fisch Posted March 14, 2013 Report Share Posted March 14, 2013 Awesome Atom! It is the perfect candidate for a major swap like this. You still thinking of trying to get the column shift to work? I want to see a smoky burn-out! Quote Link to comment
Z chopper Posted March 14, 2013 Report Share Posted March 14, 2013 keep looking at the pic of an engine test fit but not sure what engine that is. is it a KA single cammer? Quote Link to comment
AtomChurch Posted March 14, 2013 Report Share Posted March 14, 2013 Awesome Atom! It is the perfect candidate for a major swap like this. You still thinking of trying to get the column shift to work? I want to see a smoky burn-out! Yes. And yes. Haha. My hope was to make the factory column shift work. Though my first plans won't work out. I have three more I am going to try. I would rather not have a shifter on the floor after going to the trouble of getting the engine that low. I want it to look stock inside. Hahah. Quote Link to comment
AtomChurch Posted March 14, 2013 Report Share Posted March 14, 2013 keep looking at the pic of an engine test fit but not sure what engine that is. is it a KA single cammer? Dual cam Ka! Quote Link to comment
Z chopper Posted March 14, 2013 Report Share Posted March 14, 2013 hmmm wonder if a narrowed toyota truck rear end would work, as I have my doubts that the stocker would be able to handle a ka double cammer Quote Link to comment
AtomChurch Posted March 14, 2013 Report Share Posted March 14, 2013 hmmm wonder if a narrowed toyota truck rear end would work, as I have my doubts that the stocker would be able to handle a ka double cammer I have access to a Chevy rear axle for free I might pick up. Same lug pattern and easy options for disc brakes My brother swapped out headlight bezels before I got home from work. He said he was going to post photos. I didn't get much done today since I didn't make it too clack steel in time. But I did polish the chrome on the doors! Turned out beautiful. Quote Link to comment
Z chopper Posted March 14, 2013 Report Share Posted March 14, 2013 chevy axles are notoriously difficult to narrow, why do you think hot rodders tend to go with ford 9" . I was thinking of the Toyota rear as someone on here narrowed one for a 521 and it is fairly easy to find an LSD for it too 1 Quote Link to comment
AtomChurch Posted March 14, 2013 Report Share Posted March 14, 2013 chevy axles are notoriously difficult to narrow, why do you think hot rodders tend to go with ford 9" . I was thinking of the Toyota rear as someone on here narrowed one for a 521 and it is fairly easy to find an LSD for it too Hmm. These are good thoughts I will think about that. The only things that are set in my mind are motor and ride height. Everything else is up in the air. Quote Link to comment
cosmo Posted March 14, 2013 Report Share Posted March 14, 2013 i wanted to surprise atom with fixing the head lights before he go home. fixing the bezel had a stripped screw Quote Link to comment
cosmo Posted March 14, 2013 Report Share Posted March 14, 2013 also you dont need to narrow a toyota axle for a 521. it fits just fine unless you have crazy wheels, however this thing with something skinny,i was thinking a 320 axle or a 521 axle Quote Link to comment
skyblue Posted March 14, 2013 Report Share Posted March 14, 2013 Can a 521 axLe handle a dual cam kA? Quote Link to comment
cosmo Posted March 14, 2013 Report Share Posted March 14, 2013 yeah why not, its as strong as a toyota axle. the 4.10 (toyota) is the strongest from what i have seen, also the fastest (unfortunatly), i run them for strength and gear my tranfer cases (yes more than one with 4.7's in the back case) for a final drive of over 207:1, so way the heck down for crawling and thats with stock axle shafts . doesnt help that i am running 40 inch tires either. however the l16 has a 4.375 ratio in their rear end and i have a few of those laying around here. i will go take some measurements for my brother. but at least i have them here and we dont have to buy anything haha. and at minimum the 521 was rated as half ton rear end.... he wont be pulling that nor can he fit a half ton of anything in the car. and he wont have enough traction to shear the shaft off at the splines because the car doesnt weigh enough. haha i think it will be able to handle it. if need be we can make something else. any ideas on it? more than happy to for more information on the actual strength of the datsun axles? Quote Link to comment
AtomChurch Posted March 15, 2013 Report Share Posted March 15, 2013 I think I am goin to run the stock axle for a while an se what it can handle. Haha. Just throw some lowering blocks on it and gather everything for a swap later. It will help the money situation and it will be fun to see what happens though the braking situation might change this. Quote Link to comment
Z chopper Posted March 15, 2013 Report Share Posted March 15, 2013 I have my doubts that you would go anything more than a block on the stock axle and brakes before you decide firmly on swapping it out Quote Link to comment
AtomChurch Posted March 15, 2013 Report Share Posted March 15, 2013 Haha. I would like to try it but I don't want to deal with the brake headache rather just make My own setup. And at that point might as well do a new axle or I will just be repeating work. Quote Link to comment
mklotz70 Posted March 15, 2013 Report Share Posted March 15, 2013 I've looked at the '59 front axle before....when you want to start looking at discs for the front, let me know :) Quote Link to comment
AtomChurch Posted March 15, 2013 Report Share Posted March 15, 2013 Hmmmm! Okay. Haha. I want to do something with the back also! I want discs all the way around. That would be cool and more enjoyable to work on later. Quote Link to comment
mklotz70 Posted March 15, 2013 Report Share Posted March 15, 2013 Can't really help much with the rear until you make a final decision on the axle. :) 1 Quote Link to comment
AtomChurch Posted March 15, 2013 Report Share Posted March 15, 2013 I want to find some drop spindles or make some for the front to give me an extra couple inches of drop without raising the axle. For engine clearance. Quote Link to comment
Z chopper Posted March 15, 2013 Report Share Posted March 15, 2013 hmmm maybe look at dropped model T spindle or simular ford spindles keeping mind of king pin size Quote Link to comment
heretic Posted March 15, 2013 Report Share Posted March 15, 2013 I'm excited for your build this is going to be a sweet little car. The I-Beam axle is a great idea but I recommend looking at Ford I-Beams. The options for dropped beams & spindles are far greater, it's what all the hot rodders use. I don't know of anyone making dropped spindles for Chevy I-Beams & its not as simple as swapping out spindles from one beam to the next. Not only do you have to be mindful of the king pin size but the camber of the wheel is set by the beam & the spindle, and varies by car & manufacturer. Quote Link to comment
AtomChurch Posted March 15, 2013 Report Share Posted March 15, 2013 It's all measurable. And with the right tools anything will work! Quote Link to comment
heretic Posted March 15, 2013 Report Share Posted March 15, 2013 agreed Bob3 has documented that fact quite well but ".. money will probably slow me down too much to get done by then." using what is plentiful/available helps in the money department. Quote Link to comment
mklotz70 Posted March 16, 2013 Report Share Posted March 16, 2013 If you decide to go with the stock front axle, you should be able to swap the spindles over to truck spindles. When I measured the kingpins, they came up the same.....so just put the truck spindle on, then you can run any of the truck disc kits. Quote Link to comment
AtomChurch Posted March 16, 2013 Report Share Posted March 16, 2013 I might have to do an axle with drop spindle options. To get the trans to sit where I want the engine has to be low. And to lower the car to where I want it the axle would have to be notched. Drop spindles would give me an extra couple inches too play with. I made my trans bracket today and tacked it I . But the poky bushing I am using is 3/4 of an inch too tall. So now I have to find a new bushing for it before I can make the motor mounts. I can't use the stock bushing because I can't get it far enough back without making all kinds if changes and re modifying the crossmember. So when I get the bushings there will be more updates. Also my grill is missing for some reason. Ha. Quote Link to comment
