converted_to_datsun Posted November 8, 2012 Author Report Share Posted November 8, 2012 Got more parts yesterday... Picked up some su's! And Datsun mud flaps and a Datsun ohc valve cover and a new cowl or however you spell that My su's!! Need a little lincage tho but the ly are 2 bolt 38's New valve cover, needs stripped and re-painted New mud flaps I found in the junk yard New cowel Pickin up another part tomorrow Quote Link to comment
Eagle_Adam Posted November 8, 2012 Report Share Posted November 8, 2012 i see how it is, i give u your first elephant oil cap and you arent even happy....... Quote Link to comment
converted_to_datsun Posted November 8, 2012 Author Report Share Posted November 8, 2012 Haha and yes an elephant oil cap too. Little distracted by the carbs Quote Link to comment
converted_to_datsun Posted November 8, 2012 Author Report Share Posted November 8, 2012 Also got a fuse box from eagle Adam. Soaked it in vinegar and rinced it in soapy water and now ready to install Quote Link to comment
Eagle_Adam Posted November 8, 2012 Report Share Posted November 8, 2012 take a round wire brush to those contact, or some sandpaper. i found the wire brushed for cleaning gun barrels work great Quote Link to comment
converted_to_datsun Posted November 9, 2012 Author Report Share Posted November 9, 2012 I cleaned them good as new Spent some time on my electrical today cause I've been having issues with my headlights and corroded battery cables Took the old fuse box off to find this... Someone had a 32 amp fuse for the horn which shorted out a couple months ago and my horns burned up and looks like so did the back of the fuse box Put new shielded connectors on and a smaller fuse and sprayed the other harness with contact cleaner Pic of the new fuse box mounted My headlights actually turn on right away now! And my brights are actually bright! Then been having problems with my battery cable ends... Had to clean them every couple days or no start in the morning... So got new cable ends and cut the wires back a little to where they were clean. Old crusty New and improved! Quote Link to comment
Laecaon Posted November 9, 2012 Report Share Posted November 9, 2012 Well theres your problem, you are using clamp on ends. As in, they clamp onto the cable. They are notorious for having issues. Quote Link to comment
converted_to_datsun Posted November 9, 2012 Author Report Share Posted November 9, 2012 And more progress kinda. My window squeegee was completely destroyed on the drivers side. Managed to fine a complete one for the passenger side and then pieced one together for the drivers side out or the left over good bits Not much to see... But did take a pic of one of the seams where I spliced the drivers side together Quote Link to comment
converted_to_datsun Posted November 9, 2012 Author Report Share Posted November 9, 2012 Well theres your problem, you are using clamp on ends. As in, they clamp onto the cable. They are notorious for having issues. Yep that's the problem for sure. I hope the new ends last better. Any suggestion for better options? Never had issues with cable ends corroding so quick before Quote Link to comment
Laecaon Posted November 9, 2012 Report Share Posted November 9, 2012 I know I soldered mine on. I used one like this. Heated up until orange, cut some solder into it, and then stabbed the cable into it. Added a bit more solder to completely fill. I held it in a bench vise. Then I took a punch, and gave it a good whack. Quote Link to comment
converted_to_datsun Posted November 9, 2012 Author Report Share Posted November 9, 2012 Cool I'll pick some of those up and dig out my torch. At least for now they're fixed Quote Link to comment
Eagle_Adam Posted November 9, 2012 Report Share Posted November 9, 2012 my fuse box looked like that too man, glad you got it all fixed up. :D Quote Link to comment
converted_to_datsun Posted November 9, 2012 Author Report Share Posted November 9, 2012 Thanks dude, it helped to have a spare so I could swap stuff right over really quick Quote Link to comment
Eagle_Adam Posted November 9, 2012 Report Share Posted November 9, 2012 ;) been there done that one man :D Quote Link to comment
Eagle_Adam Posted November 9, 2012 Report Share Posted November 9, 2012 we will have to do a battery cable day cus ive got 4 rigs now with clamp on battery terminals - i fucking hate them....... Quote Link to comment
converted_to_datsun Posted November 9, 2012 Author Report Share Posted November 9, 2012 Sounds good dude after 5 vehicles we'll be pro's Quote Link to comment
converted_to_datsun Posted November 11, 2012 Author Report Share Posted November 11, 2012 Kinda had trouble getting motivation today so I lowered the front Too low? First time lowering with torsion bars... Thinking of going back up a little Quote Link to comment
converted_to_datsun Posted November 12, 2012 Author Report Share Posted November 12, 2012 Completely forgot to update haha Got a square port exhaust manifold from hwaggon yesterday. That way I'm ready to put those su's in when I finish messin with them. And a different head might be comming as well if the bottom end tests good Quote Link to comment
Eagle_Adam Posted November 12, 2012 Report Share Posted November 12, 2012 take ur grinder to that mani man, it should clean up real well. i sent you a txt about that cylinder head Quote Link to comment
Skib Posted November 12, 2012 Report Share Posted November 12, 2012 you can also just buy cables with soldered/sealed battery ends from any parts store. they come completed in various lengths Quote Link to comment
converted_to_datsun Posted November 13, 2012 Author Report Share Posted November 13, 2012 Adam I might have a cool idea where the fins would look good. Gotta figure out if that head is what I want.... Lots of searching the Internet is being done haha Pictures always help. Thanks skib I'll be doing that pretty soon Quote Link to comment
converted_to_datsun Posted November 14, 2012 Author Report Share Posted November 14, 2012 Finally got my truck some Oregon plates! And successfully avoided deq! Which means my upgrades can continue with no fear of smog Quote Link to comment
Eagle_Adam Posted November 14, 2012 Report Share Posted November 14, 2012 winning!! that cylinder head is yours whenever man, just let me know when you have time to meet up. Quote Link to comment
converted_to_datsun Posted November 15, 2012 Author Report Share Posted November 15, 2012 Awesome! Sounds good. My parts collection has grown 10x in the last couple months Quote Link to comment
izzo Posted November 15, 2012 Report Share Posted November 15, 2012 Just wait, it gets worse. Quote Link to comment
