Eagle_Adam Posted July 27, 2014 Author Report Share Posted July 27, 2014 Nice work :thumbup: I would like contact info for that glove box. Pm sent 1 Quote Link to comment
Eagle_Adam Posted July 27, 2014 Author Report Share Posted July 27, 2014 Sure looks like a motor, wish it would rotate like a damn motor..... Quote Link to comment
BlackBird620 Posted July 27, 2014 Report Share Posted July 27, 2014 Sure looks like a motor, wish it would rotate like a damn motor..... won't turn over? Quote Link to comment
Eagle_Adam Posted July 27, 2014 Author Report Share Posted July 27, 2014 Doesn't rotate.... Quote Link to comment
Draker Posted July 27, 2014 Report Share Posted July 27, 2014 Doesn't rotate.... Did you try pulling the pin on the engine stand? ::troll:: 3 Quote Link to comment
uberkevin Posted July 27, 2014 Report Share Posted July 27, 2014 What!? Sooo why won't the engine rotate? Quote Link to comment
Eagle_Adam Posted July 28, 2014 Author Report Share Posted July 28, 2014 Did you try pulling the pin on the engine stand? ::troll:: This guy...... 1 Quote Link to comment
Eagle_Adam Posted July 28, 2014 Author Report Share Posted July 28, 2014 What!? Sooo why won't the engine rotate? If I knew I would have posted..... Bound up somewhere I think..... Quote Link to comment
Draker Posted July 28, 2014 Report Share Posted July 28, 2014 It is like a hard stop like something is hitting? or does it just not move at all? Quote Link to comment
Eagle_Adam Posted July 28, 2014 Author Report Share Posted July 28, 2014 It's weird, the bottom end seems to move a bit, top end goes nowhere I'm too afraid of having the valves kiss a piston to force anything Was kinda wondering if the assembly lube had dried up since I put it together but I doubt it.... So I got mad and decided to lower the goon Quote Link to comment
]2eDeYe Posted July 28, 2014 Report Share Posted July 28, 2014 I forgot to ask Jrock to tape em off..... It's my bad and I too am a bit apprehensive You could clean up the tubing section with a wire wheel before you put a hose on there. The coating may cause problems later on when you try to take the hose off. It's weird, the bottom end seems to move a bit, top end goes nowhere I'm too afraid of having the valves kiss a piston to force anything Was kinda wondering if the assembly lube had dried up since I put it together but I doubt it.... So I got mad and decided to lower the goon Assembly lube shouldn't dry out, especially in as short of a period as this has been together. Did the cams rotate freely before you installed the timing chain? 1 Quote Link to comment
Eagle_Adam Posted July 28, 2014 Author Report Share Posted July 28, 2014 Never had to spin the cams prior to instal. I'll pull the top timing cover and top timing chain another day and find out redeye 1 Quote Link to comment
Eagle_Adam Posted July 29, 2014 Author Report Share Posted July 29, 2014 Much better!!!! Click for the vid Pouring oil down the spark plug holes did the trick! 3 Quote Link to comment
Charlie69 Posted July 29, 2014 Report Share Posted July 29, 2014 Did you assemble the pistons dry? I always have a coffee can of oil that I dip the pistons in before installing in the cylinders. Quote Link to comment
Eagle_Adam Posted July 29, 2014 Author Report Share Posted July 29, 2014 Yes, I was working with the FSM and a Nissan master tech neither advised to dip anything in oil. And the motors been on the stand for 6 months so I would imagine the oil would have seeped down to the pan anyway Quote Link to comment
Eagle_Adam Posted July 29, 2014 Author Report Share Posted July 29, 2014 But, since all is well I'm on to the emissions delete and assembly of the install mani. Once those are done and the transmission has been pressure washed I can drop the motor and trans in for The first time For anyone interested this is a badass written up on emissions delete and intake manifold assembly http://www.nicoclub.com/archives/intake-manifold-mysteries-revealed-diy-ka24de-emissions-removal-and-assembly.html 1 Quote Link to comment
Eagle_Adam Posted July 31, 2014 Author Report Share Posted July 31, 2014 Well I've got this confusin mess cleaned and sorted I think 2 Quote Link to comment
Eagle_Adam Posted July 31, 2014 Author Report Share Posted July 31, 2014 If all goes well it should be sitting in the engine bay before I go to bed! 2 Quote Link to comment
Eagle_Adam Posted August 1, 2014 Author Report Share Posted August 1, 2014 Kiss these mirrors good by! Much better 1 Quote Link to comment
Eagle_Adam Posted August 1, 2014 Author Report Share Posted August 1, 2014 First up, clean my tranny Muybueno 2 Quote Link to comment
Eagle_Adam Posted August 1, 2014 Author Report Share Posted August 1, 2014 Almost ready Right after I change these New tierods idler arm, and flipped centerlink 1 Quote Link to comment
Cpl620 Posted August 1, 2014 Report Share Posted August 1, 2014 im going to have to catch up on this thing. ive seen that engine sitting like that for a while now. Quote Link to comment
Eagle_Adam Posted August 1, 2014 Author Report Share Posted August 1, 2014 Found out the rear main seal installer for the L20b works on my De motor Quote Link to comment
Cpl620 Posted August 1, 2014 Report Share Posted August 1, 2014 awwww, yeah thats easier to get too when you have the bottom end apart.... Quote Link to comment
Eagle_Adam Posted August 1, 2014 Author Report Share Posted August 1, 2014 Bell housing bolts, motor mounts, and trans mount away from being installed 2 Quote Link to comment
