captaingamez Posted January 31, 2014 Author Report Share Posted January 31, 2014 ITBs are sweet and definitly more costly, getting the ITB setup on will probably cost as much as tuning it, tuners hate ITBs. I have been working on an ITB system for the Toyota 7MGE with my buddy who has a supra for a while now. Everyone loves to hate on 7Ms, funny that HKS got 400hp on one, NATURALLY ASPIRATED WITH ITBs!!!!! Quote Link to comment
Tx_jc_s13 Posted January 31, 2014 Report Share Posted January 31, 2014 If anyone is looking for a ld28 there's one here in Houston on cl rebuilt 0 miles for 1500 Quote Link to comment
captaingamez Posted January 31, 2014 Author Report Share Posted January 31, 2014 A rebuilt LD 28?? with 0 miles??? Does it have a new fuel pump? If so, worth every single penny. But im not converting to diesel, lol Quote Link to comment
Tx_jc_s13 Posted February 2, 2014 Report Share Posted February 2, 2014 not sure. it said complete motor! i will post a link later. also where can i get oem interior pars? and this might be a stupid question but i have a stock rb25det manifold laying around...does anyone know if it will fit a l series? Quote Link to comment
ggzilla Posted February 2, 2014 Report Share Posted February 2, 2014 It will not fit Quote Link to comment
datsunfreak Posted February 2, 2014 Report Share Posted February 2, 2014 and this might be a stupid question but i have a stock rb25det manifold laying around...does anyone know if it will fit a l series? You're right. That's a stupid question. ^_^ I kid. ^_^ Quote Link to comment
Tx_jc_s13 Posted February 2, 2014 Report Share Posted February 2, 2014 lol i figured. well i saw on ebay the cx racing manifold say it will fit l28 and rb25 Quote Link to comment
ggzilla Posted February 2, 2014 Report Share Posted February 2, 2014 RB is 4-valve per cylinder. L28 is old-fashioned 2-valve head. Quote Link to comment
datsunfreak Posted February 2, 2014 Report Share Posted February 2, 2014 lol i figured. well i saw on ebay the cx racing manifold say it will fit l28 and rb25 That seller doesn't know what he's selling. ;) RB is 4-valve per cylinder. L28 is old-fashioned 2-valve head. And the intake is on the opposite side of the car. ^_^ Quote Link to comment
captaingamez Posted February 2, 2014 Author Report Share Posted February 2, 2014 NO, the best intake for these cars is the non-EGR intake from 1975. Somewhat rare item, I have the next best thing, the 76-early78 intake that has no webbing and larger port runners. Our intake manifold is a little small and restrictive, but it also gives the Maxima a butt ton of torque due to the faster air flow from it being physically smaller. Quote Link to comment
Tx_jc_s13 Posted February 3, 2014 Report Share Posted February 3, 2014 Can the l24 be boosted? Mine only has 100k ms runs great. Only problem is a ticking sound that varies in loudness different days. Sometimes a slight tick and sometimes sounds like rod knock. I've been running cleaners through the oil, intake and fuel to try to clean the motor out (car was sitting for six years) I noticed yesterday when I ran seafoam through the intake the sound went away but this morning was back. Any ideas? Maybe stuck valve? Thanks for the help! Quote Link to comment
ggzilla Posted February 3, 2014 Report Share Posted February 3, 2014 Indeed. My neighbors was stolen, the cops found the 240 but the L24 was missing. That could be a cracked exhaust. Use a piece of hose to your ear and move it over the manifold to identify where the sound comes from. 1 Quote Link to comment
Tx_jc_s13 Posted February 3, 2014 Report Share Posted February 3, 2014 Danm your right I can't find an intake manifold lol usually Craigslist is my friend. Quote Link to comment
ggzilla Posted February 3, 2014 Report Share Posted February 3, 2014 I can find an intake manifold. Its right above the exhaust manifold on your engine. The one that makes a small noise when running. Quote Link to comment
Tx_jc_s13 Posted February 3, 2014 Report Share Posted February 3, 2014 Lmao I mean for sale Quote Link to comment
ArchetypeDatsun Posted February 3, 2014 Report Share Posted February 3, 2014 Can the l24 be boosted? Mine only has 100k ms runs great. Only problem is a ticking sound that varies in loudness different days. Sometimes a slight tick and sometimes sounds like rod knock. I've been running cleaners through the oil, intake and fuel to try to clean the motor out (car was sitting for six years) I noticed yesterday when I ran seafoam through the intake the sound went away but this morning was back. Any ideas? Maybe stuck valve? Thanks for the help! Could be a number of things, valve adjustment if it's a steady ticking (valve chatter), rod knock would be louder check your bottom end you might have to take the front of the engine apart, try moving the crankshaft by hand. I suggest not to run so many cleaners especially on an old engine. Seafoam should be enough for a one time use. Take the valve cover off and start it up and pay attention to the valves. To answer your first question yes the L24E can be boosted you will need everything from a L28ET, ECU, wiring harness, intake manifold, injectors, J-pipe, turbo, turbo manifold. You need to drill a hole on the oil pan for the oil drain line. Quote Link to comment
