Yellow_Feva Posted December 26, 2011 Report Posted December 26, 2011 I have my Panasport wheels wich are in perfect condition and look great but I have no idea what the offset is. there 15x6 in a 4x114 pattern Some pics. Quote
datrod Posted December 26, 2011 Report Posted December 26, 2011 If they were on your wagon they must be like +11MM or so. Someone will chime in and tell ya what all the stamp marks mean. But if you want to sell them I know a fucker that might want them. Quote
Radim Posted December 26, 2011 Report Posted December 26, 2011 Should be stamped, look around a bit better, but i imagine they're 10-15mm Here's how to measure it. http://community.ratsun.net/topic/32359-wheel-fitment-and-wheel-basics/ Quote
jesusno2 Posted December 26, 2011 Report Posted December 26, 2011 Its called a tape measure and a straight edge?? Quote
ggzilla Posted December 26, 2011 Report Posted December 26, 2011 That's backspacing. For offset, take the backspacing and subtract the wheel width. Quote
ggzilla Posted December 26, 2011 Report Posted December 26, 2011 Wheel Offset is the difference between the flange and the wheel centerline. Lay wheel flat on the ground (outside face down). You can also do this with tire mounted if it is aired up. Lay straitedge or straigt 2x4 across it, measure to the ground. Measure down to the flange back face Subtract the two measurements offset = (distance to flange) - (1/2 width) Quote
INDY510 Posted December 26, 2011 Report Posted December 26, 2011 . Panasport doesn't stamp the old wheels ,, , , the new ones have stickers,,, so I guess they "still" don't stamp wheels .... If my 16x8 Panasport measures 16x9 .... and the back-space is 4.5" .... . . it's not a zero offset 16x9 ..... :rolleyes: Quote
RedBanner Posted December 26, 2011 Report Posted December 26, 2011 . Panasport doesn't stamp the old wheels ,, , , the new ones have stickers,,, so I guess they "still" don't stamp wheels .... If my 16x8 Panasport measures 16x9 .... and the back-space is 4.5" .... . . it's not a zero offset 16x9 ..... :rolleyes: .... Then you cant measure, try again :P maybe + or- a few mm but if a wheel measuers 9 wide and 4.5 back spacing, its 0 offset, dont confuse the kids. Quote
INDY510 Posted December 26, 2011 Report Posted December 26, 2011 . Confusing for good reason ....... . ALL wheels measure one inch wider than manufacturer's specs ..... i.e. a 15x7 wheel measures 15x8 .. . . so a wheel that measures 16x9 with 4.5" backspacing is really a 16x8 +0 wheel? (I think) ........ :lol: Quote
ggzilla Posted December 26, 2011 Report Posted December 26, 2011 Nah, the overall rim width is always wider than the tire bead. Rim width: 8" Overall rim width: about 9" Quote
RedBanner Posted December 26, 2011 Report Posted December 26, 2011 It could have 10" extre in either sude doesnt matter, if the over all width is 30" and you gave 15 unches to tge mounting surface its a 0 offset Quote
RedBanner Posted December 26, 2011 Report Posted December 26, 2011 It could have 10" extre in either sude doesnt matter, if the over all width is 30" and you gave 15 unches to tge mounting surface its a 0 offset Wtf. My thumbs are douches... Quote
Duncan Posted December 27, 2011 Report Posted December 27, 2011 Wheels For Sale. Measure backspace as mentioned above. I'm pretty sure those would be a 15x6. Take measurement and consult attached chart. Bob's your uncle. Quote
banzai510(hainz) Posted December 27, 2011 Report Posted December 27, 2011 most sold were in the +22 offset for 510s and fit the 240z also perfect. But its only a guess on my part. as Panasport had many offset availible. Who cares it fits your car run them. if you find a E then a number right next to it thats the offset. Like E25 would be +25mm offset Quote
datrod Posted December 29, 2011 Report Posted December 29, 2011 Measure backspace as mentioned above. I'm pretty sure those would be a 15x6. Take measurement and consult attached chart. Bob's your uncle. Yellow. This is the fucker I was telling you about in my last post. :lol: Quote
