Clutch Fluid questions(photos)
Lacuchufleta69
  • Replies 13
Guest 510kamikazifreak
 what I'm running in it right now.lol not sure if its a good thing or a bad thing or I it really even matters.
Thats the problem your running it,you are supposed to push....the clutch
Dot 3 brake fluid, as usual.  Like mike said, you should probably flush the clutch system, but also your entire brake system with fresh fluid as well.  Brake (clutch) fluid absorbs moisture out of the air and turns dark in the process, signalling you to change it.  The moisture in the fluid leads to corrosion inside the system, and in the case of brakes will cause the fluid to boil prematurely.
Look at the manual or call a Nissan dealer for the correct fluid. The only difference between DOT 3 and 4 is the temp rating. For a clutch, the temp won't really get that high. This is off http://www.davidcmurphy.com/olddat/620tech3.htm and it says, DOT 3 (MVSS 116), SAE J1703C.