HRH Posted February 3, 2014 Report Share Posted February 3, 2014 You can make a manifold for the turbo, that's the easy part. Factory compression was 8.9:1 so good to go for boost. The problem is they used 8mm rod bolts from '81 on, mainly because the Maximas got the pussy 2.4l. They only make 120 hp in the EFI version. Less than the dual SU setup of the 240z. I've already considered boosting but I would get a set of rods from an earlier L24 to begin with, or have the current rods milled out to accept 9mm rod bolts like all the rest of the L motors. Quote Link to comment
Tx_jc_s13 Posted February 3, 2014 Report Share Posted February 3, 2014 Awsome thanks for the info!! I'll keep updates! Quote Link to comment
ggzilla Posted February 3, 2014 Report Share Posted February 3, 2014 You don't need any parts from the 280ZX Turbo - you can convert it using generic turbocharger kit. But it is far easier to swap over the factory Turbo parts. There are a lot of parts. Quote Link to comment
captaingamez Posted February 3, 2014 Author Report Share Posted February 3, 2014 Can the L24E be boosted - Of course, all engines can be boosted, its just how much boost. how much spark, and howmuch control over the two you have Can I boost the engine in stock form- Yes, but dont, please do it the right way. You need Megasquirt or something of the like for an engine management system, larger injectors and better spark control, or at very least a piggy back system to prevent blowing holes through the pistons. As HRH said, weakest point is the rods, even on the L28ET turbo engine, the rods are the weak point, I recommend anyone turboing use ARP rod bolts or again as HRH said, older 240Z rods. I still recommend using the ARP fasteners though, even though the early L24s had 9mm bolts. The best thing about an L24E is that is has a great head design, 8.9:1 compression ratio, and a lot of torque You need an exhaust manifold from a 280zx turbo, no getting around that, unless your a mega baller and can have one fabricated.I priced it out, $1200 is a great price. and yeah you CAN buy a generic turbo kit, I reccomend against that as well. Reason 1- The Nissan turbo is made by Garrett Airresearch, you are not going to get a better or more reliable turbo for less than $1000, unless you get a Holset HX35, in which case, you will absolutely need good fuel and spark control. Reason 2 - it will do 250hp Reason 3 - not buying turbos from the chinese, I have literally seen them blow up. Reason 4, FMICs are gonna be hard as hell to fit in a Maxima, im trying to figure this out right now... Quote Link to comment
Tx_jc_s13 Posted February 3, 2014 Report Share Posted February 3, 2014 Awsome thanks Quote Link to comment
ArchetypeDatsun Posted February 3, 2014 Report Share Posted February 3, 2014 Can the L24E be boosted - Of course, all engines can be boosted, its just how much boost. how much spark, and howmuch control over the two you have Can I boost the engine in stock form- Yes, but dont, please do it the right way. You need Megasquirt or something of the like for an engine management system, larger injectors and better spark control, or at very least a piggy back system to prevent blowing holes through the pistons. As HRH said, weakest point is the rods, even on the L28ET turbo engine, the rods are the weak point, I recommend anyone turboing use ARP rod bolts or again as HRH said, older 240Z rods. I still recommend using the ARP fasteners though, even though the early L24s had 9mm bolts. The best thing about an L24E is that is has a great head design, 8.9:1 compression ratio, and a lot of torque You need an exhaust manifold from a 280zx turbo, no getting around that, unless your a mega baller and can have one fabricated.I priced it out, $1200 is a great price. and yeah you CAN buy a generic turbo kit, I reccomend against that as well. Reason 1- The Nissan turbo is made by Garrett Airresearch, you are not going to get a better or more reliable turbo for less than $1000, unless you get a Holset HX35, in which case, you will absolutely need good fuel and spark control. Reason 2 - it will do 250hp Reason 3 - not buying turbos from the chinese, I have literally seen them blow up. Reason 4, FMICs are gonna be hard as hell to fit in a Maxima, im trying to figure this out right now... Can the l24 be boosted? Here's one idea this is a L28ET in a 82 Maxima. I almost bought this too it was located in Portland and it was at Canby 2012. Quote Link to comment
captaingamez Posted February 3, 2014 Author Report Share Posted February 3, 2014 That is some of my inspiration for mine. He did a side mount intercooler because of the same thing I am trying to figure out, fitment. Mine will be something like that. Black is so freakin rare. Quote Link to comment
