replacing oil filter without draining oil
d510addict
  • Replies 11
maybe if you elevate the oil filter side as much as you (safely) can it will make less of a mess.
just be as quick as you can about it. prelube the filter, have it in one hand and right as you twist off the old filter with your left hand, have your right hand standing by to install new filter. just dont cross thread it :)
On a Datsun L engine the oil filter is above the oil level in the pan. There is also an oil pump in between the oil in the pan, and the oil filter. The oil pump is also a "positive displacement" type of pump. That means unless the oil pump is turning, oil cannot flow through it.
Your biggest concern is you left about a quart of dirty oil in the engine. Your oil in the engine will get dirtier sooner.
Go ahead and change the filter, and add oil as required. Do the next oil AND FILTER change sooner. How much sooner? When the oil looks dirty again.
your oil is in the pan you will have the same mess and or results changing the filter weather the pan is full or empty
just pull the filter just like you would if the pan was empty
