/olddat/620tech.htm Ther are wiring diagrams but they are for US trucks, but they should be cose enough to hel you figure out the wiring. Quote Link to comment
Charlie69 Posted September 18, 2016 Report Share Posted September 18, 2016 You might have to cut the engine mounts off the 620 frame and weld them to the frame of the 521 since you had the J motor. My 66 520 had a J13 and I had to cut the J13 mounts of of the 520 frame and weld on mounts out of a 620 L20B. 1 Quote Link to comment
wobble Posted September 18, 2016 Author Report Share Posted September 18, 2016 Thanks for that. I will need to get the chassis mounts welded up for sure, right now I'm going run the J15 for the shake down. Once I'm happy with all the fixes I'll look at doing the L20 swap. I drove it for the first time this weekend, just up the street to test the brakes and just give it a run. Most things went well clutch and gears worked well but the brakes need work locking up with just a touch. It was backfiring like a son of a bitch as well. I pull the dizzy and replaced the cap and ordered a rotor arm cos it was a little messed up. I'll have another crack at it next weekend when I get the part in 1 Quote Link to comment
wobble Posted September 18, 2016 Author Report Share Posted September 18, 2016 Not a flat bed fan but very nice mate.. Keep it up. Cheers Thanks mate Trying to find a long wheel base tub in Australia has been impossible. I've found a couple but with freight cost of over $1000 I had to let them go 2 Quote Link to comment
Charlie69 Posted September 18, 2016 Report Share Posted September 18, 2016 Long wheel base tubs are scarce int the US also. When I did the frame mounts for the L20B, I bolted everything concerning the engine mounts and the brackets up with the the engine bolted the transmission to the engine and set it al in as an assembly. Moved it front to back to clear the oil pan and side to side to get the mounting surface for the carb level side to side and also ffront to back. I drew center lines on the front cross member under the radiator and also on the trans crossmember to center engine and transmissision in the chassis side to side. I set the engine as low in the chassis as I could for my purpose. I had the engine blocked up from underneath and also had the hoist still attached with the chain snugged in case I knocked it off the blocks. After I had it all lined up I tack welded the mounts to the frame. I also had to make a custom trans mount bracket because I was running an automatic trans. One thing to watch is not to get the engine pushed back to far into the firewall because you will not be able to get the valve cover off the engine. Quote Link to comment
