datzenmike Posted March 7, 2021 Report Share Posted March 7, 2021 Buick 3800???? 1 Quote Link to comment
Mattndew76 Posted March 7, 2021 Report Share Posted March 7, 2021 Looks to be Toyota with an Eaton upon it. 2 Quote Link to comment
datzenmike Posted March 7, 2021 Report Share Posted March 7, 2021 A Toyota V6??? Looks GM to me. https://www.gmforum.com/buick-172/need-pic-top-3800-engine-305097/ 2 Quote Link to comment
ratpatrol66 Posted March 7, 2021 Report Share Posted March 7, 2021 It's a Buick. 2 Quote Link to comment
Mattndew76 Posted March 8, 2021 Report Share Posted March 8, 2021 Toyota Corolla...With a GM-3800 2 Quote Link to comment
VFR800 Posted March 8, 2021 Report Share Posted March 8, 2021 21 hours ago, datzenmike said: Buick 3800???? Correct 35 minutes ago, Mattndew76 said: Toyota Corolla...With a GM-3800 Also correct. 2 Quote Link to comment
datzenmike Posted March 8, 2021 Report Share Posted March 8, 2021 4 hours ago, Mattndew76 said: Toyota Corolla...With a GM-3800 3 hours ago, VFR800 said: Also correct. While Buick is part of GM the 3800 and has been used in Chevs, Pontiacs and Oldsmobiles it's still a Buick engine. Just like the Chevrolet 305 was used in the Oldsmobile but it was not called an Olds engine. 4 Quote Link to comment
angliagt Posted March 16, 2021 Report Share Posted March 16, 2021 How does it run without wiring? Quote Link to comment
Chopper Jim Posted March 16, 2021 Report Share Posted March 16, 2021 I see wiring to the distributor from the shock tower. Well hidden wiring harness. That is what i try to do with my wiring harnesses on all of mine. Makes it much cleaner under the hood. Chopper Jim 3 Quote Link to comment
Mattndew76 Posted March 16, 2021 Report Share Posted March 16, 2021 (edited) 3 hours ago, Chopper Jim said: I see wiring to the distributor from the shock tower. Well hidden wiring harness. That is what i try to do with my wiring harnesses on all of mine. Makes it much cleaner under the hood. Chopper Jim They still could have done a better job with that wire too and they don't have my billet bell crank installed. Edited March 16, 2021 by Mattndew76 2 Quote Link to comment
Chopper Jim Posted March 16, 2021 Report Share Posted March 16, 2021 Indeed. I split my factory harnesses to tuck out of sight, back of the engine, under exhaust, along valve cover or fuel rail. What were they thinking not using your billet bell crank? Chopper Jim 1 Quote Link to comment
