skyblue Posted February 20, 2013 Author Report Share Posted February 20, 2013 Thanks for the info randy. Antony has a z master but the lines don't line up. So I will just have to save up for the right one. Hey on another note, do u have any 240z seats. I've been wanting to swap out the stock ones with z seats. Not in a big rush. Just curious what they go for. Quote Link to comment
Busta Nut Posted February 20, 2013 Report Share Posted February 20, 2013 I saw some earlier today on Sac's Craigslist. http://sacramento.craigslist.org/pts/3572331106.html Quote Link to comment
Busta Nut Posted February 20, 2013 Report Share Posted February 20, 2013 We can bend your lines very gently to fit the master.... ........I'm pretty good with brake lines. I think another question would be if we can use the later model master instead of the earlier one?? Quote Link to comment
Tristin Posted February 20, 2013 Report Share Posted February 20, 2013 Cars looking great Sky! Quote Link to comment
skyblue Posted February 20, 2013 Author Report Share Posted February 20, 2013 We can bend your lines very gently to fit the master.... ........I'm pretty good with brake lines. I think another question would be if we can use the later model master instead of the earlier one?? Like a 280 master? Quote Link to comment
skyblue Posted February 20, 2013 Author Report Share Posted February 20, 2013 Cars looking great Sky! Thanks. There's a long road ahead, but I'm enjoying it. Quote Link to comment
Tristin Posted February 20, 2013 Report Share Posted February 20, 2013 Ha its a Datsun... unless youre a straight baller, its always a long road. Quote Link to comment
skyblue Posted February 20, 2013 Author Report Share Posted February 20, 2013 Ain't that the truth brother. Quote Link to comment
Busta Nut Posted February 20, 2013 Report Share Posted February 20, 2013 Like a 280 master? No no. I meant in your 510. You have the early model master($$$$$$$$). Wondering if you can use the later model one($$). Remember the pics i sent? If I still had them I'd post'em. Quote Link to comment
skyblue Posted February 20, 2013 Author Report Share Posted February 20, 2013 oh gotcha. I may still have those pics. let me check. Quote Link to comment
skyblue Posted February 20, 2013 Author Report Share Posted February 20, 2013 ok so this is what is on the car. early model. will this one work? late model and this is the replacement also available, but reservoirs are reversed Quote Link to comment
Busta Nut Posted February 20, 2013 Report Share Posted February 20, 2013 Yes....I don't see why the first one wouldn't work. Just have to tweek the line a bit. But I'm no expert. Quote Link to comment
skyblue Posted February 21, 2013 Author Report Share Posted February 21, 2013 ok. that's good to know. now i just gotta get some money. just ordered bearings for my truck so one thing at a time. Quote Link to comment
skyblue Posted March 3, 2013 Author Report Share Posted March 3, 2013 new sticker Quote Link to comment
skyblue Posted March 3, 2013 Author Report Share Posted March 3, 2013 Little PS fun with indy's pic. Quote Link to comment
mattyhacks71 Posted March 4, 2013 Report Share Posted March 4, 2013 Sweet! Just not sure about that positive camber :rofl: Quote Link to comment
skyblue Posted March 4, 2013 Author Report Share Posted March 4, 2013 yea i thought it looked kinda weird too. but it's just to get an idea. Quote Link to comment
mattyhacks71 Posted March 5, 2013 Report Share Posted March 5, 2013 Yeah looks good! I like the slammed with hubcaps look Quote Link to comment
skyblue Posted April 10, 2013 Author Report Share Posted April 10, 2013 got some goodies today. rear wheel cylinders, oil fllter and u-joint for the truck. Also, does anyone recognize this sticker? it's on the front of the valve cover. just curious. and lastly, an artsy engine pic. Quote Link to comment
510T Posted April 10, 2013 Report Share Posted April 10, 2013 Repost from sightings: Quote Link to comment
skyblue Posted April 10, 2013 Author Report Share Posted April 10, 2013 nice. these sightings keep getting closer to home. Quote Link to comment
datzenmike Posted April 10, 2013 Report Share Posted April 10, 2013 ok so this is what is on the car. early model. will this one work? late model and this is the replacement also available, but reservoirs are reversed Just catching up. The replacements are marked 7/8 and the 510 was 3/4. That's 16% larger. Moving more fluid will require more pedal pressure, it'll feel stiffer. Also the rear line is for the front brakes and the front line for the rear brakes. The bottom master is clearly marked F at the front. I don't understand this. Quote Link to comment
Ranman72 Posted April 11, 2013 Report Share Posted April 11, 2013 this is for a 72 240z it worked fine had to tweak the brake lines a bit just be gentle Quote Link to comment
skyblue Posted April 12, 2013 Author Report Share Posted April 12, 2013 So I realized the master is not bad. The problem is with my leaky rear wheel cylinders. I let the fluid get too low and got some air in the lines. But I will be replacing the cylinders tomorrow. I hear they are a bitch to change. I've never done them on a 510. Anyone have thoughts or advice on the replacement process? Quote Link to comment
skyblue Posted April 14, 2013 Author Report Share Posted April 14, 2013 found another little problem. my carb has a hairline crack on the top and it seems to be leaking a very small amount of gas. SOB! oh well time to save up for a side draft. Quote Link to comment
