]2eDeYe Posted December 19, 2011 Report Posted December 19, 2011 After being asked to modify a few sets of stock KA brackets to fit the 620, I figured I might as well design a new set of brackets to help save time and shipping costs. Thanks to Eric Garside's patience in allowing me to use his brackets for measurement, they are finished. Here are Version 1.0 of my KA24-620 Swap brackets. The mounts are a 3/4" drop from the factory KA mounts. They will fit the KA24E and KA24DE with stock 620 rubber motor mounts and allow you to bolt the KA to your 620. You will still have to deal with the center link flip/ oil pan clearancing with the DE swap and any transmission issues due to your choice of transmission. If you run a 720 5-speed from behind a Z-series motor it should bolt to the stock transmission mount at the stock crossmember location. $100 a set + shipping. I have 3 sets available, but I can build more if the demand is there. Reference links for the KA swap. KA24E into a 620 KA24DE into a 620 Edit: These mounts require the later style 620 rubber motor mount for the L20B. Quote
Siqx20 Posted December 19, 2011 Report Posted December 19, 2011 Nice! Thanks for taking the time to build these! Im staying L for now but its cool someone is making them. Free bump Quote
69FJWagon Posted December 19, 2011 Report Posted December 19, 2011 Those look great Steve... Any thought on making them to use the stock or aftermarket KA motor mounts? I've ripped more than one stock 510 mount in my wagon with the FJ and would love to have the alternative to the stock rubber mounts if (WHEN!) I go KA in my 620 Clayton Quote
chester Posted December 19, 2011 Report Posted December 19, 2011 I know I need a set. But prolly wont be able to get one till the 1st. By the way they look great!! Quote
]2eDeYe Posted December 19, 2011 Author Report Posted December 19, 2011 Thanks guys. :) Those look great Steve... Any thought on making them to use the stock or aftermarket KA motor mounts? I've ripped more than one stock 510 mount in my wagon with the FJ and would love to have the alternative to the stock rubber mounts if (WHEN!) I go KA in my 620 Clayton It would depend on the thickness on the stock KA mount, the frame side hole pattern is probably an issue as well. That said, they will bolt up to these mounts with a little work to the index hole. The nice thing with the 620 mount is that they bolt right to the frame. My stock 620 mounts have held up pretty good so far. :) Quote
MicroMachinery Posted December 19, 2011 Report Posted December 19, 2011 Awesome. We need more stuff like this on the market. Quote
Wide14u Posted December 19, 2011 Report Posted December 19, 2011 I think this is great looks good Quote
]2eDeYe Posted December 20, 2011 Author Report Posted December 20, 2011 Hopefully I can sell a few to buy more Datsun parts and a new welding helmet, so I can see when I'm welding. :D Quote
Boaty Posted December 20, 2011 Report Posted December 20, 2011 Well hell now just whip up a set of brackets to mount KA motor mounts to the factory 510 crossmember, so us 510 folks don't have to hack up crossmembers and such ;) Free bump. This is promising :D Quote
Farmer Posted December 20, 2011 Report Posted December 20, 2011 How close well these work for The vg series? Quote
ggzilla Posted December 20, 2011 Report Posted December 20, 2011 The mounts are a 3/4" drop from the factory KA mounts Does that mean the transmission should likewise be dropped 3/4", or is the KA transmission already lower than the 620 transmission? Quote
]2eDeYe Posted December 20, 2011 Author Report Posted December 20, 2011 Well hell now just whip up a set of brackets to mount KA motor mounts to the factory 510 crossmember, so us 510 folks don't have to hack up crossmembers and such ;) Free bump. This is promising :D I think the oil pan is more of the issue there. :lol: How close well these work for The vg series? Not sure, don't think they would unless the VG has the same mounting pattern on the block, block width and the same crank centerline as the KA. These may work on the RWD CA series though, but that has not been verified yet. Does that mean the transmission should likewise be dropped 3/4", or is the KA transmission already lower than the 620 transmission? No. The 3/4" drop puts the transmission close to the stock 620 transmission centerline. I think the KA sits a bit higher in the stock configuration/vehicle. The 720 transmission I recommended is the same as the 620 transmission dimensionally other than the clocking of the bellhousing. With the stock KA mounts the 720 transmission hits the tunnel. To use them you would have to modify the transmission tunnel/firewall, either by cutting it or banging it up with a hammer. I chose to modify the mounts. Hope that makes sense... :mellow: Quote
yello620 Posted December 20, 2011 Report Posted December 20, 2011 How close well these work for The vg series? Farmer, these dont look like they would fit the VG at all. Quote
southern620 Posted December 20, 2011 Report Posted December 20, 2011 Those are lookin good man. I have a set he moded for me and seem strong and would recogmend his product to anyone enterested. Quote
]2eDeYe Posted December 20, 2011 Author Report Posted December 20, 2011 Thanks :) Those are lookin good man. I have a set he moded for me and seem strong and would recogmend his product to anyone enterested. You get them installed yet? Quote
wildmaninid Posted December 21, 2011 Report Posted December 21, 2011 I want to endorse these. Looking good! Quote
Farmer Joe Posted December 21, 2011 Report Posted December 21, 2011 these look badass man!! the KA swap is soooo tempting now that youve made these... dammit lol Quote
]2eDeYe Posted December 21, 2011 Author Report Posted December 21, 2011 I want to endorse these. Looking good! You made your own, but thanks :lol: these look badass man!! the KA swap is soooo tempting now that youve made these... dammit lol Thanks, pretty stoked they turned out so well myself :cool: After a stop into the Post Office it looks like shipping will be $10.95 anywhere in the US. A during pic, cause...we all like pics. :D Quote
southern620 Posted December 21, 2011 Report Posted December 21, 2011 2eDeYe' date='20 December 2011 - 02:29 PM' timestamp='1324420186' post='596739']Thanks :) You get them installed yet? Haha sadly no :(. I bought a 5 speed and it turned out to be trash so I'm still in search of a good one and I'm torn as to get a white bunny 1.5 or 2.0 clutch set up for this build. Quote
]2eDeYe Posted December 21, 2011 Author Report Posted December 21, 2011 Well that sucks. What is this 'white bunny' you speak of? Quote
Sinnful Posted December 23, 2011 Report Posted December 23, 2011 2eDeYe' date='21 December 2011 - 07:43 AM' timestamp='1324482200' post='597156']Well that sucks. What is this 'white bunny' you speak of? he means this......... http://www.240sxforums.com/forums/nissan-240sx-f-q/90222-ka24e-de-white-bunny-clutch-setup.html Quote
]2eDeYe Posted December 24, 2011 Author Report Posted December 24, 2011 Now that I like. All stock Nissan clutch beef. Thanks for the link :cool: Quote
