Bory Posted February 3, 2016 Author Report Share Posted February 3, 2016 I just hope wiring this thing isn't a nightmare, I already have to do satellite speedo, fuel gauge will be like 400bucks worth of hardware Quote Link to comment
Bory Posted February 6, 2016 Author Report Share Posted February 6, 2016 time to link that rear end!!!! Well your right!! I went with this kit, That's what I'm doing this weekend! 2 Quote Link to comment
Jester Posted February 6, 2016 Report Share Posted February 6, 2016 PLEASE PLEASE PLEASE take lots of pictures. I am planning on doing a 4 link as well. What kit? 2 Quote Link to comment
Bory Posted February 6, 2016 Author Report Share Posted February 6, 2016 Ok J I sure will! Went with ride tech. Triangular instead of parallel, I was going with the latter at first, but the pan ard Bar rides above the housing, and really makes for a big bed hump, witch I wanted to avoid. I like em deep down and dirty, but everything is getting bagged these days, so I'm picking a mean stance that it always resides at! With a nice set of coil overs 1 Quote Link to comment
datzenmike Posted February 6, 2016 Report Share Posted February 6, 2016 Can't wait to see this one rolling smoke. 1 Quote Link to comment
Bory Posted February 6, 2016 Author Report Share Posted February 6, 2016 Sitting in front of King bolt, so I have 10 mins to post, The top angled bars, have tabs to weld to the inside top of housing, if you are using a 9" ford, this will work nice, I'm using 8.8, which has top mount bushings on the center casting part of the pumpkin. So I'm using that part to hang the top bars, which has me making my top mount. Gonna use 2-1/2" sq tubing and grade 8 bolt to replace this Quote Link to comment
Bory Posted February 7, 2016 Author Report Share Posted February 7, 2016 This is the new Rod end that will work with the factory mustang bushing, it is a temp, I will use 1/4" but pipe yard was out. Quote Link to comment
Bory Posted February 7, 2016 Author Report Share Posted February 7, 2016 Here is where the chassis too bar lands 1 Quote Link to comment
Bory Posted February 7, 2016 Author Report Share Posted February 7, 2016 Here I used 3-1/2" X 1/4" sq tubing 1 Quote Link to comment
Bory Posted February 7, 2016 Author Report Share Posted February 7, 2016 Bottom bar chassis mount 1 Quote Link to comment
Bory Posted February 7, 2016 Author Report Share Posted February 7, 2016 Too view 2 Quote Link to comment
Bory Posted February 7, 2016 Author Report Share Posted February 7, 2016 Once the kit is all tacked in place, the leafs springs can finally come out, it's important to leave the leaf springs and blocks in and set the springs at ride height, I used ratchet straps to load the springs, and all angles are set, Quote Link to comment
Bory Posted February 7, 2016 Author Report Share Posted February 7, 2016 Making sure that both bars are level to each other 1 Quote Link to comment
Jester Posted February 7, 2016 Report Share Posted February 7, 2016 Do me a favor and buy a welder that will run some good wire. That NR shit scares me when I see people building suspensions with it. I too have been looking at the RideTech parts. They make some nice stuff. 2 Quote Link to comment
Bory Posted February 7, 2016 Author Report Share Posted February 7, 2016 J notice that nothing is welded out, it's all in tack form only, when cab comes off chassis is going to the welding shop for proper beads! Just prior to powder coat. 2 Quote Link to comment
Jester Posted February 8, 2016 Report Share Posted February 8, 2016 Right on. Sounds like an awesome plan. I have a small 110 welder that I do the same thing with. In the process of doing my front end right now. Quote Link to comment
Jester Posted February 8, 2016 Report Share Posted February 8, 2016 Are you planning on coming north this year to attend an event. I would love to see this in person at Rats and Dats. Quote Link to comment
Bory Posted February 8, 2016 Author Report Share Posted February 8, 2016 That would be sick to attend, let's see if I can complete this build on time! Quote Link to comment
Bory Posted February 8, 2016 Author Report Share Posted February 8, 2016 Point of no return, all leaf spring hangers are gone!! Looks clean tho! 2 Quote Link to comment
Bory Posted February 8, 2016 Author Report Share Posted February 8, 2016 Next move is to order coil overs and build top mount. 1 Quote Link to comment
Bory Posted February 9, 2016 Author Report Share Posted February 9, 2016 Look what brown did for me! 1 Quote Link to comment
Bory Posted February 9, 2016 Author Report Share Posted February 9, 2016 Front runner! 1 Quote Link to comment
