Round 2, FIGHT! - now with a DE in progress(for real this time...)
Eagle_Adam
  • Replies 2k
is that a hand operated butt crack scrubber?
yes sir! top of the line, ill clean it when im done and you can give it a whirl if your man enough
Happy belated birthday bro,
when your ready to sell that L-series let me know, might need a reason to drive to Oregon again.
thanx james! im ready to pull that motor anytime, ill be test fitting the KA in the next week or two so the L has to come out..........
and to anyone else that's talked to me about buying the L, its first come first served right now. I need the cash
Thanx for the birthday wishes guys :)
Picked up another tool to finish the motor, I ended up splitting this with Draynor so he has one to use on his LZ build in progress
5246B42A-A594-4A5A-809B-AEC5CDA33218-593
that ^^^ is a piston ring filer to adjust the and gaps on new rings
i saw it used here vvvv
so i went to drop off the valve stem seals i got in my gasket kit so i wouldnt have to buy a 2nd set
and
i got some early presents!
flywheel..... mmmmm shiny
9DA937CA-FA42-4244-9B22-B4EE5015E135-593
box of stuffs:
07523D7E-A232-4416-AE04-A5EE9AA4859B-593
Magnifluxed, hottanked, and honed block with a verified true block to head surface
EEDA5CE0-A81E-4AAA-8C60-602188CA0BD2-593
mmmmmmm - fresh metal :)
1963FB49-E022-4508-982A-DBA3D2E9F62B-593
and a polished and balanced crank!
2F315572-5363-496A-B113-A2FB56AC0B73-593
all thats left if the cylinder head work and to buy rings and bearings!!!!!!!!!!!!!!!!!!!!!
  • Like 5
BOOM!!!
B7F4BC5C-03FD-4DDF-86A2-1D8C64C0677E-741
well, now that ive blown just about all of the datto funds i had saved up on either the KA or my parents.........
im gunna have to wait till next Friday to buy rings and bearings  :/
Oh well, tis life i guess
But, just to have it documented
the machinist - http://stevesprecisionmachine.com/
the final tally:
*BLOCK
   -checked for true flat on block to head surface
   -magnifluxed for cracks
   -honed
   -hot tanked
   -and fresh freeze plugs
* Fly Wheel surfaced
* 2 broken bolts removed
* Crank
   - polished
   - balanced
* Cyl Head
   - decked
   - 3 angle valve grind
   - valve adjust
   - new valve seats
   - new valve guides
   - new valve seals
all in i spent $465.00 - and steve(the machinist) turned it around in LESS THAN A WEEK!!!!
happy mother fucking birthday to me!!!!!!!
guess it helps when this is the 5th motor you've run thru him + who knows how many odd jobs
  • Like 6
my GF is a college student.........
so thats not happening, besides she already put in some cash for the bill at the machine shop as a B-day present :)
and im also waiting for the piston ring filer i ordered to get here too
Got the old piston rings taken off, the wrist pins removed then reinstalled and lubed
3EE419D5-745E-4245-952C-0078A18E7FE9-811
AF07C4BF-7888-4210-A772-76B33A282023-811
Before and after cleaning and lube
D7FB3502-32BC-4EB7-A43E-72988D39EA83-811
Cleaned up the dizzy
A47CF6D4-077E-4A73-A195-52A4FB72A234-811
Cleaned up the oil filter extender thing....
3E191777-5AD2-4CF4-942F-DDE07907F007-811
Then it was onto one of my favorite parts of a motor build!
Paint!
3A2CA712-5FA9-4887-ADDF-61551A2B0F5E-811
776355C2-5DE5-42BA-AAC0-25A4CE26AB10-811
High heat primer
9AE94685-1573-44FC-97AE-746DFB5DCD1B-811
69FF6D33-110D-44DD-8E9A-9CB0E9FEDD84-811
And then black!!!! Ended up going with a gloss black to match the black powder coat that's going on the oil pan
3DE136CF-D4AC-4C2D-927E-8D7B943B95DA-811
BFF7BBFE-3F19-4B1E-950F-0ACE2BF522C2-811
Yummy!
131835E8-FEBB-4759-8007-2B3AF038C4EF-811
