Bory Posted February 9, 2016 Author Report Share Posted February 9, 2016 More is better! 1 Quote Link to comment
Bory Posted February 9, 2016 Author Report Share Posted February 9, 2016 And finally a full Vintage air system! - condenser 4 Quote Link to comment
Bory Posted February 10, 2016 Author Report Share Posted February 10, 2016 So I'm still using spare dash to mock up a/c vents, and cutting out center part where some bozero did his best at a butch job to install some weak deck. Quote Link to comment
Bory Posted February 10, 2016 Author Report Share Posted February 10, 2016 Here's what's left of what once was a Datsun radio house Quote Link to comment
Bory Posted February 10, 2016 Author Report Share Posted February 10, 2016 So here is a shot of passenger side dash, where I'm putting a 2-1/2" round vent, but my hole saw was a bit dull, and my pilot hole started to walk. So I clamped a penny to the underside, and welded the hole back up, I'll retry with a new hole saw. 1 Quote Link to comment
Jester Posted February 11, 2016 Report Share Posted February 11, 2016 I've done that trick a few times myself. Works great huh? Quote Link to comment
Bory Posted February 11, 2016 Author Report Share Posted February 11, 2016 So I tacked in this washer so I can run the hole saw, since the key hole was in the spot. Quote Link to comment
Bory Posted February 11, 2016 Author Report Share Posted February 11, 2016 After the drill 1 Quote Link to comment
Bory Posted February 11, 2016 Author Report Share Posted February 11, 2016 Here after both ends are drilled and vents fit test 2 Quote Link to comment
Bory Posted February 11, 2016 Author Report Share Posted February 11, 2016 Here is a mock up with the machine finished controls, with the 2 center vents. Waiting on my 18 gauge sheet metal for the insert, this weekend. 2 Quote Link to comment
Bory Posted February 12, 2016 Author Report Share Posted February 12, 2016 So not only am I gonna have one of mikes 1st set of balljoint set ups for the 521, but I will be the only one to have these 13" front rotors by Wilwood! 2 Quote Link to comment
q-tip Posted February 12, 2016 Report Share Posted February 12, 2016 That's a serious set of brakes. Quote Link to comment
Bory Posted February 12, 2016 Author Report Share Posted February 12, 2016 I sure hope so, 2500LBS with 4 Hundy HP under the bonnet! I might want to hault it down every once and again- Quote Link to comment
Ratwagon1600 Posted February 12, 2016 Report Share Posted February 12, 2016 So I tacked in this washer so I can run the hole saw, since the key hole was in the spot. What a fucking great idea!! Quote Link to comment
Bory Posted February 12, 2016 Author Report Share Posted February 12, 2016 Thanks RW16! It worked tits! Quote Link to comment
Bory Posted February 13, 2016 Author Report Share Posted February 13, 2016 So here is my replacement piece where I cut the butch job out Quote Link to comment
Bory Posted February 13, 2016 Author Report Share Posted February 13, 2016 Running it thru the roller, adding the radius 1 Quote Link to comment
Bory Posted February 13, 2016 Author Report Share Posted February 13, 2016 This is what it looks like in positio 1 Quote Link to comment
Bory Posted February 13, 2016 Author Report Share Posted February 13, 2016 Doin a little tackin! 1 Quote Link to comment
Bory Posted February 13, 2016 Author Report Share Posted February 13, 2016 Cleanin it up 2 Quote Link to comment
Bory Posted February 13, 2016 Author Report Share Posted February 13, 2016 Runnin string for sq-ness 3 Quote Link to comment
Bory Posted February 13, 2016 Author Report Share Posted February 13, 2016 Looks like a radio with huge knobs, but not- 3 Quote Link to comment
Lockleaf Posted February 13, 2016 Report Share Posted February 13, 2016 Haha you said huge knobs 2 Quote Link to comment
