Camber on my 620!
barricade88
  • Replies 32
on your upper control arms, there are two bolts. you can remove the two bolts, add some "shims" (i used washers). It will suck the top of the tire IN creating the camber you seek.
(this works on the front only...)
Eagle_adam! Where are you located!?!
And alignment shims? Where do I get that, and what is it?
And IRS?
I don't know anything about camber, or what I need. I just know I want it
This is the most ridiculous thing I've heard in awhile. Why are you so desperate to get camber? Because hellaflush?
You might want to do some reading up on what camber is, what's affected when it changes, what a solid axle is, and what IRS.
