Engine Porn (beyond ... saturation)
  • Replies 4.9k
8 hours ago, VFR800 said:
Let's call this variation on the Wankle a Dankle .  To bad it never made it into service.  The curse of the Wankle rotary, only Mazda made it work.  American Motors bet on GMs version and designed the Gremlin for it.  That's why there is so little room in the driver's compartment after AMC had to cram a straight six into the existing design.
I think this would have made the Vega more successful in the long run
Vauxhall - Rotary engine project
Edited by Jesse C.
  • Like 3
But the 304 V8 fit just fine, 🤣
  • Like 3
The Vega suffered from bean counter interference.  Originally the engine was supposed to have a stainless steel head gasket.  "Too expensive" cried the beans.  Put in an ordinary gasket.  It didn't work with the  aluminum to cast aluminum alloy/silicon engine block so failed.   The water leakage into the block ruined the engine.  That's why the expedient cylinder liner or over boring and acid etch work arounds had to evolve among die hard owners.
Note that the death valley test run resulted in 1 of the 4 card blowing its timing chain [which the disinformation publicity crew cleverly insinuated was a fan belt].
The result of this fiasco was that GM sold the Aluminum/silicon technology to Porsche which made very good use of it.
The rotary is an evolutionary dead end. Mazda improved on it but didn't perfect it. Seals are still a problem though better, emissions are through the roof, poor fuel economy and poor oil economy. They do make good power when revved up but no good for car engines that have to idle and accelerate up and down. Doesn't a Wankel wear out and need rebuilding more often???
Just think of the rotary as a small V8.  Doesn't seem so bad on mileage that way.
